Question about Fisher and Paykel Active Smart E522B Bottom Freezer Refrigerator
Beeping 17 times on e422b fisher and paykel fridge
SOURCE: Fisher Paykel Fridge Freezer
I have a Fisher and Paykel E442B upside down, which is a very similar model, and I just fixed the same problem (temperature was around -4C even though I set the fridge temperature as warm as possible).
The cause of my problem was excessive ice build up on the side of the evaporator coil (which is in the back of the freezer compartment behind the rear plastic panel). I had the same problem around a year or so ago, so I expect it to be a regular occurence. To defrost the coil, I removed all the drawers in the freezer, and the plastic insert by pulling out the bottom of the panel out and rotating it upwards until it released at the top. There are a couple of snap-in tabs holding the panel in, so with a bit of pulling they released. The tabs are either side of the slot at the bottom of the panel.
I then supported the panel horizontally on the top shelf so that I didn't have to disconnect the thermostat wire and the circulating fan wire.
52de81a.jpg With a small fan heater set on low, aimed roughly at the ice buildup on the left hand side of the evaporator coil, I defrosted the ice built up. This took around 2 hours or so. Then put it all back together and it worked fine.
I'm not sure why the ice build up on the side caused the problem, but presumably it interferes with the proper flow of cold air to the fridge compartment.
If you don't seem to have ice build up like I did, then it could be a thermostat problem, or a fan problem (a symptom of which would be fridge being colder at the bottom than at the top).
Posted on Oct 04, 2008
SOURCE: E521T fisher & paykels fridge is freezing everything
trn your thermostat right down see if that helps
Posted on Mar 31, 2009
reddyanantha
  • 205 Answers
SOURCE: I have a Fisher and Paykel E522B Fridge and the
hello sir/mam
after replacing the tempreture probe have u checked the compressor so that it should get the signals for cutt in and cutt off if not please check it.if this is not happening please change the temperature sensor.
Posted on Sep 14, 2009
Testimonial: "which temerature censor ( there are three )"
BIKER T
  • 909 Answers
SOURCE: Fisher and Paykel Freezer
Very possible the door was accidently left open for a period of time. When that happens, moisture latches on to different areas which inturn creates ice build up. In short, do a good defrost and then restart freezer again.
Posted on Oct 04, 2009
Testimonial: "Thank you. Freezer defrosted and working again!"
SOURCE: Fisher & Paykel Fridge Freezer E402B beeping when door closed
see http://www.fixya.com/support/t675116-refrig_e402bre
Posted on Oct 06, 2009
Fisher and paykel fridge beeping
The beeping is in most cases to alert you to the fact the temperature is above the safe limit.
Jul 21, 2017 | Fisher and Paykel Refrigerators
Fisher and Paykel fridge E442B Initially started beeping, and would not stop. I turned the fridge off at the wall and on again and pressed temp control, the green light has turned red. Problem?
If the warranty is still in effect, call Fisher-Paykel, and even if the warranty has expired call. Their support line has many staff who know the operation of the equipment and a warranty is not needed to get their help.
That's my tip - free
Dec 03, 2016 | Fisher and Paykel Washing Machines
Why did door alarm suddenly start going off every time I open the fridge or freezer?
Hi Christine.
When your F&P beeps, it's indicating a fault code - count the beeps which will relate to a fault code. 17 beeps would indicate an issue with the freezer fan.
Could be the reed switch (door switch).. amount of beeps will indicate the fault code.
Dec 14, 2015 | Fisher and Paykel E402BRXFDU Bottom...
Fisher Paykel RF175WDRX1. Why does the fridge beep when I open it?
check the thermostat setting for the compartment
it may not be set low enough so the alarm goes off when the compartment temperature reaches or exceeds that setting
some fridges have a system whereby if the door is open too long then it notifies the user to close the door
May 21, 2015 | Fisher Paykel RF175WDRX1 Fisher & Paykel...
Why does my fisher and paykel active smart fridge/freezer keeps beeping when I open fridge? As if the fridge has been open for a long time?
Does the beeping start immediately or does it follow the designed timing as stated on page 12 of the manual? You would have to check with the manufacturer to see if the feature can be disabled. Page 12 of Fisher Paykel Refrigeration User Guide ManualsOnline com
Mar 08, 2015 | Fisher and Paykel Refrigerators
The door alarm of my fisher and Paykel E372B fridge goes off when the door hasnt been opened for a number of hours. How can I stop this.
You would notice that when it beeps, there are a series of beeps, which relate to an error code - also, the temperature panel would be most likely flashing the same amount of times the beeping occurs. The code relates to a component failure that the active smart system is having problems with.
For example, 17 beeps would be error code 17 - which relates to the freezer fan is drawing less current than is expected. Either the wiring is open circuit or the fan is faulty.
Feb 18, 2015 | Fisher and Paykel Refrigerators
Fisher and Paykel E402B beeping, freezing symbol flashing, crisper bins freezing.
sounds like a sensor faulty will need a tech to recify the problem.
Nov 29, 2012 | Fisher and Paykel Refrigerators
Fisher & Paykel active smart fridge keeps beeping for no apparent reason, while door closed
press the select button ( the button that you choose the temperature on the fridge and freezer) and check that the fan on both fridge and freezer are working.
Nov 04, 2009 | Fisher and Paykel Active Smart® E522BR...
Fisher & Paykel Model number 402B S.Steel. Bottom frezer top Fridge.
My Fisher & Paykel Model E402B Stainless Steel Fridge/Freezer has a problem. Bottom Freezer is OK but Refrigerator will not work properly, somtimes it will freeze everything now it just warm inside i have checked the the fan and the rubber holding it up has broken also the ice is frozen in the vents can you help i got someone in to fix it but he said it will cost around $600 as there might be more wrong with it, what do you suggest thanks Clare
Jun 13, 2008 | Fisher E522BLX Stainless Steel
Fisher and Paykel Active Smart E522B Bottom Freezer Refrigerator Logo
94 people viewed this question
Top Fisher and Paykel Refrigerators Experts
Brian Coughlan
John Tripp
John Tripp
Colin Stickland
Colin Stickland
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
