Question about Take 2 Interactive Hidden & Dangerous 2 for Windows
INSANITY 3D SETUP
WHEN I AM START THE GAME BY DOUBLE CLICK ON SHORTCUT ,INSANITY 3D SETUP COMES ON FRONT OF ME.WHAT I HAVE TO DO.
When i click my fifa 13 icon nothing happen and game dznt start
The shortcut may be disabled or pointed in the wrong folder
locate where the game is installed in your computer C: drive > programs, the game folder and look for the game name with exe as the extension - double click > If the game launches then delete the icon on ur desktop - right click the .exe file and create shortcut on desktop. if it does not then u may have re install the game
Aug 23, 2013 | Electronic Arts FIFA 13
My At&t 2Wire 3800 BGV-B will connect through the USB Netopia 3D Reach adapter using the 3D Reach Utility and my Sony BR and Cell Phone but, It will not connect through my Win Xp Wireless Zero Conf....
Insert the 2Wire CD and follow the on-screen instructions. If the 2Wire Setup Wizard does not
automatically start:
- Double-click the My Computer icon located on the desktop.
- Double-click the icon that corresponds to your CD-ROM drive.
- Double-click Setup.exe and follow the on-screen instructions.
2. If prompted by the Setup Wizard, enter the 20-digit key code you received from your service provider.
If you were not provided with a key code, contact your service provider.
Apr 27, 2012 | AT&T Computers & Internet
How to download my yahoo.messenger?
Hi
For downlaod the latest yahoo messenger in your PC click hear and get the messenger. after downlaoding click the downlaod file and start the setup this is very simple wait 4 few min,after complet the setup you get the shortcut in you desktop double click that shortcat and get the yahoo messenger Login with your User name and password and start to chat with you friends and family member.
Cheer
Jul 27, 2011 | Computers & Internet
I bought a digital copy of Airport Tycoon 3 and downloaded it. The game installation went fine but when I tried to open and play the game and error comes up saying "at3.exe has stopped working"...
I had this problem with this game.
Try right clicking on the shortcut (game icon), go down to properties, switch to the compatibility tab, click the 'run this program in compatibility mode' and put the pulldown options on XP (Service Pack 2), you might also try clicking the box at the bottom that says 'run this program as administrator'.
After making these changes press 'apply' and then 'ok' and then try double clicking on the shortcut again.
Mar 03, 2011 | Global Star Software Airport Tycoon 3 for...
Removal of shortcut virus in pen drive
Is this the Problem???
Don't format your Flash Drive.
Your data is still there.
Use Shortcut Virus Remover.
  • 100% free
  • Setup file to download 1.1 Mb
  • Installed file 2 Kb
It will recover your all data.
DOWNLOAD !!!
Sep 03, 2010 | Online Computers & Internet
Do i need an installation disk for the extreme 3d pro joystick if I'm using it with a mac
Follow the below guide from Logitech.....
The following Logitech gaming devices will function on a Macintosh computer running Mac OS 9 with Input Sprockets 1.7 or higher. You must also have a functioning USB port.
Logitech® Freedom™ 2.4
Logitech® Dual Action™ Gamepad
Logitech® Extreme™ 3D Pro
Logitech® Attack™ 3
WingMan® Attack™ 2 on the USB port
WingMan® ActionPad™
WingMan® Formula™ GP on the USB port
WingMan® Precision GamePad (USB version only)
WingMan® Extreme™ Digital 3D
WingMan® Formula™ USB
WingMan® GamePad USB
These devices will use the Mac OS Human Interface Device (HID) support. If you are experiencing detection problems using one of the supported devices on a Mac, please contact Apple to ensure your computer meets these requirements. If you are experiencing problems in a particular game, please contact the game manufacturer.
To determine if your Logitech game controller is detected please do the following:
  1. OS 9.x
  2. Click the "Apple Menu".
  3. Click "System Profiler".
  4. Click the "Devices and volumes" tab.
  5. Look at the USB tree to confirm that the controller is listed.
  1. OS 10.x (Traditional View)
  2. Double click the "Hard Drive" icon.
  3. Double click the "Applications" folder.
  4. Double click the "Utilities" folder.
  5. Double click "System Profiler".
  6. Click the "Devices and volumes" tab.
  7. Look at the USB tree to confirm that the controller is listed.
Jul 19, 2010 | Logitech Extreme 3D Pro Joystick
My Great Brain Robbery is old and says it works with Windows 95, Windows 3.1 & MacIntosh. I have Windows XP and can't seem to get it to setup. Any ideas?
1. Create a shortcut on the desktop for the setup/install program on the CD. 2. Right click in the shortcut you have created and select properties then click on the compatibility TAB at the top of the dialogue box. Tick the [Run this program in compatibility mode for] box and select windows 95. Then click [OK]. 3. Double click the Shortcut you just created and the program will install. 4. After it has finished installing find the shortcut it has created for the game and repeat step 2 for this new shortcut. It should now run in windows 95 mode.
Jan 09, 2010 | Davidson Pre-Algebra Math Blaster Mystery...
Initialization failed
You can still try to make the game compatible for installing it on the Windows Vista by following the steps below.
1. Insert the game disc in your CD-ROM drive, if the game setup or the autorun starts, exit it.
2. Open "Computer", Right Click the Cd Drive which has the game disk in it and select "Copy".
3. Go to your "Desktop" right click and then select "New" and click on "Folder" this should create a new folder on your desktop.
4. Open the New Folder and then Right Click and select "Paste".
6. After all the files are copied to the "New Folder" without any error messages then locate the file "Setup.exe" or "Setup" and right click and click on "Properties".
7. In the new window click on the "Compatibility" tab and run the program in compatibility mode for "Windows XP Service Pack 2" and then click on "Apply".
8. After applying changes double click on "Setup.exe" or "Setup" to launch the installation.
You can delete all the files copied from the CD after completing the installation
The game files need to be copied to the hard drive because the files on the game disk would not let you make changes while on the disk.
After the game is successfully installed right click on the game shortcut or the game "AOM.exe" in the root folder of the game and click and click on "Properties".
In the new window click on the "Compatibility" tab and run the program in compatibility mode for "Windows XP Service Pack 2" and then click on "Apply". (You can also try with the other options also)
The same set of steps can be used for installation of older games installation on Windows Vista.
Nov 19, 2008 | Microsoft Age of Mythology for Windows
3D mazeman
The game was released in 1998, and was developed for Windows 95/98.
To make the game run on Windows XP, try the compatibility for the installation and after it is installed use the same steps for making the game executable file compatible.
Note: Some game ".exe" file (executable file) would let you make changes in the Compatibility option, whereas older games might not give that option at all.
7. In the new window click on the "Compatibility" tab and run the program in compatibility mode for "Windows 98/ Windows Me" and then click on "Apply". (You can also try "Windows 95")
After the game is successfully installed right click on the game shortcut or the game ".exe" in the root folder of the game and click and click on "Properties".
In the new window click on the "Compatibility" tab and run the program in compatibility mode for "Windows 98/ Windows Me" and then click on "Apply". (Again, you can also try "Windows 95")
There are lot of files that need to be changed in order to get full functionality and to communicate with operating system and the hardware, hence there is no guarantee that the game might run even in cases where you will successfully install an older version of the game with the above mentioned steps.
Oct 24, 2008 | eGames 3D Mazeman Amazing Adventures for...
Open Questions:
See all Take 2 Interactive Hidden & Dangerous 2 for Questions
Take 2 Interactive Hidden & Dangerous 2 for Windows Logo
374 people viewed this question
Top Take 2 Interactive Video Game Consoles & Games Experts
Hanzu
EnergeeUK
Level 1 Expert
Are you a Take 2 Interactive Video Game Console and Game Expert? Answer questions, earn points and help others
