Image problems on my lcd tv
There is something wrong with the image in my tv. All the parts look fine. No blown capacitors or anything. Don't know what is wrong or what to replace.
  • 7,733 Answers
The internal power output maybe need replacement.If you have outage power loss the IPU receive to much voltage when the power restore and become faulty
Posted on Jul 16, 2013
  • 2336 Answers
SOURCE: Akai LCT2785TA Capacitors blown out
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or
not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
I repair these power supplies. Write to jah2mil@hotmail.com if you require further assistance.
Posted on Dec 30, 2008
  • 10 Answers
SOURCE: Dell W2300 LCD TV Picture Problem
Your problem is due to intermittent power in the backlighting circuit. This is usually caused by swelling of electrolytic capacitors in the power board. If you can find an honest electronics technician it is about a $40.00 fix.
Posted on Jan 18, 2008
budmrtn
  • 11361 Answers
SOURCE: Grundig GU22 DVDP LCD TV. No image on screen.
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Posted on Nov 17, 2009
  • 27 Answers
SOURCE: picture has a double image
I'd go for a new set.
Posted on Apr 09, 2010
SOURCE: Hitachi LCD TV, Problem with the image
I am having the same problem with my 50v500 as well. Please let me know if you find a solution.
Posted on Apr 25, 2010
42hl167 no picture but has sound
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
May 02, 2014 | Toshiba 42HL167 42 in. LCD Television
LCD image problems
You've here with a video of its app settings. I can't see any fault with it. Back-light is OK. But something wrong with its center part. Might be with its back light CCFL lamps. Check it. How old is this TV?
Jul 17, 2013 | Televison & Video
Samsung LCD TV Problem with Video
If this is a LCD, you have a failing LCD panel. Typical of older Samsung sets!
Jun 10, 2013 | Samsung Televison & Video
Viewsonic TV model N4285P-4M wont turn on, beeps and smells like burning ozone
69a74461-4e9a-4f69-9c55-94033d8b09fa.jpgYou problems sound like a power supply capacitor has blown.
Look for bulging tops on the capacitors similar to the photo.
Apr 01, 2013 | ViewSonic N4285p 42 in. LCD TV
This is the strangest thing I've ever seen. I have a Gateway FPD1975W TFT Monitor and its always worked great. The other day it went into a sleep mode via windows, and now it wont boot up the input...
Your monitor problem is causes by the power supply. What is happening is the power supply voltages are not stable, just enough to power the unit up. When you connect it to a video signal the power demands slightly increase and the power supply can't handle it. This is a very common problem with LCD after a few years of use. The issue with the power supply is the capacitors have started to fail. These parts are used to filter the output voltage and when they start to fail the outputs start rippling hence the problem you are having. Here is a link to a repair article that shows how to repair the Gateway FPD1975W monitor.
http://www.ccl-la.com/blog/index.php/gateway-fpd1975w-monitor-repair/
I hope this helps you get back going.
BuddyMc
Sep 20, 2011 | Gateway FPD1975W 19" LCD Monitor
Problem with a Viewsonic pj800 LCD projector. The image looks like it's not aligned properly. Like it's a double image and the color is all distorted. I imagine there is something wrong with the...
The image is made up of three polarisers, one tends to fail causing a problem with the image. On average it may cost £300 per polariser to be fixed. As you know these days you can get a projector for that price as everyone now wants HD and 3D. I recently bought 7x NEC NP115 for just over £200 each. Very good spec, auto power up (Which was important for what I needed)
hope that helps
Aug 04, 2011 | ViewSonic Projector PJ800 Multimedia...
I have a sumsung LA40M81BD lcd tv simple problem the tv is always clicking on and off and wont show anything on it. you have to switch it off from the switch on the wall.
Good day!
you have a better chances if you have failing capacitors on the power supply board.
How can you find it?
Just look the actually image of it and see if it is look like leak or bulged on the top.
If you found replaced it with the same type,ratings and value.
Thank you and don't forget to rate my answer.
May 29, 2011 | Samsung LN-S4692D 46 in. LCD HDTV
I have a Samsung LN-s2651d LCD tv that black screened on me and I don't know if the sound works because I have the internal speakers turned off... I use 5.1. I have been told that it is the t-con...
Do flashlight test on unit. If you can see an image thruout screen the problem is with the tcon board. If no image then it is the inverter board/circuits.
Sep 12, 2017 | Samsung LN-S2651D 26 in. LCD Television
Viewsonic N3251w 32inch LCDTV that does not have
It's most likely a capacitor. Open up your television, and look at your power circuit board. Look to see if any of the capacitors are blown.(the will be bulging look up an image of a blown capacitor to get a better image if not known already. Mine was (CS19, CS21, CS22, CS23) Also on (C672) from the Circuit Board.Can you look at the voltages of these for me? I'm missing the capacitors.
May 04, 2009 | ViewSonic N3735W 37 in. LCD TV
Televison & Video Logo
62 people viewed this question
Top Televison & Video Experts
