Question about DeLonghi Pinguino PACL90 Portable Air Conditioner
Delonghi smell Horrible smell from delonghiair conditioner. Smells like fuel oil or something like that, maybe more like gasoline and oil. I get a headache and sick if I stay in the room with it. Doesn't bother husband. Doesn't notice it. I think something is definitely wrong. Have you heard of this before with delonghi SAC's?
4 Suggested Answers
shastalaker7
  • 1515 Answers
SOURCE: smells like gas...!
I am not sure what the deal is, as this is a 10,000 btu air conditioning unit. No gas in this unit except for the freon gas in the system which is not harmful unless ingested? If you had it stored and it was on its side, this could cause a problem for sure. This would cause the oil and freon to mix causing a failure in the compressor, we call a burn out. The fan would blow air but not cold air and would have a terrible smell. If you have a thermometer to check the air temp. would be helpful. If it is blowing warm or room temp air, then you could have a problem with the compressor.Even though it may have worked before, by just turning it back on could have caused a failure. The only thing that would be dangerous, is a wiring problem of some kind, and I know you have smelled burning insulation. If it is cooling good, and you dont see any problems with the unit, go ahead and use it for a few days more and if the smell continues, take it down to an appliance repair shop and let them take a smell.Dono't use it at night when you are sleeping, or when you leave the house untill you know that it is ok.Wish I were there to see it for myself.
Sincerely, shastalaker7
Posted on Oct 29, 2009
SOURCE: air conditioner delonghi will not cool the room
THE RED LIGHT IS ON AND WILL NOT START?
Posted on Jun 29, 2010
  • 4736 Answers
SOURCE: I bought a used K900
arianne, either the plastic tubing to the eater collect bucket is clogged or it has become disconnected.
I suspect the tubing is clogged. To resolve this, do the following:
Remove the water collection bucket and look up inside the bucket holder cavity. You will see either a drain hole or small tubing that drains the water into the bucket. Using an appropriately sized, 18" long, plastic Zip Tie, carefully insert the tip of Zip Tie into the hole or tubing. Continue to push it in until you reach a bend in the tubing. You will need to gingerly work the Zip Tie past this bend, until it either bottoms out or you run out of usable Zip Tie. Then slowly pull the Zip Tie back out while rotating (twisting) it. This will breakup any clogs. As you reach the inserted end of the Zip Tie, be prepared, as some water may follow. Reinstall the bucket, plug the unit in and turn the Master ON/OFF Switch to ON. Allow the unit to run, while you monitor it for any leakage.
NOTE: If you don't have a Zip Tie, you may use something similar ( i.e.a long pipe cleaner), but NO wire coat hangers
I hope this helps you.
Posted on Jul 11, 2011
I have a 01 jeep cheeroke and last night the oil pressure gauge dropped to zero so i just left the truck and this am the oil is full and smells like gasoline
Gasoline in the oil would be from a faulty injector or fuel pressure regulator.
You would need to change the oil and check the fuel system for leaks before you drive it.
Mar 07, 2015 | 2001 Jeep Grand Cherokee
When fuel tank is full it smells like gasoline
Possible cracked fuel filler tube. The tube that goes from the fill hole to the gas tank is cracked.
Jan 17, 2014 | Delphi 2005 GMC Yukon XL 1500 A/C...
96 ranger oil smells like gasoline
i would change oil and filter could be dumping fuel maybe an injector
Feb 20, 2013 | 1996 Ford Ranger SuperCab
Fuel oil smell in the house
Fuel oil--- is a #2 oil & sometimes has kerosene in it also & is not like gasoline, that is combustible
Fairly safe,just smells strong
Nov 25, 2012 | Cars & Trucks
The engine oil smells like gasoline. Why is this happening and how can I fix it?
If the oil smells like the fuel then does you engine knock or lost compression? fuel can leak past the piston if the rings are bad and the vehicle doesn't start easily.
Modern synthetic oils can smell different so borrow another nose for a second opinion.
Also test the oil... put a single drop in a metal pan and throw a match at it. Oil wont ignite straight away and will burn slow only once it has reached ignition temperature, any fuel in the oil will cause an explosive flash almost immediately
Apr 06, 2012 | 1998 Isuzu Trooper
Smells like gas...!
Oct 29, 2009 | DeLonghi PAC C100 Air Conditioner
Rotten smell from my air conditioner unit
make sure your drain hose is draining, It drains all the condensation from the unit, then you will need to clean the coil(s)
Jul 30, 2009 | Sharp CV-P09FX Air Conditioner
Smells like gasoline in car when it's in idol
Check entire fuel system for leaks 99% of time wen you smell GAS.... there is a leak. So be very careful. Gasoline leaks can be very dangerous. If you had a tune up lately or changed a fuel filter that can be your problem because they are metal line then can be left loose accidentally. Check all fuel lines from fuel thank towards the engine compartment and you should be able to locate source of the smell. Good Luck and contact if you need more help. Thanks for using FIX YA
Jan 08, 2009 | 2000 Toyota Corolla
Heating & Cooling Logo
Top DeLonghi Heating & Cooling Experts
paulcarew
Donni Steen
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
