Devireg 540 Hi I have moved into an apartment that has this system. I can't turn it on, how do I do this please? I have tried holding the button down for 12 seconds but nothing. What am I doing wrong? regards Maxine
  • 7,733 Answers
Hi I just moved plugged in my ps3 the red standby light came on and now nothing it won't even try to turn on what should I do ?
Sorry I had no idea you sent me this message until today. I apologize for the delay. You probably found a solution by now but if you haven't, please try this..
Solution:
  1. With the PS3 in Standby mode (Red light on), press and hold the Start button until you hear a single beep, followed by double beeps.
  2. Connect the controller using USB cable and press the PS button on the controller.
  3. Now, the system restore screen (or whatever they call it) will come up like this
  4. You have several options here for restoring the system, some will unfortunately wipe up all your data, others will make you lose the file naming.
I hope this helps :D
Oct 24, 2011 | Sony Playstation 3 (PS3) Console
Unable to set clock on pioneer super tuner IIID - tried holding down clock button but time doesn't flash. Your assistance will be appreciated thank you
To set up the clock...
Turn radio off.
Hide clock face.
Press and hold a few seconds “clock button” to bring clock face up.
Press and hold “power on button” till clock starts to blink.
The 4 buttons in a cluster on the right under audio, move the hours and minutes.
press power when done.
I hope this helps
Please rate accordingly
Thank you
Computerrep
Apr 27, 2008 | Car Audio & Video
I hae a Pro Form 540 Iteracive Trainer treadmill. When the key is inserted, the treadmill cuts on but the control panel doesn't seem to work when you touch start. I waited and cut it off and went...
I will advice you try re-calibrate your treadmill, follow the procedure below to re-calibrate it,
Step 1 Stand on the side rails of the treadmill for safety purposes. Remove the safety key. Step 2 Press and hold the two incline buttons. The incline buttons are blue and on the left side of the display. Hold the up and down button simultaneously. Release the buttons when the display reads "Calibration."
Step 3 Press the green start button located either above or below the large, red stop button (depending on your model). Stay on the side rails as the treadmill belt begins to move. Both the speed and incline should go through their full range from lowest to highest, and then back down again.
Step 4 Repeat the process if the display does not read "Calibration Successful."
Aug 08, 2011 | Sport & Outdoor - Others
Sony walkman NZ-E353 was working fine both alone and attached too a docking station. Next day it won't come on and keeps flashing "HOLD" before turing off.Battery is fully charged. Please...
I'm sorry that the Walkman Player is not turning ON normally and displaying "HOLD" message. The "HOLD" message indicates that the Walkman player is set to HOLD mode by sliding the HOLD button on the right side. Please make sure that the HOLD switch is not activated.
If the issue persists after moving it from HOLD position, please reset the Walkman player by pressing the reset button using a sharp pointed object. The reset button is located on the rear of the unit.
Thanks for understanding. Please let me know if you require any clarification.
Jul 31, 2011 | Sony NWZ-E353 MP3 Player
The child/safety lock won't release at the end of a wash cycle so I'm unable to take my clothes out of the machine. I've tried a different cycle, turning the machine off, and switching the...
Thank you for contacting fixya.com.
You did not mention the type and the brand of your washing machine. However given bellow are some options you can try.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
In Hoover washing machine try holding down the temperature and eco/rapid options together to turn off child lock. Some series use "TEMP and OPTION" at the same time.
Please get back to us if you have further query else please accept the suggestion
Jun 17, 2011 | Washing Machines
Hi everyone, I have got a panasonic KX TES824 system. The guy before me changed the default password of the system. How do i reset the password? I tried opening the box and i see two buttons. one...
First the button clear position
anfter press hold reset 20sec
it will reset
after turn off PABX
move the button to open position
and strat the PABX
Please let me know this is helpful
Jan 06, 2011 | Panasonic KX-T7730 Corded Phone
Replacing the element in a NEFF U1721 but having trouble
To rtemove the nut, hold the fan blades,and at the same time undo the securing nut clockwise as though you were tightening it, as it is a left hand thread, and vice versa for tighteming it again
Please rate mhy solution.
Thankyou..
Jan 15, 2010 | Neff U1721 Double circotherm Electric Oven
No sound is coming from the speakers
hi , perhaps during the move your Speakers were damaged and a wire or fuse came lose, i suggest taking it into the shop and having them repair it otherwise you can , but u suffer from losing the warranty, hope this helps bud :)
Dec 06, 2009 | Logitech X-540 Computer Speakers
The "home" button on my PSP does not work
I have the same problem.. I cant put YES on home and my R button isnt working either.. but I've noticed that if I push down the power button to the HOLD lvl and then put it again to the medium lvl it works like the R button -_-'' ..
Jan 06, 2008 | Sony PlayStation Portable (PSP) Console
Computers & Internet Logo
137 people viewed this question
David Payne
David Payne
