Question about Refrigerators
Montgorery-ward hmg-21674 not cooling - Refrigerators
4 Suggested Answers
SOURCE: My Ward, HMG - 1400 - 0, refridgerator coils will ice over
The problem sounds like the defrost thermostat is bad. I would replace it first.
Posted on Jul 09, 2009
milten1
  • 1304 Answers
SOURCE: Model HMG 21674 About how old is this model,
with out knowing the producton number i am showing this model to have a twelve year run
88-2000,
10 years is the expected life of most units now adays, so even if you were at the end of production
your pushing 10 years now
i would just buy new,,,, fixing one problem could only open a very exepensive can of worms
Posted on Oct 27, 2009
  • 670 Answers
SOURCE: Water collecting in bottom of
Check to see if your ice maker is not leaking water. Otherwise, the problem might be a clogged drain in the freezer. Need to remove the back cover in the freezer to check that the drain is clear. If it is clogged, try removing any blockage that you see and push wire down the drain tube to clear any blockage in the tube.
Posted on Oct 04, 2010
How do I clean condenser coils on a Ward HMG 2172-4
Coils on 'fridges are either underneath or on the rear, so you need a good vacuum cleaner with a crevice tool.
Apr 30, 2015 | Refrigerators
Montgomery ward side by side HMG 229637B ... defrost timer does not cycle ... have relaced defrost timer .. STILL DOES NOT cycle ...if i manually cycle coils heat ... defrost etc etc BUT refridgerator does...
turn the allen screws one is under the hindge side of freezer door and one is under fridge hindge side of door turn counter clockwise be carefull turn to far the adjustment screw will come out of the wheel adjustment bracket.also try having someone tilt refrigator back by pushing top of refrigator then turning the two white adjustment screws in same area of allen screw this adjust the front of the refrigator you may want to adjust the front adjustment so the refrigator is slightly tilted to the back this will help close the doors.
Jan 22, 2014 | Montgomery Ward Refrigerators
Water collecting in bottom of refrigerator side under meat keeper. Wards model no. HMG 2290
Oct 04, 2010 | Montgomery Ward Refrigerators
Model HMG 21674 About how old is this model, trying to decide to repair or buy new! Thanks.
88-2000,
Oct 27, 2009 | Refrigerators
Make and model numbers are important to give answers.
Jun 19, 2009 | Montgomery Ward Refrigerators
Not cooling
Replace the defrost timer about $20-30.00. One plug 2 screws. Mine was located on the bottom front behind the grill. (model HMG 24922) . Follow startup directions.
Sep 14, 2008 | Admiral 26 cu. ft. Side-By-Side...
Montgomery ward refrigerator freezer side by side model hmg 2164
Hi there!
Was the bulb blown that you removed?
If not, it may be the contact switch on the door. These usually are just a press fit, sometimes needing a screwdriver in a slot to release it.
Hope this helps you. If it does, Please take a moment to rate your problem fixed with Fixya! Thanks.
Jun 17, 2008 | Amana ARB2217C Bottom Freezer Refrigerator
Refrigerators Logo
41 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
