Ge spacemaker radio model 7-4220
Part of the light display is out and cannot set time. Any suggestions? Thanks.
SOURCE: complicated GE clock radio/CD player
To set the time:
Hit the SET Wake/Time Button closest to the CD player until the clock face appears in the bottom left hand of the display.
Use the TRACK Rev Search Fwd Arrows to adjust the time.
Rev will decrease by minutes and Fwd will increase by minutes.
Hope this helps.
Posted on Mar 09, 2008
SOURCE: FM/AM GE Digital clock radio model#7-4966 display bulb burned out
Geri, I recently had the same problem with my GE model 7-4966 clock radio. The radio manual states that there is a spare bulb included and stored on the underside of the battery compartment door on the bottom of the clock radio. To replace the bulb: 1. Twist the bulb bar handle on the underside of the radio to unlock and remove the holder. 2. Carefully pull the bulb out of the holder and replace with the spare bulb. 3. Place the holder back in place, twist the bar handle to the right to "lock" the bulb holder in position.
In case you can't find a spare bulb, the manual states "use only a GE259 or equivalent 6.3 volt, wedge base bulb. A clerk at Radio Shack told me she could get a replacement bulb.
Dennis60
Posted on Jul 27, 2009
  • 10865 Answers
SOURCE: I cannot set the time on my GE Spacemaker under
push the time button then set the time then push the time button a second time.
Posted on Sep 07, 2009
  • 11 Answers
SOURCE: set the time? ge model #75350.
Download the manual here:
http://www.devicemanuals.com/guide/CD%20Player/RCA/RCA-75350-User-Manual-==TVRJMk1UZ3k=.html
Or open the battery compartment on the right side and press the clock button, >> or << to set time, and press clock button again to save.
Posted on Jan 09, 2010
SOURCE: GE 7-5402 Spacemaker under counter radio - all static
fix
Posted on Feb 20, 2012
Magic chef MCD1611ST microwave, the display lights up, the time and powerlevel can be set, the light works when the door is open but when i hit start everything shuts off. Any suggestions?
There are a lot of possible causes, but I'd look at the door switches first, and the wiring connectors to them. Make sure the contacts on all the switches are opening and closing.
Nov 19, 2016 | Magic Chef MCD1611ST Microwave Oven
Why can I no longer see my mileage or electronic displays? The dash still lights up and so does the radio.
You could have damaged display. Maybe the connection. If your dash lights up I would not suspect a relay. Not a bulb either. Most likely a bad display. Try this if you can disconnect display and wait for a short time and reconnect. This may or may not work.
Apr 28, 2016 | 2005 Ford Expedition
I am trying to hook up an averkey to a laptop and TV. I have the TV set on video-1 and I have used the FN -F7 keys several times but I still do not have a picture on the TV and the red freeze light...
Check the resolution you are outputting to the TV and check the resolution the TV is set to. These must match for the TV to display properly.
I hope this helps
Aug 31, 2011 | Avermedia AVerKey 300 Gold (61K0C3BF)...
Dead Display on Xerox Phaser 6120
Did you receive any good solutions? I have a Dead Display on a Xerox Phaser 6120. Thanks!
Rick
RickHamiltonMBA@earthlink.net
Sep 11, 2009 | Xerox Phaser 7400/DXF Laser Printer
Leviton Programmable Timer 6124H-W installation problem
I Have a decora 24 hour lcd programmable timer switch 6124, when i set the timer it doesn't go on, but it goes one a 5:00 am. when there is nothing programed?
Apparently i need to set the time first and then program timer?
Can you please help. Thanks so much.
Apr 20, 2009 | Leviton 6124H 24 Hour LCD Programmable...
Smeg SUK91MFX5 oven wont heat
Reset the clock that will make the heating element work, if your clock has stopped displaying (common fault) set as per instructions but you wont be able to set at any acurate time.
Sep 16, 2008 | Smeg SUK61MFX Gas Kitchen Range
Light printing
I would suggest using the printer's menu and checking both Direct Print->Print Quality and Direct Print->Brightness as these may be set too low or too high. Change these values, 1 at a time, and do a test print to check the print density
Dec 24, 2007 | Konica Minolta magicolor 2430 DL Laser...
F9 Display in Model MGR5770ADB Gas cooking range
f-9 means you either have a bad door latch hinse the light staying on, or the ERC which is the oven control has a stuck relay and youd have to replace the ERC to fix it.
Nov 26, 2007 | Kitchen Ranges
My screen wont work!! :s
hav u dropped ur h.set ?if yes contact lg  care center. if not then take the back up of data & reset ur h.set .check display settings & try to set some theme.
Oct 21, 2007 | LG Shine KE970 Cellular Phone
Setting the right time
Check page 164 of the manual, you can set it as below:
Aug 03, 2007 | Casio Exilim EX-S500 Digital Camera
69 people viewed this question
 Grubhead
Grubhead
