Question about Miele KFN8462S Bottom Freezer Refrigerator
Freezer keeps getting warm
Bottom freezer keeps warming from -18 to -11 and higher , if press super button it will drop to -18 again but warms back up once the super button is turned off . any ideas ? what does th compresser do , could it be that?
4 Suggested Answers
  • 311 Answers
SOURCE: GE Refrigerator- Freezer coil ices up and the F/F gets warm
It is not defrosting obviously. Check heater and defrost limit for continuity. Defrost limit is small round can-looking device; it must be cold to check accurately. If anything shows no continuity then it needs to be replaced. If continuity ok then replace defrost control. Please contact me if you need further help or leave feedback if appropriate as that is how I get paid. Thanks for letting me help you!
Posted on Nov 30, 2008
SOURCE: Fridge Freezer will not maintain fridge temp, but freezer fine
My miele fridge freezer has just come up with a fault code F4 where the temp is... what does this mean and how can we fix it???
Posted on Jan 18, 2010
heatman101
  • 43501 Answers
SOURCE: Fridge freezer kfn 9755 ide
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Jun 12, 2011
We have got water coming out at the bottom of the freezer of our fridgidair FRC170FF how do i fix it?
1. Your freezer may be not cold enough so water does not freeze.
2. Your freezer may leak so warm air goes into the freezer and keep the temperature higher than freezing temperature.
Jul 03, 2014 | Miele KFN8762SDED Bottom Freezer...
Q45 sputtering when it gets warm
look into camshaft position sensor, i know of three sensors that will do this, throttle body, cam shaft, and timing. hope it helps
Nov 20, 2013 | 2004 Infiniti Q45
Amana refrigerator, bottom freezer. Back keeps icing up. I have unplugged and thawed it twice, within 2 weeks it is frozen again and freezer warm
This is a defrost problem most likely caused by a defective defrost thermostat. It is located in the freezer compartment behind back wall on top right hand side of coils and usually has a brown and an orange wire connecting to it. It should have continuity when checking with a volt/ohm meter when it is frozen and read open when it is warm.
I have seen many of the newer electronic temperature model bottom mounts with defective control boards as well that cause the fridge to skip the defrost cycle.
Jun 14, 2010 | Amana Refrigerators
Frost free combo unit fridge keeps getting warm
Hi: You have a bad defrost heater or defrost timer. I'm not familiar with the brand but the heater will be below the evaporator coils in the freezer ( in the back behind a panel.) When you do your defrost that your dad told you to do, it will work until it frosts up again. You are doing the work of the defrost heater. I hope this helps, Jeff
Jun 02, 2009 | Belling BE811 Bottom Freezer Refrigerator
Upper Fridge Too Warm
We had a warm fridge and super cold freezer.....we unplugged for about 20 minutes and the fridge started to cool down again.... but only for a few days then back to warm.
We ended up unplugging and "defrosting" the whole unit for 24+ hours ....Now it works perfectly again.
I think it happens when one or both of the doors is not shut or sealed all the way and engine works too hard and "freezes" up the fans or some other part of the system.......I am just happy I did not have to buy a new fridge.
Mar 30, 2008 | Maytag MB2262H Stainless Steel Bottom...
Frigadaire freezer cold but fridge compartment is warm
i need the complete model number to narrow it down they still make the frs20zrg to this day the last two numbers like frs20zrgwo or frs20zrgw9 is what will tell me what kind of defrost system it has the serial plate is in the fridge side up by the light bulb or on the left hand side or right hand side of the fridge compartment up near the top sorry to be a bother but its necessary
Mar 30, 2008 | Frigidaire FRS26ZSG
Cold freezer/warm refrigerator
Same problem with Frigidaire Gallery model#GLRT182SAW5 (dated 2002 on back of case)
Vents were blocked with ice. Vents (from top compartment to lower) located behind light. You can check by poking a chopstick up the (2) holes; be careful not to hit fan blades.
Solution:
- took freezer coil cover off in back; checked that defrost heater element was working (marked and rotated the timer in the hole next to light); checked that fan working. Found ice in the vents and defrost drip area. Got it out with hair dryer.
- cleaned compressor coils in back (check fan is rotating; also tweaked some of the compressor tubing bends to make them more smooth - read somewhere about a manufacturing defect ...); blew out drip tube from defroster while down there.
- Set the freezer control to WARM and the refrig control to COLD (THIS SHOULD IMPROVE AIR FLOW FROM TOP TO BOTTOM).
- Put thermometers in top and bottom. Checked that refrigerator cycles (not running continuously). Checked that cold air is coming down from (2) vents behind light.
OK: so far, so good. Lower compartment is 40 or under. Top is under 18.
CONCLUSION: Suspect marginal design. Had problems with another similar model where defroster ice doesn't drain correctly, pools and refreezes. Leading to blocked vents as well as blocked defroster drain and similar problem including dripping water from top to bottom and warm bottom.
MAYBE KEEPING THE FREEZER CONTROL AT WARM GETS AROUND THE PROBLEM?? ANYWAY, ITS WORKING FOR ME FOR NOW !!
Nov 12, 2007 | Frigidaire Refrigerators
Miele KFN8462S Bottom Freezer Refrigerator Logo
19 people viewed this question
Top Miele Refrigerators Experts
Starnley Johnwells
Starnley Johnwells
Oloyede Monsuru
Are you a Miele Refrigerator Expert? Answer questions, earn points and help others
