Question about Panasonic Cameras
Remove front cover Lumix dmc-zs7
How do you remove front cover from a Lumix dmc-zs7
  • james Chase Jul 16, 2013
    Opps, I didn't state the right part. It should be the front body cover, which appears to have a bunch of philips head screws around perimeter. And thanks much for your response!
  • Doctor PC
    Doctor PC Jul 16, 2013
    http://www.youtube.com/watch?v=o9O43EOki...
  • Panasonic Master
  • 7,733 Answers
This camera doesn,t had a front cover at all maybe the lens has a cover.Just turn it on and the lens open automatically
Posted on Jul 16, 2013
SOURCE: lens cover is stuck half
argh! me, too! i love this camera, but the lens cover is just plain stupid. we used the camera at the beach for a couple days, and i could tell a grain of sand got stuck behind the lens cover. now it is jammed and the camera is totally out of commission. why make a camera built for outdoor conditions, then put a lens cover like that on it!! i can't find a tech who can fix it, either. went to three shops in NYC and all said the cost to deal with it would pretty much buy me a new one... ! :(
Posted on Oct 28, 2008
  • 1705 Answers
SOURCE: windows 7 compatible driver for panasonic lumix camera dmc-ls70
You need to go to the lumix website and follow links to support and/or downloads for drivers.
Posted on May 02, 2010
  • 13433 Answers
SOURCE: Lumix DMC TZ4 lens cover
Hi could you clarify, the plastic doors in front of the lens are stuck half open, but the lens has retracted inside the camera or is the lens in half open position outside of the camera.
Posted on Nov 07, 2010
LongPockets
  • 1177 Answers
SOURCE: My Lumix DMC ZS7 reads
SD and SDHC cards fit the same slots, but they are slightly different electrically. Many cameras won't work with SDHC (high capacity) cards. SDHC is not backwards compatible.
If your manual doesn't specifically mention SDHC cards or memory card size bigger than 2GB, then the camera almost certainly won't work with SDHC. My Lumix won't work with anything larger than 1GB SD.
Posted on Jan 18, 2011
  • 11967 Answers
SOURCE: aI have a Panasonic Lumix
This could be a lens error...try some of these:
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous interiors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many cameras, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particles that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Jun 28, 2011
Where do I load 2 batteries in the digipower rapid charger
Panasonic DMW-BCG10, DMW-BCG10E, DMW-BCG10PP Battery, Technical Specification: Battery Type: Li-ion, Voltage: 3.60V, Capacity: 895mAh. Dimension: 41.60 x 30.40 x 9.40 mm, Product Type: Replacement Battery (Brand New). Compatible with: Panasonic Lumix DMC-TZ10 Series, Panasonic Lumix DMC-TZ18 Series, Panasonic Lumix DMC-TZ20 Series, Panasonic Lumix DMC-ZR1 Series, Panasonic Lumix DMC-ZR3 Series, Panasonic Lumix DMC-ZS1 Series , Panasonic Lumix DMC-ZS10 Series, Panasonic Lumix DMC-ZS3 Series, Panasonic Lumix DMC-ZS8 Series, Panasonic Lumix DMC-ZX1 Series, Panasonic Lumix DMC-ZX3 Series. Panasonic Lumix DMC-TZ22, Panasonic Lumix DMC-TZ6, DMC-TZ8 and Panasonic Lumix DMC-ZS5, DMC-ZS7.
Panasonic DMW-BCG10 Battery
Jun 04, 2012 | Digipower Battery Charger
I need a manual in English for my Panasonic Lumix 21X camera. Where can I buy one, or download instructions from the website? Lagoussis, Mombasa, Kenya
You have not indicated the model number, but I guess it is Panasonic Lumix DMC-ZS10
Did you buy this from Amazon.com? I think this camera is not released yet. But you can download the manual for Panasonic Lumix DMC-ZS7. Most functions will be similar in these cameras.
Go to following address: http://dlc.panasonic-europe-service.com/EUDocs/GetDoc.aspx?did=190538&fmt=PDF&lang=en&src=3&uilang=en-GB&model=DMCZS7
Jul 19, 2011 | Cameras
My huband bought the Lumix DMC-ZS7 camera for me to take to my son's wedding. I never even got a chance to register the camera. I am ready to download the images to my mac computer and have found out...
You can purchase the cable from here.
http://cgi.ebay.com/NEW-USB-Cable-Panasonic-Lumix-DMC-ZS7-Camera-14p-/160533669033
As for the disc, please tell me what you are looking for(a user manual, software that you got with the cam etc.,) so that I can link you to the same on the Panasonic website
Jun 10, 2011 | Panasonic Cameras
How do I format the sd card in the lumix dmc-zs7
1. Go to picture-viewing mode
2. Select Menu/Set button
3. Select Setup
4. Select 'Format' on Page 6/6
Feb 11, 2011 | Panasonic Lumix DMC-LZ2 Digital Camera
Manual for a panasonic lumix dmc-zs7
You can download and print the instruction manual for panasonic lumix dmc-zs7 in PDF format by clicking this link.
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Hope this helps. Thanks for using FixYa.
Oct 29, 2010 | Cameras
I cant install my panasonic ZS7 lumix on i mac
You can always use a card reader to download your pics to a folder you create on your desktop.
Sep 14, 2010 | Panasonic Lumix DMC-FS3 Digital Camera
Cameras Logo
63 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
