Homebase 253797 Drain water pipe broke
How to remove broken off hot water tank drain nipple
You can purchase an ease out tool from Home Depot or Lowe's, It fits inside the broken pipe and when you rotate it counter clockwise it tightens inside the pipe and removes the nipple. (Be sure to check the inside pipe diameter first)
Mar 21, 2013 | Water Heaters
Whirlpool leaking water under refrigerator. It does not do it all the time. Water is apparrent when unit is defrosting.
The water should drain into a plastic container which is on top of the motor so the motor heat evaporates it away and this container is either broke or the feed pipe that runs into it is disconnected or something akin
Dec 03, 2011 | Whirlpool Refrigerators
How can i get my air conditioner to stop leaking with water
Put a hose in the drain pan whole, and fkush out the restriction. If a drain pipe is broke, or not conected, you will be able to tell then, an replace it.
Jul 04, 2010 | Heating & Cooling
My washer stopped during the spin cycle. Now I can get it to fill with water But aggitate and spin it just makes a noise and the tumbler is locked up tight
Your shaft coupler / motor coupler has likely broke. Not too hard to fix yourself, but you will have to remove the water from the washer first.
Remove the clothes, place them in the bathtub. Roll a garden hose from the washer to outside where drain water won't matter. Tape the garden hose to the drain hose, and lower the drain hose to the floor. Water will flow through the garden hose outside. Turn the washer over, follow directions supplied with new part, and replace the motor coupling. When finished, reorient the washer, remove the garden hose, place drain hose in the drain stand pipe. Run the washer through a couple of full cycles, then rewash the clothing.
Jun 11, 2010 | GE WBSR3140DW Top Load Washer
Electrolux dishwasher won't drain. Not a clog in the outlet hose or drain pipe.
The drain hose on a washing machinemag-glass_10x10.gif connects the drain pump to a stand pipe, a U-pipe under the sink, or another place for draining dirty water into the sewer. If your washer won't drain properly, the problem is sometimes an object blocking the drain hose, like a pair of underpants, a child's sock, or pieces of something that broke up in the washer.
  1. Unplug the washer and put the plug on top of the machine to keep it out of any spilled water.
  2. Step 2 Take any wet clothes out of the washer and bail the water out of the drum with the bucket. The washer may be too heavy to move if it's full of water and wet clothing.
  3. Step 3 Pull the washer out from the wall enough for you to get behind it.
  4. Step 4 Remove the plate from the back of the washer by taking out all the screws. Different brands and models of washers vary in how many screws hold on the back plate, and not all models require removing the plate to get to the pump where the hose is attached.
  5. Step 5 Locate the drain hose. Of the three hoses coming out of the back of the washer, the drain hose is the largest in diameter and is attached to a drain pipe instead of a faucet.
  6. Step 6 Check the drain hose for kinks and bends. These are often the cause of a blocked or slow-running drain hose.
  7. Step 7 Remove the drain hose from the washer by detaching it from the drain pump. You will need a screwdriver or a slide-lock wrench to open the clasp that holds the hose to the pump, depending on what type of clasp it is.
  8. Step 8 Keep the bucket nearby to catch any water that comes out of the drain pump when you remove the hose.
  9. Step 9 Remove the other end of the house from the pipe it drains into.
  10. Step 10 Bend the clothes hanger open so you can use it to poke inside the hose. Push or pull out the material that's causing the blockage.
  11. Step 11 Replace the hose and run the washer to check if it's clear.
Nov 13, 2009 | Electrolux 24 in. EDW5505EPS Stainless...
Drain Plug broke in half and is stuck
If you can not get the pice still in the header out, loosen the flanges that hold the inlet and outlet pipes enough for water to drain and then tilt the unit so the water inlet/outlet side is lower than the other side. You may want to place a block of wood under the edge to kep it this way for the winter. Be sure to also remove the pressure switch to allow that tube to drain as well.
Oct 03, 2009 | Pool & Spa
Washer won't start. water pours down sewer pipe
Hi, If the water is going out the drain hose, raise the drain hose so that its highest point is as high as the top of the washer. This should take care of the issue. If the water is coming out of the bottom of the machine, tip it back against the wall and look under the washer to see if a hose has broke or came loose.
If I can assist you further, please let me know.
Vic
Jul 18, 2009 | Roper RAS8445KQ Top Load Washer
A/C unit is working perfectly, but the past days is leaking water inside the house. Is probably the drain right?
Yes, the drain has either come loose, or clogged. Treat these as you would any plumbing problem. If the water isn't coming out at all where it normally does you can use some drain cleaner followe by plenty of water. If the line is broke you may need a 3/4 inch pvc coupling, pvc glue and a small hand saw to repair the drain pipe. There is a possibility that it is the pan has rusted through, which you would probably need help from a Pro. Good luck
Jul 13, 2009 | Heating & Cooling
Motor won't spin, with flashing "End" light and 3 beeps
this should be a blocked pump or waste pipe or pressure switch ( round grey disk with small pipe off the drum)
Aug 15, 2008 | Tricity Bendix AW1400W Front Load Washer
Heating & Cooling Logo
22 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
