Question about Sony KDF-E55A20 55 in. LCD Television
Sony KDF-E55A20 No picture or sound
I was watching a movie one night when the screen suddenly went blank and the sound also was gone. I thought one of my kids turned the power off, but when I tried to turn the power back on I noticed the power light blinking red. I can't turn the power off with the remote or on the tv, I have to pull the power cord out of the wall. there was no "popping" noise like the manual says can happen when the bulb goes out. I've contacted a sony style tech and he said it is a "circuit failure." From what i've read about other peoples problems it sounds to me like the thermal fuse. What do you think?
  • dzig Aug 29, 2007
    I checked the bulb and it looks fine. After I put it back in I turned the power back on. It is still doing the same thing. The power light blinks 6 times then pauses then just repeats this over and over.
    Scholar:
  • 53 Answers
The little flashing light down on front of your TV will tell you the problem by the color of the light or the blinking intervals, this is the reason you can not turn it off is telling you something. The manual should have a section dedicated to this part, most likely is the bulb, the bulb is easy to access generally hold by one or tow screws you can pull it out to verify the integrity of the bulb. Then again check the LED light before anything then you go from there.
Posted on Aug 28, 2007
  • GUILLERMO ORTUNO
    GUILLERMO ORTUNO Aug 30, 2007
    I am sorry for this. I was hopping that the blinking intervals will be able to tell you exactly what is going on, then I checked the user manual on the trouble shutting section and it has nothing to tell you what it is. Tough you may be able to squeeze this information from the tech support on Sony here is the number 1-800-222-7669, now if they can not diagnose the problem and if you bought it in the last 11 months ask them for the manufacturer's warranty, if that is not possible you might want to have a technician look at it and if possible heave him tell you the problem and if possible buy the part your self it will be cheaper. By the way here is the link where you can down load the user manual if you need it:http://esupport.sony.com/US/perl/model-h...
Sound problem on Sony KDF-E55A20 LCD tv
Check audio output section, It sounds that the audio output IC has damaged.
May 31, 2012 | Sony KDF-E55A20 55 in. LCD Television
Sony KDF-E55A20 55" 3LCD TV Purchased
Hi This is most likely the inverter panel that drive the CCFL's (Backlight tubes) or the backlight tubes themselves, I'm afraid I can't help with the diagnostic test or service menu.
hope this helps
Midge.
Feb 10, 2011 | Sony KDF-E55A20 55 in. LCD Television
While watching TV we got sound and the TV stoped working.. No picture.. when we turn on it makes noise..but no picture..what could be the problem.. Do you the lamp is gone.. or some other problem..
IT may because of over heating and more alternate current.....the picture tube is gone away from which video is not seen and speakers are tered due to high volume it seems so but do take that channel you are watching is consists of a channel.....otherwise without channel it ll make sound possibly......
Jan 20, 2011 | Sony KDF-E55A20 55 in. LCD Television
Picture goes out, comes back, sound is fine
I found several instances of this probllen on various forums, and determined that it is the bulb after all. It seemed that a bulb should either work fine or be burnt out, so I thought it might be something else, but so many other customers had this identical problem that I am 99% sure it is the bulb. I found a replacement bulb with housing for about half the price of the Sony Store, so i ordered it. In the meantime, another customer offered a suggestion to try adjusting the Power setting to Power Saving instead of Standard. I tried this last night and the picture worked fine! I will replace the bulb when it arrives and keep the old one on hand in case this happens in the future. Thanks to all of the posters out there!!!
Dec 07, 2009 | Sony KDF-E55A20 55 in. LCD Television
No picture no sound
Thats great that TV is working fine. How about rating solution as 4 blue diamonds?
Thanks.
Mar 04, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Sony kdf e55a20 picture goes black sound stays on
Thanks for updates.
Its time to replace Lamp. Please buy original Sony Lamp for Sony TV and avoid aftermarket or compatible parts for good performance of TV.
You can purchase original Lamp form Sony Accessories Store. Just type TV model in search box and see details by click search.
Good Luck
Jan 17, 2009 | Sony KDF-E55A20 55 in. LCD Television
Screen became dim over time and then blank. Red LED lights blinks when on and sound is fine. Is this the bulb, unlike the others that went suddenly?
There is more than one flourescent tube in your TV, It could be possible that one after the other has failed, these should usually last a few years depending on usage.
If it is not the tubes then there may be a fault in the backlight inverter although this would more likely show up as a sudden failure.
How old is your TV?
Oct 16, 2007 | Sony KDF-E55A20 55 in. LCD Television
Sony KDF-E55A20 55 in. LCD Television Logo
316 people viewed this question
Top Sony Televison & Video Experts
Steve Allison
Steve Allison
Jaime Hernandez
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
