Question about Sewing Machines
Elna button hole on a 2004 sp - where do I set by pattern selector dial
5 Suggested Answers
SOURCE: Elna 2002 -
The question was regarding the Elna 2002 not 2007 and it wasn't a problem. I just do not understand how the pattern selection works. Thank you.
Posted on Dec 04, 2008
  • 8 Answers
SOURCE: I need a manual for a Necchi-Alco Super, model
Do you need a manual for your sewing machine,just visit wwww.janomestuff.com answer it all
Posted on Sep 19, 2009
SOURCE: Manual for Elna lotus sp model 35 m703163
http://www.scribd.com/doc/25386753/Elna-Lotus-Sewing-Instruction-Manual
Posted on Jul 13, 2010
SOURCE: the pattern (stitch) selector doesn't work when I turn it
it sounds like you need a new pattern selector dial & it wouldn't
hurt to have the machine checked to see if the internel part of the
dial is ok inside
Posted on Oct 12, 2012
I have a Elna air electronic 68, I am not able to use different function. Like thr preprogrammed.
Your AE 68 will have three dials across the front, from L-R, stitch selector, stitch width and stitch length. To sew any stitch with a sidewise needle movement, you will need to turn the stitch selector to that stitch on the selector, then turn the stitch width to between 3 and 4 and the stitch length to a similar setting, adjusting to get the stitch formation you need. To sew with the discs, set all the dials to zero, then insert a cam into the Elnagraph on top of the machine. Then turn the selector to the disc icon, and the stitch length around to the "S" and stitch width to 4.
Don't use reverse if using the elnagraph stitches.
Jul 01, 2017 | Elna Sewing Machines
How do you adjust the tension control on an Elna lotus SP
The tension dial is on the front of the machine right above the needle. The higher the number, the tighter the tension is applied to the top thread. HINT: When threading the top thread, ALWAYS RAISE the presser foot throughout the entire threading process. This allows the thread to seat completely in the tension disk. Tension is correct when the top and bobbin threads meet in the middle of the fabric.
Elna Lotus Instruction Booklet
Elna Lotus SP bobbin case repair Removing cotton jam from Elna Sewing...
Elna SP ST SU sewing machine repair tips (I use liquid Tri-Flow Synthetic Lube or silicone spray to loosen parts seized from old oil. Do NOT use WD-40, cooking oil, motor oil...)
Apr 29, 2017 | Elna Sewing Machines
Elna air electronic sewing machine button holing
if it is a smart machine no attachment is needed .some use dial settings only
Jan 25, 2013 | Elna Sewing Machines
My Elna SP suddenly stopped making the normal stitches regardless of whether I turn the stitch guide to "normal," "zigzag," or "overcast" mode.
Have you also turned the stitch width lever to 3 or 4 to form a swing needle type stitch?
Is this a Lotus SP or a Star Series SP? They should both have a stitch selector, a stitch width dial and a stitch length dial. Stitch width usually 3 or 4 and length usually at least 2 for a zig zag or overcast stitch. Also check the needle position dial, have you perhaps moved this off centre and not moved it back?
Mar 03, 2011 | Sewing Machines
Elna 2002 -
Dec 04, 2008 | Elna 2007 Mechanical Sewing Machine
Making a buttonhole on a Necchi 3204 sewing machine
Here's what the manual says:
Before sewing, fit the button-hold foot to the machine (long white plastic thing with red, ruler like markings).
Select the pattern selector dial that is solid green on the left hand side. Set the dial to "1" position. Sew the left side and raise the needle.
Select the pattern selector dial that is solid green on the top and bottom. Set the dial to "2" position. Sew 5-6 stitches and raise the needle.
Select the pattern selector dial that is solid green on the right hand side. Set the dial to "3" position. Sew the right side. Raise the needle.
Select the pattern selector dial that is solid green on the top and bottom. Set the dial to "4" position. Sew 5-6 stitches and raise the needle.
Hope that helps...
Nov 26, 2008 | Necchi 3537 Mechanical Sewing Machine
Sewing Machines Logo
121 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
