Cars & Trucks Logo
A
Anonymous Posted on Oct 25, 2017
2002 VW Jetta wont start after battery charger was not connected correctly.
My 2002 Volkswagen Jetta was starting fine until I accidentally connected my battery charger clamps to the wrong post. The charger itself was not plugged in to an AC outlet but the battery still sparked and now the car wont start, but the engine will turn over. The battery light and EPC light are illuminated on the dash.The engine is a 1.8T
warren
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on Oct 25, 2017
warren
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1102
Points
10
You can buy a diagnostic tool to plug in under the dash that will tell you what the error lights in the dash mean the tool will read obd1 and obd2 and cost about $20
Marvin
Level 3:
Top Expert:
  • Cars & Trucks Master 85,242 Answers
Marvin
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29051935
Points
266281
You may have blow the fuses check all of them.
3 Related Answers
ElDopa
ElDopa
  • 295 Answers
  • Posted on Aug 17, 2009
SOURCE: my epc light went on in my 2002 volkswagen jetta
Take it to the dealer, the EPC warning light - and even more the failsafe run which doesn't allow you drive faster than 20mph) is an indication of serious motor troubles. They can read the ECU faultcodes, which should be a good startingpoint for troubleshooting the cause ...
You could do some basic troubleshooting like checking the air filter, the oil level, the spark plugs, etc. You didn't fill it up with bad gas, did you ? And does the engine make strange noises/vibration when running idle ? In case you fixed some obvious cause, you can dis- and reconnect the battery to erase the engine's faultcode. If it's not fixed, the EPC (and failsafe run) will simply come on again.
My advice would be not to drive it untill it's fixed to prevent more potential damage.
roniecon
Ronny Bennett Sr.
  • 6988 Answers
  • Posted on Sep 21, 2009
SOURCE: 2002 VW Jetta won't start
Check the battery out put to see if it is at least 12.25 volts(may need to have it load checked).If the battery checks good,remove battery cables and clean them real shiney,also the battery terminals,and replace them back on the battery,WARNING,DO NOT DISCONNET THE BATTERY WITHOUT PLUGING A 12 VOLT POWER SOURSE INTO THE CIGARET LIGHTER PLUG,OR EQUAL.If you do not plug in a power sourse to the car,the computer will loose all it`s memory,and will have to go to the dealer to be reflashed.
Anonymous
  • 64 Answers
  • Posted on Aug 05, 2012
SOURCE: epc light came on and car died and won't start back jetta volkswagen 2002
try unplugging the battery and replugging it and then starting the car. hope that helps
2002 jettaL wont start when it's cold
02 VW Jetta GL TDI
WON'T start or HARD start as in takes alot of cranking over to finally start eventually
2002 Volkswagen Jetta won't start
If the charger is connected the wrong way round then lots of current will flow and any fuse in the circuit will probably blow.
If the battery charger has a fuse it is likely to have blown if there was a spark. It would then not be charging your battery. A low battery may not quite start the car.
Also If you did not connect directly across the battery there could have been a fuse in the car that the current had to flow through that may have blown. There are quite often a few larger fuses or a fusible link near the battery. They are not always easy to find so look in a service manual or ring a VW workshop and ask where the main fuses are.
It's a bit unlikely to have done any major damage I think.
Yesterday i accidentally left my lights on all to day to find that my battery died. After I jumped it things were fine. Later last night, the interior lights in the front failed to work and now when I...
put the key in the door and unlock/holdover for 30 secs,then lock/hold over for 30 secs.then press/hold down the unlock button on the remote,you have juast reset the system........
3helpful
2002 vw jetta cranks but will not start I left the lights on
2002 volkswagon jetta has a security issue since the battery ran low. It will start but not continoue to run. I have a flashing indicator of a car /key on the panel board
3helpful
2002 VW Jetta 1.9 diesel. Cranks fine but won't start!
check fuel rail pressure with a gage from renting from auto shop shold hold 30 PSI for 60 seconds if not replace fuel pump.
2002 vw jetta wont start ,just replace timing belt . What is the problem?
If the Valve Timing Was Not Set Correctly this will SurlyKeep it from Starting. The TIMING SETTING MUST BE TRUE and Possibly RECHECKED . With this Piticular REPAIR thhere is ONLT this to Check other than Any ENGINE WORING that may have been Disconnected.
I have a 2002 vw jetta turbo diesel. I have had
you probably need to get the feul common rail tested, the diesel pumps are also known to give trouble on that model car
54helpful
9answers
Electronic immobilizer
i recently had the problem with the immobilizer after mo 03 jetta battery had died after speaking with the dealer they said i would have to tow it to them. yeah a 160 miles after reading several blogs i put the battery charger back on put the key in the ignition and turned it to the on position and left it for @ 20 minutes when i returned the immobilizer light was out i then cycled the key off and back on the light came on then went out as it should then proceeded to crank the engine over and it fired without problems and seems to be fin now......curse greedy dealers
2answers
Vw jetta
check all connections to the starter, and check relays.. also have the starter tested
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
