Whirlpool lsr7233e my washer stopped spinning.
3 Suggested Answers
  • 351 Answers
SOURCE: whirlpool super capacity washer spin cycle stop working
Sounds like you need a new lid switch. Click HERE for prices.
Posted on Apr 19, 2009
Maytag317
  • 1136 Answers
SOURCE: washer wont spin at end of cycle
Hi, it sounds like the coupler or lid switch is bad. Do you hear the motor running during these cycles?
If you do, the coupler has gone bad. Here are the instruction on how to change the coupler. Part# 285852
Normal 0 Removing the cabinet. UNPLUG the washer. There are two screws holding the control panel to the cabinet. Most models the screw are in front but, some models have the screws in back. They are on each end. Now raise the control panel up and let it rest on the hinges. Unplug the lid switch harness and locate the clips on each side (bronze in color) and release them.
Now the cabinet will lift off the frame and you can set it aside.
Normal 0 How to replace a coupler.
Now that the cabinet is out of the way, remove the pump from the motor and set the pump off to the side. Remove the two screws holding the clips on the motor and remove the clips. Unplug the motor harness and on some models you wil need to unplug the capacitor.
Now you will need to replace all three parts to the coupler. I use a ½” socket and a small hammer to force the coupler onto the motor and transmission shafts. Put the rubber part onto the coupler half on the transmission and then line up the post on the motor shaft with the holes on the rubber part and it should go on ok. Put the clips that hold the motor in place and plug in the harnesses.
Put the pump back on and the clips to hold it in place. Set the cabinet back on the frame. Make sure the lip on the front cabinet is under the front rail of the frame. Ease the cabinet on the frame making sure the two rear sides of the cabinet set down on the tabs of the frame.
Put the two clips back on that hold the cabinet and plug the lid switch back in. Fasten the control panel down and you are all set.
I know this is lengthy but I hope it helps. Please let me know if I can assist you further.
Thanks
Vic
Posted on May 25, 2009
Whirlpool cabrio washing machine doesn't spin
Try to turn the drum by hand, if it hard to turn, there may be something stuck underneath spin basket. If it does turn freely but makes a loud growling sound, you probably have a bad bearing. You should notice black oil and water mixture at bottom of washer, on the rotor. It will usually throw a f51 error code. This unit has service bulletin on this problem.
Apr 05, 2014 | Whirlpool WTW6400SW Cabrio Washer
I have a whirlpool wfs1072Aw 7.5kg washer that has stopped spinning and won't start even the wash cycle
You probably have either a bad gearcase, timer, or lid switch. Defective motor is also possible.
May 08, 2012 | Whirlpool Washing Machines
Whirlpool type 111 model LSQ9200LQ3 washer not
I have a whirpool model:lsq9200lq3, and recently it has stopped working. when ever you turn it on, its fine and the water fills up normally and right before it gets to the spinning cycle the machine makes a grinding noise like if something is stopping the motor from spinning, and it dosent spin inside the washer. if anybody has any suggestion It would be great thank you.
Jan 30, 2010 | Whirlpool Washing Machines
Whirlpool washer will not spin
sounds like the timer is shot.
Apr 30, 2009 | Whirlpool Washing Machines
Whirlpool super capacity washer spin cycle stop working
Apr 19, 2009 | Maytag HAV2558 Top Load Washer
After spin cycle washer stops abrubtly causing it to shift.
You have dragging brake shoes. This will cause the motor to draw excessive current. Nedd to take apart and pull down spin tube to access the brake shoes
May 31, 2007 | Whirlpool LSQ9600L Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
