Question about AEG Washing Machines
I get an E20 error code intermittently on my AEG Lavamat Turbo 16850 washer drier.The drain filter and pump are fine and so is the condenser. Once I totally drain the machine with the black drain hose
I get an E20 error code intermittently on my AEG Lavamat Turbo 16850 washer drier. The drain filter and pump are fine and so is the condenser. Once I totally drain the machine with the black drain hose at the front and restart, all is well for a short while. I have filled the machine manually many times and selected drain and it empties completely with no problem. Could it need the error code cleared from its memory like a factory reset?
2 Suggested Answers
  • 44 Answers
SOURCE: AEG Lavamat Turbo 12830 - error code E20
Hi
E20 means there is a bolckage in there
remove filter and clear any debris in there and check impeller is turning ok.
regards
Posted on Mar 21, 2009
Remove housing
How to replace a washing machine door seal on an AEG ...
? 5:38
https://www.youtube.com/watch?v=KlAXmnKJQ9k
Aug 17, 2009 - Uploaded by eSpares
This video will show you how to remove and replace the door seal. ... Do you have video repair instructions for AEG washing machine OkO ...
AEG removing drum Washing Machines Questions ... - Fixya
www.fixya.com/tags/removing_drum/washing_machines/aeg
AEG washing machines removing drum related questions and answers. ... into thehousing and get the object out. well as we say in my town you got a "toston" .
Aeg/electrolux lavamat 76810 waschmaschine E20 - YouTube? 0:28https://www.youtube.com/watch?v=1WX5rKxFrXsMay 3, 2015 - Uploaded by jusuf jerkovicAeg/electrolux lavamat 76810 waschmaschine E20 ... front load washer from not draining -- washing machine error code e20 - Duration: 2:52.washing machine error code e20 - YouTube? 2:52https://www.youtube.com/watch?v=2B7FxovrxKoOct 25, 2014 - Uploaded by teppichkopfSave some money and fix it yourself. Totally bizarre how stuff gets stuck in the drain!
Dec 21, 2015 | AEG Washing Machines
Another AEG e20 Plea, tried everything please help!
E20 on your machine means some sort of drain problem. If it actually goes through the spin cycle fine; some water will still not drain out at the time of the tumble dry. Check the wall drain to make sure it isn't clogged..
Check the drain of your wall, not the washer, this shd be cleaned out thoroughly; and the exit pipe of your washer should not fit too tight into it, there shd be some space for air.
This is a further tip, if helped click helped.
Apr 10, 2013 | Washing Machines
Have an error code on my machine E20 - is it terminal?
You need to clear out the drain pump. E20 means drain blocked. You should be able to access the pump from the front bottom by unscrewing and removing the filter. If not then you will need to tilt the machine back as far as you can so you can access the underneath. You will see the small drain pump. Have a basin ready to catch any water that comes out when remove the pump which is only held in by 1 or 2 screws and twisted out or pulled out. If it is clear then try removing the pipe that goes from the pump to the base of the tub. Commonly a sock gets stuck. Hope this helps
Mar 04, 2011 | AEG Lavamat 72640 Front Load Washer
Oko lavamat 74640 update showing error E20 what does this mean?
its a draining error, check sump, pump and drain hose for blockage failing that it needs a new pump.
Mar 31, 2010 | AEG Lavamat 72640 Front Load Washer
Error code e20
E20 means you have a drain problem. Check the drain filter on your machine to make sure it isn't blocked by fluff/coins/etc. Should work again unless you have a bust pump (which I had).
If machine is full of water, do an emergency drain through the little pipe on the bottom front. Good luck.
Jan 18, 2010 | AEG Lavamat 72640 Front Load Washer
E20 what does that mean?
E20 is a drain problem. Clean out the drain filter, normally found bottom of machine. Do emergency drain first or you will flood the room if there is water sitting in drum. Hopefully you just have a blocked filter or pipe, otherwise you may have to replace pump if it has failed.
Hi
regards
Mar 21, 2009 | AEG Lavamat 16810 Front Load Washer/Dryer
AEG 72640 update
e20 means cant drain i usually found itsufficient to clean filter and restart but this time i blew down waste pipe /drain,cancelled program and reset
Jan 13, 2008 | AEG Lavamat 72640 Front Load Washer
Washing Machines Logo
47 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
