Question about Refrigerators
Model 106 52554100
Can we replace the thermostat?
  • 1 more comment
  • Les G Busch Jul 17, 2013
    The refrigerator continues to freeze the food no matter if we have it set to the lowest setting on the panel for both the freezer and the refrigerator.
  • John Tripp
    John Tripp Jul 21, 2013
    I usally get an email telling me when someone responds but I did not this time. Would you still like my assistance? JT
  • John Tripp
    Your model has a 2216112 Damper Control Assembly that you need to see if t is opening and closing properly. The thermisters I talked about before are what tells the control board to open this damper when it needs colder air from the freezer and close when it gets just right. Sometimes frost will cause the damper to stick open, somewtimes the termister is bad and sometimes the damper or the control board is defective. http://www.repairclinic.com/PartDetail/D...
  • Refrigerators Master
  • 4,654 Answers
Your model does not have the typical thermostat that many refrigerators have. Yours has something called a thermistor
to measure the temperature by changes of resistance and signaling the measurement electrically back to a computer located in the control panel inside the fresh food compartment. Your model has the=> 2188819 Thermistor You can test the thermisters with an OHM meter to see if they are working properly. Can you tell me the symptoms your refrigerator is having so I can help you repair or replace the needed parts? Thanks Sea Breeze
10652554100 Kenmore Parts
Posted on Jul 16, 2013
My Honeywell thermostat shows an error 91 what is that code and can it be repaired
The codes are differernt for each model. You didn't post the model #. However, Code 91 usually means a thermostat fault. Which means either the thermostat needs to be replaced, or there is loose wiring at the thermostat.
Nov 04, 2014 | Heating & Cooling
Need to know how to replace the thermostat on a 1996 buick century wagon 3.1 6 cylinder engine
Trace the upper radiator hose to the mounting area on the intake manifold. Loosen the hose clamp on the manifold end of the hose and remove the hose. Pull the thermostat out of the intake manifold.
For more help and troubleshooting go through the help links below:---
Click the link below:-----
THERMOSTAT REMOVAL PROCEDURE/LOCATION DETAILS
Where is Thermostat Located on Saturn
http://technoanswers.blogspot.com/2012/11/where-is-thermostat-located-on-saturn.html
2004 Dodge Intrepid: How to replace Thermostat?
http://schematicsdiagram.blogspot.in/2012/06/2004-dodge-intrepid-how-to-replace.html
How to Replace Thermostat on Audi A4?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-thermostat-on-audi-a4.html
How to replace Thermostat on Acura Car models?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-thermostat-on-acura-car.html
Where is thermostat located on 2006 dodge magnum 3.5L?//
http://repairhelpcenter.blogspot.com/2011/10/where-is-thermostat-located-on-2006.html
Thermostat on AUDI 1.9 TDI?
http://repairhelpcenter.blogspot.com/2011/10/thermostat-on-audi-19-tdi.html
How to replace Radiator on Audi and VW car models?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-radiator-on-audi-and-vw.html
How to Replace a Thermostat.
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-thermostat.html
How to locate Thermostat on Any car model?
http://schematicsdiagram.blogspot.com/2011/12/how-to-locate-thermostat-on-any-car.html
Where is thermostat on Audi A6?
http://technoanswers.blogspot.com/2011/12/where-is-thermostat-on-audi-a6.html
How to replace thermostat on 1992 Buick century?
http://technoanswers.blogspot.com/2011/12/how-to-replace-thermostat-on-1992-buick.html
Replacing thermostat on 1999 Mercury Cougar?
http://technoanswers.blogspot.com/2011/12/replacing-thermostat-on-1999-mercury.html
Thermostat Replacement on Toyota Corolla?
http://technoanswers.blogspot.com/2011/12/thermostat-replacement-on-toyota.html
Where is thermostat located on 2005 Dodge neon?
http://schematicsdiagram.blogspot.in/2012/02/where-is-thermostat-located-on-2005.html
These will help.
Thanks.
Nov 28, 2012 | Buick Century Cars & Trucks
Thermostat controls
Just replace the thermostat. They are cheap and generally very easy to change. Look on youtube or google for your model of vehicle followed by thermostat replacement.
Nov 06, 2012 | Cars & Trucks
Water not getting hot enough -- water heater is turned up to 130 plus model KUDC02IRBL0
Hi.
Check the operations of the High limit Thermostat
The thermostat is installed in line between control board and element. If water is cold read impedance at thermostat's terminal. A good high limit switch must read a couple of Ohms or zero. If it reads infinity then the thermostat must be replaced. If the thermostat returns low impedance it may still be defective opening too soon.
If replacing the thermostat does not do the job, check pressure switch operation (that determines water level) and control board.
Here all parts and diagrams for your model.
Regards.
Ginko
Sep 07, 2011 | KitchenAid Dishwashers
Water was much hotter this morning, actually steaming when faucet turned to max. I checked thermostat & reset button, seemed to be normal. I shut off power and pushed reset button, waiting for it to...
I would try it again and if water temp is still to high then I would adjust thermostat down to say 120 degrees and see what that does.If problem continues I would replace thermostat. Thank you
Dec 20, 2010 | Reliance & 50gal Electric Water Heater
Thermostat for Nissan Pulsar 1992 Model
STANT REVERSE POPPET SERIES THERMOSTAT -- 195%XB0 F, A Direct Fit OE Replacement Engine Coolant Thermostat,
Thank you for using FixYa , Lee
Feb 22, 2010 | 1990 Nissan Pulsar
The heater runs and doesn't want to shut itsself off
check the wire to the thermometor then if the wire is ok replace the thermostat
Mar 03, 2009 | Honeywell Programmable Thermostat Heater
Fixing thermostat on oIder Hotpoint Double Oven
Hello, there is no fixing the thermostat although some of the older thermostats could be calibrated by using a very small flat head screwdriver in the shaft of the thermostat if there is no opening for a tiny screwdriver in the shaft then it cannot be calibrated. If you have to change the thermostat contact your local parts department have the model # handy if the original is not available ask about universal oven control replacement parts. Good Luck
Dec 21, 2008 | Zanussi ZDQ895 Electric Double Oven
Refrigerators Logo
80 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
