My LG 55" LV9500 loses sound when switching from a standard def (480p) channel to a high def (720p or 1080p) channel. Then if I switch it back to SD the sound will come back. Yet EVERY time I want to watch a channel in HD I have to either turn my tv off and on again or go into my output resolution settings and uncheck 720p/1080p then recheck it again (even though it's already set to automatic). Is it the hdmi cable? The tv? The cable box? Any help would be greatly appreciated as it's driving me insane!
2 Suggested Answers
JT92677
  • 13 Answers
SOURCE: I have a VIZIO LED/LCD VF551XVT hooked up to a
I have the same set, same problem with one of my MOTOROLA boxes, but not with another. I have a SONY TV that works fine with this new MOTO box, but the new VIZIO does not. The audio is coming through the HDMI cable just fine, and the fact that it works when you cycle power on your TV means it's the SYNC between the TV and the BOX. I have the identical problem and am taking back the MOTO box for another one. I spoke to VIZIO for about 45 minutes trying different things. They think it's the MOTOROLA box, COX (my cable company) thinks it's this particular box, who knows.
Posted on Feb 04, 2010
Why is there sound but no picture?
According to the owner's manual page 2.7 (and this is an OLD [by HDTV standards] set), the TV can only handle input resolutions of 480p or 1080i on the composite inputs. Most HDTV programming today is 720p with some 1080i and 1080p on certain channels (like some Discovery shows about nature). It is possible that your set will not process the 720p signals being sent.
Nov 03, 2015 | Samsung TSL3294HF TV
Settings will not save
That is because most of the movies on tv are not produce in a 1080 p (Signel) Your lucky if there evan 720p, In High Def, 1080p is just a big hype to suck people in,
Dec 05, 2012 | RCA RTB1100 Rtb1100 Blu-ray Home Theater...
Upgraded to Hd and tv started messing up. Double images for first 10 minutes and sometimes tv picture goes off and lines up and down.
Your HDTV is capable of up to 1080P resolution. SDTV (standard def) signals are 480i; EDTV (enhanced def) is 480P; HDTV are 720P, (there is no 720i) 1080i and 1080P. Generally, those modes ending in "P" look better than those ending in "i". 1080i is the highest possible for broadcast TV, but BluRay disks and Directv have 1080P display capabilities.
The double picture you're describing sounds like the TV is set to display only standard or enhanced def signals while the Dish Network box is supplying it with HD signals. You should locate the control for the TV's resolution and make sure it is set to "1080P" and then set the output of your Dish Network set top box to the highest output it offers. Do the same for your BluRay player and any other devices, too.
Once set correctly, you should have a great picture once again. I hope this helps & good luck!
Sep 04, 2012 | Sony KDL-40XBR4 40 in. LCD HDTV
How do I get my 52inch rca scenium to show 1080 using my ps3
Video Output Settings Adjust the system's video output settings. Select the best output settings for the TV in use.
1.
Check the resolution supported by your TV.
Resolution (video mode) varies depending on the TV type. For details, refer to the instructions supplied with the TV.
2.
Select in_setting.gif (Settings) > in_dispset.gif (Display Settings).
3.
Select [Video Output Settings].
4.
Select the connector type on your TV.
Resolution (video mode) varies depending on the type of connector used.
videooutput001.jpg Input connector on the TV Supported video modes (NTSC region) *1 Supported video modes (PAL region) *1 HDMI 1080p / 1080i / 720p / 480p 1080p / 1080i / 720p / 576p Component / D-Terminal *2 1080p / 1080i / 720p / 480p / 480i 1080p / 1080i / 720p / 576p / 576i Composite / S Video *3 480i 576i AV MULTI / SCART *4 480p / 480i 576p / 576i *1 The video mode options vary depending on the region where the PS3™ system was purchased. In North America, Asia and other NTSC regions, 480i video mode is displayed as [Standard (NTSC)]. In Europe and other PAL regions, 576i video mode is displayed as [Standard (PAL)]. For details, refer to the instructions supplied with the product.
*2 D-terminal is a connector type used mainly in Japan. The resolutions supported by D1-D5 are as follows:
D5: 1080p / 720p / 1080i / 480p / 480i
D4: 1080i / 720p / 480p / 480i
D3: 1080i / 480p / 480i
D2: 480p / 480i
D1: 480i
*3 Composite is the connector used to connect the AV cable that is supplied with the PS3™ system. S VIDEO is a format mainly used in Japan.
*4 AV MULTI is a format mainly used in Japan. SCART is a format mainly used in Europe. If [AV MULTI / SCART] is selected, the screen allowing you to select the type of output signal will be displayed.
5.
Change video output settings.
Change the resolution for the video output. Depending on the connector type selected in step 4, this screen may not be displayed.
videooutput003.jpg 6.
Set the resolution.
Select all resolutions supported by the TV in use. Video will automatically be output at the highest resolution possible for the content you are playing from among the selected resolutions.*
* The video resolution is selected in order of priority as follows: 1080p > 1080i > 720p > 480p/576p > Standard (NTSC:480i/PAL:576i).
If [Composite / S Video] is selected in step 4, the screen for selecting resolutions will not be displayed.
If [HDMI] is selected, you can also select to automatically adjust the resolution (the HDMI device must be turned on). In this case, the screen for selecting resolutions will not be displayed.
videooutput004.jpg 7.
Set the TV type.
Select the type of TV in use. Set when only SD resolution (NTSC:480p / 480i, PAL: 576p / 576i) is to be output such as when [Composite / S Video] or [AV MULTI / SCART] is selected in step 4.
videooutput005.jpg 8.
Check your settings.
Confirm that the image displayed is at the correct resolution for the TV. You can go back to a previous screen and revise the settings by pressing the in_left_key.gif button.
videooutput002.jpg 9.
Save your settings.
The video output settings are saved on the PS3™ system. You can continue on to set audio output settings. For details on audio output, see in_setting.gif (Settings) > in_soundset.gif (Sound Settings) > [Audio Output Settings] in this guide.
Source: http://manuals.playstation.net/document/en/ps3/current/settings/videooutput.html
Feb 28, 2011 | RCA Televison & Video
Is my apex tv AT2702 high def??
According to apex its not and does not have a digital tuner the only way this can be high def would be 720P meaning 720 lines progressive scan.
Your aspec Ratio is 4:3 this indeed is a standard TV without a digital tuner so you will need a digital setop box or a digital tuner.
High DEF is not considered digital its conidered how many lines are displayed on the TV. For example 720p, 1080p .
  • Silver, 27-inch monaural television; 29.6 x 23.2 x 18.7 inches (W x H x D)
  • Front-panel audio/video input accommodates a camcorder, VCR, or gaming console
  • 3 rear AV inputs (including 1 S-video input), 1 RF antenna input
  • Channel scan, channel recall, closed-caption display
  • Offers V-Chip parental control, sleep timer, auto-off, and a full-function remote control
Technical Details
  • Brand Name: Apex
  • Model: AT2702
  • Display Technology: CRT
  • Display Size: 27 inches
  • Image Aspect Ratio: 4:3
  • Speakers Included: 2 speakers
  • Height: 18.7 inches
  • Width: 29.5 inches
  • Depth: 23.2 inches
  • Weight: 88.2 pounds
Jan 27, 2011 | Apex Digital AT2702 27" TV
TV set always starts up indicating 420p. How do I get it to 1080?I have Bell expressvu HD
is your cable or sat in HD(720p, 1080i, 1080p) over the air broadcast in the usa is in digital so it should start at the highest res available in your area
next are you using HDMI or composite for your cable or sat going into your tv if not your not going to get higher than 420p because A/V and S-video do NOT support HD
check your cable/sat box is it HD(high def) or SD(standard def) if SD going through cattv/attn in your only going to get 420p
now for changing the resolution its automatic it goes to the highest setting on its own
you can control the resolution through your cable/sat box, blue ray/hddvd player and other HD devices connected to the tv through the options menus of those devices BUT only when connected through
HDMI(supports 720p, 1080i, 1080p)
composite(supports 420p, 420i, 720p)
A/v and S-video(supports 420p)
cat tv/attn in(supports 420p, 720p, 1080i, 1080p) only supports what the tuner will do
i=50hz
p=60hz
Feb 11, 2010 | Hisense LHD3204US 32 in. LCD HDTV
Is the protron pltv32cm a high definition tv . I bought it in 2005.
Kind of. It is capable of 720p. So channels like FOX, the ESPN channels, SPEED, and other 720p broadcasts will look fantastic on that display. However, the 1080i broadcasts will be shrunk to fit your screen. They'll still look pretty good, though. Most people consider HDTV to be anything above & beyond 480p (so, 720p, 1080i, 1080p).
Apr 07, 2009 | Protron PLTV-32 Television
I Have A Vizio 32LCD and my problem is i am trying to get the PS3 to play with the HDMI I have a HDMI cabel hooked up to the hdmi input on the back of the set and it is hooked up to to the HDMI input on...
1. Check the resolution supported by your TV.
2. Select (Display Settings) under (Settings) in the home menu.
3. Select [Video Output Settings].
4. Select the connector type on your TV.
D2: 480p / 480i
D1: 480i
5. Change video output settings.
6. Set the resolution.
7. Set the TV type.
8. Check your settings.
Confirm that the image displayed is at the correct resolution for the TV. You can go back to a previous screen and revise the settings by pressing the button.
9. Save your settings.
The video output settings are saved on the PS3™ system. You can continue on to set audio output settings. For details on audio output, see (Settings) > (Sound Settings) > [Audio Output Settings] in this guide.
Apr 06, 2009 | Vizio L32 32 in. LCD HDTV
NO HIGH DEFINITION
  • HDTV capable: Yes (up to EDTV, 480p)
  • Jul 10, 2008 | Akai PT5492S 54" Rear Projection...
    How to get 1080 resolution from my plasmaI have the 6842 pe EDTV
    DVDs are 480p
    HD-DVD or Blu-Ray DVD is 720p or 1080i or 1080p
    you cannot increase resolution, if you want to play a 480p/i video on a 1080p/i or 720p screen, you are merely stretching the picture.
    If there is any kind of box that tells you it can convert 480i/p to 1080p/i or 720p(high definition) it is simply stretching the picture.
    you can convert 1080p/i or 720p(high definition) to 480i/p as you are taking out information from the video to make it smaller.
    Feb 25, 2008 | Sylvania 6842PF 42 in. EDTV-Ready Plasma...
    Televison & Video Logo
    18 people viewed this question
    Top Televison & Video Experts
    Electro Med Services...
