Question about SkyScan 86709 Atomic Wall Clock
Temp sensor need a new sensor 3n6 tx6u-516 v10(ss)
How to set time zones on La Crosse Projection clock 3N6
https://www.lacrossetechnology.com/support/manuals.php
3N6 its the technology named , but the model you can choose can be find on this site .
Mabe the model and page are find on these pictures.
la crosse 3n6 Google zoeken
Feb 18, 2016 | La Crosse Projection Alarm Clock with...
How do I set up my skyscan temperature transmitter
These devices are very particular about how they are set up. You are supposed to insert batteries in the transmitter first then wait awhile until it gets in the mood to start transmitting. Next, insert batteries in the clock and wait for the two units to begin "talking to each other".
Sep 16, 2014 | La Crosse Technology TX6U Wireless...
2001 Excursion 6.8 V10, hard start, high idle, code P1288 KOEO, and KOER, no memory codes, with temp gauge in normal range scan data reads 20 deg F, suspect CHT sensors looking for sensor location.
CHT -cylinder head temperature sensor located under the intake manifold.you have to remove intake manifold to replace sensor its in the cylinder head.
Oct 22, 2013 | Ford Cars & Trucks
My temp hand on the cluster wont moved i just got it fix and the company is saying it might be a temp swicth dats bad
That is correct. If your coolant temp. sensor is bad or there is a bad connection. Your temp. gage will not read the proper temp. The sensor is just a thermistor, here is what it looks like. You can check the sensor with an ohm meter. 10_2_2011_9_38_00_pm.jpg
Sep 29, 2011 | 1996 Chevrolet Impala SS
I have a 87 Suburban V10 I have change temp sensor, new throttle body, map sensor, spark plugs. wires, and still can't figure it out. Went to pass someone and it started flooding itself and would not stay...
Change your fuel filter. Replace the distributor cap and rotor. If you have the HEI ignition, they are really bad about burning through the igniton rotor.
Dec 19, 2010 | 1987 Chevrolet Suburban
I have a 2001 dodge 2500 v10 gas. When started it runs rough regardless of temp. Code says mixture is too rich. The problem goes away if engine rmps are held between 3 and 4 thousand for about a minute and...
I commend you on your tenacity. I guess the code is P0172. So you have metered air due the the MAP and IAT in combination and good engine coolant signal but still too rich and runs rough. It all points to a leaky fuel pressure regulator valve.
Jun 24, 2010 | Cars & Trucks
After car has reached operating temp, if I don?t move for a while the temp. will keep rising. I notice that the fans have not been coming on, but they do turn on when I turn on the A/C. Where is the...
on your car are two sensors one is an engine temp sensor the other is a coolant temp sensor
change the coolant temp sensor that is what goes bad most of the time when the water gets to 210 degrees the coolant temp turns on of that is working change the radiator fan relay
Mar 03, 2010 | 1996 Chevrolet Impala SS
Starting the engine when cold
Look for the temp sensor around the area where the top coolant hose meets the engine. That should be your thermostat housing (goose neck)....the coolant temp sensor is typically located in or around that component. What octane gas are you using? You may find that operating in the colder temp will require you to run premium in order to avoid excessive starts.
Feb 22, 2009 | 2001 Ford F350 Super Duty SuperCab
SkyScan 86709 Atomic Wall Clock Logo
63 people viewed this question
Top SkyScan Home Experts
Jerry Greenberg
Jerry Greenberg
Rick Goldsmith
Rick Goldsmith
Level 1 Expert
Are you a SkyScan Home Expert? Answer questions, earn points and help others
