Question about Garden
Homebase ACR 8500 portable air conditioning unit
I have lost the hose to the air conditioner.Please could you tell me if it is possible to source a replacement.Thank you
  • 86 Answers
SOURCE: Supplier of Wireless Remote for Fujitsu Split Air Conditioner
why want to replace remote.no idea abt w.canada
Posted on Mar 17, 2008
SOURCE: Parts for Fedders Portable Air conditioner model # SFPEB08F2A
there are two separate solid plastic pieces between the hose and the body of the unit
i have a hose but I am about to donate the unit
Posted on Jul 20, 2008
  • 134 Answers
SOURCE: Exhaust Hose DeLonghi PAC-210U replacement
Hi
You need to go here
://www.delonghi.co.uk/accessories.php
Posted on Feb 14, 2009
SOURCE: WA 903 and WA 10000 Portable Air Conditioning Units
http://docs.google.com/fileview?id=0B_eH0pjdeVdkYjE4ZTI1NTAtN2NhMS00NjVmLWEyZjYtZWQyNDQ3NmNiNjUw&hl=en_GB
Here's a link to the manual.
Hope this helps.
Regards, Davy
www.SidelightPhoto.co.uk Wedding | Event | Lifestyle
Posted on Feb 26, 2010
SOURCE: danby dpac7008 portable air conditioner
how do u turn on a silhouetto dandy floor air condition
Posted on Sep 04, 2010
When set to heat it blows out cool air.
Chances are your portable unit is a reverse cycle unit...If so, the leaving air temp in heating mode is not usually much warmer than room temp with 85 degrees F just about the maximum under PERFECT design conditions. A small portable in a large cold room may only be discharging 75 degree air, which is going to feel cold.
If your unit is NOT a reverse cycle unit, the heating source (probably electric resistance) is either not coming on at all or a portion of it is not coming on due to a defective element, burnt wire or a control issue.
Jan 08, 2015 | Amcor AL10000EH Portable Air Conditioner
Tip
Portable Air Conditioning great portable air cooling
Portable air conditioning offers you the convenience of mobility. All you have to do is roll the portable air conditioner to the room in which it's needed. Install an exhaust hose out a window or other opening (everything you need is provided) and turn it on. The installation process for these units is very simple. These portable air conditioning units are built small enough to be very mobile and are supplied with wheels for easy movement. A portable air conditioner will also work very well in apartment situations where you will often find a window unit is unacceptable.
Portable air conditioners are very unique in that they are portable and can be easily moved to different locations in your home or business. They can be a highly effective way to either help out an existing HVAC system in one room or cool a single room entirely. They are also one of the best ways to cool a room or area without having to install a window mounted unit.
These air conditioners use a compressor and Freon to cool just like normal air conditioning. They are very effective in cooling rooms and to keep the humidity low. Like normal air conditioners portable units extract hot air that must be vented. That is why they need to have the exhaust hose to the outside. These units can cool air as well as air conditioning done with window air conditioners. However they do not require installation like conventional window air conditioners this makes them very convenient for seniors or physically challenged people. Most portable air conditioners are supplied with a window kit. This kit contains exhaust hoses that will work in any window: double-hung, casement, awning or slider. Because they vent through an opening like a window they require no permanent mounting like window air conditioning.
Portable air conditioners are a very good cooling option for those who can't use the more conventional air conditioning methods. Remember though that this type of unit is not as efficient as most window units or conventional air. So while they may make your environment cooler, it won’t turn your tent into a room at the local hotel.
So as you can see these air conditioning units have some great advantages over other types of air conditioning. They are a great alternative for unique applications where central air or conventional window units are either unfeasible or too expensive. During special events, portable air conditioning can also be a great way to keep guests or equipment cool and comfortable. Always be aware though that because portable air conditioning will remove moisture from the air, they will also need to be drained occasionally similar to a dehumidifier.
Does your application warrant a permanent air conditioner of some form or should you just use a portable one? There are some interesting things to consider when making that choice. Weigh out all of the different options and make that decision based on what will best suit your needs.
on Dec 13, 2009 | Heating & Cooling
I have a homebase air conditioner 275937 and no intructions, where is the water out let, is it a hose fitted to the plug or a internal fitting to
I was also unable to find a manual through any of my many searches, however either of these two links may provide some general, generic assistance, given similar items. Hopefully you may find something useful:
1) This website includes numerous general info articles. Link to Article Library & Buying Guides (for similar items):
http://www.air-conditioner-home.com/portable-ac-library/
2) YouTube video - Portable Air Conditioner from Air-Conditioner-Home.com:
https://www.youtube.com/watch?v=LRDihKbdrwc
Aug 20, 2014 | Heating & Cooling
I lost my user manual for my 4 in 1 portable air conditioning unit. Does anyone know where I can find a replacement?
Hi, you don'tmention what model you have but don't worry; most portable 4 in 1 airconditioning units are similar. Here is a link to a user guide that should helpyou. http://www.onninen.com/sweden/produkter/onnline/Documents/Manual+OPAL+AC%201.pdf
Jul 17, 2012 | Soleus 4 in 1 Portable Air Conditioner
I am looking for the attachement that conects the exhaust hose to the ac unit i ve lost mine any suggestions
Try contaxting Amana Directly. www.amana-hac.com
To speak with a Heating and Air Conditioning Consumer Affairs Representative from within the United States, please call 1-877-254-4729 or use some duct tape and cardboard.
May 27, 2010 | Amana AP095R Portable Air Conditioner
Portable Air Conditioning unit no longer blows out cold air
Bit late I know, but for others having same issue, ensure that it doesn't need draining - use black tube at bottom left when viewed from behind to drain any excess water.
Jul 01, 2009 | Heating & Cooling
Blows room temperature air
Hello
Welcome to fixya.
I'm Huuum and happy to assist you
The air conditioning
unit works, but does
not cool the room
• window open
• there are heat sources in the room (burner,
lamp, etc)
• the exhaust hose is detached
• air filters clogged
• Inadequate size of the room (too large)
• close the window
• eliminate the heat source
• connect the exhaust hose
• clean or replace the filters
If all this dose not remedy the problem then you need to see service!
Please remember to leave a rating before you go!
Thank you
Jul 13, 2008 | DeLonghi Pinguino PACL90 Portable Air...
Danby dpac7008 portable air conditioner
I want to know how these portable air conditioners are supposed to be set up. Do they have to be on the same as the window out of which the hose goes? If the window is 4.5 feet off the ground, does the air conditioning unit need to be put on a table to make it and the window on the same level?
To the best of my knowledge the unit can stay on the floor and included the product features listed below and it does have a dehumidifier reservoir with direct drain and to make sure if you use the drain hose that the hose is higher than the item that you are draining the water into or you can elevate the unit so that the hose can drain outside and out the window - but you can also drain the water into a bucket or some thing that will hold water. I hope this will help you…..
Product Features
picexporterror From our expanded online assortment; not available in all Best Buy stores
picexporterror 7,000-BTU cooling capacity lets you cool rooms up to 250 sq. ft.
picexporterror Electronic temperature controls let you adjust the temperature in 1° increments for precision cooling; 3 fan speeds
picexporterror Dehumidifier mode removes up to 45 pints of moisture in up to 24 hours; 6.3-pint dehumidifier reservoir with direct drain
picexporterror Auto on and auto off timer
picexporterror Overload protection helps protect the air conditioner from power drains and surges
picexporterror Mesh filter is removable for quick and easy cleaning
picexporterror Includes remote
Apr 06, 2008 | Danby DPAC9030 Air Conditioner
Garden Logo
96 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
