Question about Kenneth Cole Unlisted Ana-Digi watch
Ul5108kcp how to set digital time
How do I set the right time on my Casio 5208 aq-s800w watch
All you have to do is to set the digital time.After pressing the upper left button for 2-3 seconds the display digits start to flash.By pressing lower left button (MODE) once at a time and by using the left side buttons, you can set the right time,date etc.When finished press upper left button again to complete setting.Automatically the hour and minute hands will be set to the correct time following the digital time.
Mar 19, 2016 | Casio Watches
How to set digital part of the watch
[PDF]4 Button Digital Watch - Dakota Watch
https://www.dakotawatch.com/PDF_FILES/Digital.pdf
In normal time mode, Hold L2 for 2 seconds to alarm time set mode, then L2 again to normal time set mode, the second digits begin flashing. Press R2 to reset the seconds to "00", press R1 to switch to the minute digits. Press R2 to advance the minutes. Press R1 to switch to the hour digits.
how to set time in digital watch - YouTube
? 1:13
https://www.youtube.com/watch?v=4FmHYMeXbDA
Oct 26, 2011 - Uploaded by Vedant Sen
https://www.youtube.com/watch?v=u_H5I3H15R8 ... how to setyour digital watch {UPDATED} - Duration: 1:20. by Vedant Sen 3,424 views ... The 10 Greatest Wrist Watches of all Time REVISED FOR 2014 - Part 1 - Duration: ...
How To Change The Time On Most Digital Watches - YouTube
? 8:40
https://www.youtube.com/watch?v=kBvaePDtEUU
Jun 27, 2012 - Uploaded by Pitskate
How To Change The Time On Most Digital Watches. Pitskate ...How to change / set time on Armitron watch, 45/7004. - Duration: 2:02. by ...
Jan 05, 2016 | Watches
Waveceptor 3310 Frozen "H-S ET"
You must set the digital time as well.Analog time (hands) follows digital time.At first press button A.If digital time is according to analog time ok.If not you have to follow "H SET" (hour setting) procedure.
May 01, 2014 | Casio Watches
Please can u show me how to change the time on this watch.
Set the time on your Baby G by switching to time mode. The button on the bottom left-hand side of the watch is the mode button. Pressing it once to will set the watch to time mode. The time digits will begin to flash.
  • 2Start by adjusting the seconds. Press the button on the top-right side of the watch once. The second digits will start to flash. Press the bottom right-hand button until the correct second time is displayed. Hold down the button to cycle through the digits. Once the correct time is displayed, press the bottom left-hand button and the digits will stop flashing. Press the bottom left-hand button again to set the hours.
  • Sponsored Links
  • 3Follow the same procedure to change the hours setting. Set the time and date by cycling through the digits in the following sequence: seconds, hours, minutes, year, month and date.
  • 4Press the bottom right-hand button to set the seconds to 00. When the second display is between 1 and 29, the digits will change to 00. If the display is between 30 and 59 seconds, the seconds will revert to 00 and one minute will be added to the minutes display.
  • 5Change from an a.m. to a p.m. setting by pressing the button in the middle of the bottom of the watch when any of the time display digits are flashing.
  • Nov 03, 2012 | Watches
    Set time1440sports
    Buttons are numbered as followed:
    Start/Stop is button 1
    Lap/Rst is button 2
    Indiglo is button 3
    Mode is button 4
    a) Press 4 to select "TIME" mode
    b) Press 2 and hold for 2 sec to select "SET" mode, second digits blink.
    c) Press 1 to reset digits to 00.
    d) Press 4. Minute digits blink
    e) Press 1 to set minutes.
    f) Press 4. Hour digits blink.
    g) Press 1 to set hours.
    h) Follow same patter to set day of month, month, etc...
    i) Press 2 at any time to retain set values and exit procedure
    Nov 16, 2011 | Watches
    How to set the time for casio aw-591(4778) details about mode,adjust ,reverse and forward
    press and hold adjust button until digits flash (the digit that flashing is changeable by reverse and forward) mode is to choose what you are about to change. if your done with the digital time, press adjust once. for analogue time: press mode button until it reaches the word "H.SET" press and hold the adjust button then the word H.SET replaced by the time that you had been set for the digital time. then you can now use the reverse or forward to set the analogue time. if your done press the adjust button once then the mode button once. i hope i had been helped you.
    Sep 08, 2011 | Casio Gshock G Shock Analog Digital New...
    How to set the time and analog time of CASIO ILLUMINATOR0 SGW 400 h
    set the digital time: press and hold upper left button, then the seconds blinks use the lower left button to choose what are you going to set ( the one that blinks is the one that can be set ), use the upper right button to set. when your done. press the upper left button once.; set the analog time: from the time mode of the digital press mode until you see the "H.SET" , then the time of the digital appears, then use the upper right button to set the analog time, when your done just press the upper left button once and use the lower left button to bring back the time mode. i hope this will help you a lot.
    Aug 13, 2011 | Watches
    How to set the hands to match the correct digital display on my Casio wave ceptor 2734 wva-104h watch
    Setting Digital Time
    1. The digital timepiece on a watch is set using the function buttons on the outer part of the watch face. To set the digital time, press and hold the upper left button until the seconds starts blinking. Press the lower right button to reset the seconds to "00."
      Push the lower left button to move to the Daylight Savings Time portion of the watch. Use the lower right button to toggle between "On" and "OFF."
      Press the lower left button twice. The hours unit will start blinking. To advance the hour, press the lower right button repeatedly until the correct hour is displayed. If you need to move the hours unit backwards, press the middle right button until the correct hour is displayed. When the hour is set, press the lower left button to switch to minutes, and use the same commands to change the minutes unit.
      After the time is set, press the upper left button to exit the digital time setting function.
    2. Setting Analog Time
    3. You may find after setting the digital timepiece that the analog display does not match. When this occurs, you need to set the analog time. To set the analog time, press the lower left button 6 times. Next, press and hold the upper left button until the digital time starts to blink. This indicates that you are in analog time setting mode.
      Analog time adjustment is completed using the lower right button. Every time you press the button, the analog time will advance 20 seconds. If you need to make a big change to the analog time, press and hold the lower right button to make the hands move faster. Once the analog time is set, press the upper left button to exit the analog time setting mode.
    Aug 21, 2010 | Casio Watches
    Unable to set time
    The time on this watch is set by changing the digital display time then transferring the digital time to the hands.
    1 - Turn the crown until the mode hand points to the time mode [TME].
    2 - Press either button (A) or (B) to select the city for which the time is to be set.
    3 - Pull the crown out to the second click (3) to enter time setting mode.
    4 - Pressing button (A) will change the digits to be set. These digits are the ones that are blinking. Press button (A) to select the digits that you want to change.
    When button (B) is pressed in the [SMT] daylight savings time correction mode, DST can be turned ON or OFF.
    When button (B) is pressed with the seconds digits blinking, the seconds will return to "00".
    5 - Turn the crown clockwise to advance the hours or minutes when those digits are blinking.
    Although the crown may be turned in either direction, you should always turn it clockwise to the final setting.
    6 - When the 12H/24H selection is blinking, pressing button (B) will turn it On/Off.
    7 - After correcting the time on the digital displays, push the crown in to normal position (1) to complete time setting.
    i think this may solve ur problem
    thank u.................
    Jul 29, 2009 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
    Changing the hand time only w/o changing the digital time
    For Casio Waveceptor:
    --- A
    ( ) Button Reference
    --- B
    Set in correct order:
    1) Hand Home Position
    2) Digital Time Set
    1) Hand Home Position:
    Press and hold A and B for 5 seconds, Press A to move Second Hand to 12: position: (if not there). Press B to enter Hour/Min set mode. Press A to move both hands to 12: position. Hold A to move hands fast, Press A again to stop hands. All 3 hands are now at 12' oclock.
    Press B to exit Hand Home Position mode and enter Timekeeping Mode.
    2) Digital Time Set: (hands will self set when done)
    Press and hold B for 5 seconds to enter setting mode.
    Press A to advance current item or scroll through choices. Press B to set item and advance to next item.
    <Order of Items to Set>
    GMT Differential -> Daylight Savings auto/on/off -> Seconds -> Hour -> Minutes -> Year -> Month -> Day -> Day of week language -> Auto receive -> (back to Timekeeping Mode).
    <Setting each Item>
    GMT Differential: Press A untill your time zone is reached (E=eastern, C=central, M=mountain, P=pacific). Press B to set (advances to next item).
    Daylight Savings: Press A untill desired DST mode is reached: ("At" auto, "On" after spring change, "Of" after fall change) Press B to set (advances to next item).
    Repeat to set: Seconds (resets to :00), Hour, Minutes, Year, Month, Day, Day of Week Language, and Auto Receive (on/off).
    For each item, Press A to advance, and B to set.
    Pressing B to set last item exits Setting Mode and enters Timekeeping Mode. Hands advance to current time.
    Good luck,
    Techjoel
    May 10, 2009 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
    Kenneth Cole Unlisted Ana-Digi watch Logo
    42 people viewed this question
    Top Kenneth Cole Watches Experts
    Jimmy Accardi
    Ansel Alberto
    Ansel Alberto
    Are you a Kenneth Cole Watch Expert? Answer questions, earn points and help others
