GTUP270EMWW lid wont lock
My washer will not fully spin and this might be due to the lid not locking
hotuna
  • 288 Answers
SOURCE: washer will not spin
I'm having a little trouble understanding the question because of the spelling, but this sounds like a typical lid switch not making contact either by the depressor on the lit itself or the switch is broken. try depressing the switch with a screwdriver and see what happens. The lid switch will be in a little slot in the top inside where the lid closes.
Posted on Dec 18, 2007
aborcass
  • 2651 Answers
SOURCE: The lid will not lock.
you cant bypass this switch by pushing w/ screwdriver. its a magnetic reed switch open the top deck (3 screws behind the console) inside should be a tech ref sheet quite helpful trouble shoooter in ther
Posted on Feb 22, 2008
SOURCE: oasis elite washer lid locking mechanism broken
go to repairclinic.com to find the part. Have the make and model ready, and you have a good chance of finding the part there.
Posted on Mar 02, 2008
  • 5 Answers
SOURCE: washer won't drain
http://www.instructables.com/id/GE-Adora-Lint-Filter-Cleanout/?download=pdf
Had the same problem, this fixed it!
Posted on Oct 31, 2008
ginko
  • 19396 Answers
SOURCE: the lid will not lock, therefore the washer will
Hi.
Replace the door lock.
If the door lock is not at fault, then replace wiring harness between door latch and control board.
Enter model number here to find parts and diagrams.
Posted on Nov 14, 2009
THE DOOR WON'T LOCK THEREFORE THE MACHINE WONT START
Washer Door or Lid Won't Lock - Repair Parts - RepairClinic ...
www.repairclinic.com/...Washing-Machine/...---/Washer-door-or-lid-wo...
Most Frequent Causes for Washer door or lid won't lock. For the most ... Once thewasher door is closed, the washer can begin operating. If the door lock is ...
Door makes clicking noise and won't lock or start - Kenmore ...
https://www.ifixit.com/.../Door+makes+clicking+noise+and+won't+l...
iFixitOct 30, 2013 - Door or Lid Latch Assembly If the washer lid or door won't lock thelock and ... The Kenmore Elite HE3 is a washing machine by Kenmore.
Front Load GE washer won't lock / start. ' ShopYourWay
www.shopyourway.com > Manage My Life > Questions
Front Load GE washer won't lock / start. ... Based on your symptom and details it could have a faulty door lock assembly ... GE Washing Machines 3.8 cu. ft.
Washer Won't Spin or Agitate? Washer Door Latch ...
Dec 13, 2015 | Washing Machines
My whirlpool duet stacking washer wont spin or drain. i tried to do it manually as described in my owners manual with no luck
Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and
Drive Belt If the washer won't spin or agitate, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly.
Drive Motor If the washer won't spin or agitate the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged, replace it.
Stator Assembly If the washer won't spin or agitate the stator assembly might be burned out. The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Transmission or clutch assembly not engaging due to going out or slipping.
Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't spin or agitate the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin or agitate the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Oct 12, 2014 | Whirlpool duet Washing Machines
My Amana NTW4600YQ fills but wont wash
No agitation or spin? try these:
Jul 12, 2014 | Amana NTW4600YQ NTW4600YQ 3.4 cu. ft. Top...
Amana washer lid lock wont quit blinking
Your washer lid lock button is locked and lid was not put down before it locked, which is why the light is flashing. Therefore, push the "START" button until you see the lid lock button is off (Approx 3 seconds). Once it is off, then you can put the lid down and push the start button again, which will lock the lid into place. The washer will NOT drain or wash or spin unless the lid itself is in the locked position. If you were able to get the lid down and locked and it still doesn't work, then you need a technician to replace a wiring harness. However, you mentioned that the lid lock button was flashing, therefore, it stands to reason that your lid is NOT locked down.
Apr 13, 2014 | Amana NTW4700YQ Top Load Washer NTW4700YQ
Lid is not locking properly, washer sensor is overfilling, and the washer wont spin
Check door switch: If the lid switch is bad it will not drain or spin. Try this test: With lid open let it finish wash cycle. Press lid switch down with screwdriver. Washer should begin draining. Release switch. Motor should stop. Press switch a second time. Washer should start spinning as it continues to drain. If motor doesn't come on while lid switch is pressed, replace the switch. OR
http://www.youtube.com/watch?v=q942xn_2VXY
Pl click if helped.
Apr 28, 2013 | Whirlpool WTW4950XW Washer
Aquasmart lid
Is the lid lock tang on lid broken.
2.9 Lid Lock
The Phase 7 Washer uses the same lid lock that is used on
the Phase 6 series 11 & 12 machines. The difference being is that the lid is now locked for the entire cycle. When the lid is locked the Lid Locked LED will illuminate. Once the spin
has completed, the lock will release and the lid can be
opened. To open the lid during the cycle the
START/PAUSE button must be pressed, the machine will
come to a halt, and the lid locked LED will extinguish.
If the lid is left open, the machine will be unable to lock the lid
and the cycle will be halted. The machine will play a tune
and the lid lock will flash until the lid is closed and START/PAUSE is pressed.
• If the lid-lock fails in the closed position, the locked lid can be forced upwards and out of the
lock. Note: This is the only time in which we would recommend doing this.
• If the harness is damaged, the complete lid lock assembly will need to be replaced.
If the power supply is cut during the spin cycle, the machine will keep the lid locked until the rotor has ceased to turn (3 to 10 secs). Only then will it release the lock. The motor is acting like a generator and allows the lock to stay energized under the bowls inertia.
Mar 16, 2013 | Fisher Paykel EcoSmart GWL15
I have a FEX831FS4 washer/dryer. The washing machine will wash and spin, but will not rinse and spin. Lid is locked.
think ur voltage is too low..usually frigidaire brand washer is 220v,..usually starting of spinning has a high ampere and it need a high volt electrical supply..try to check ur main breaker for washer only..ur lid lock will lock after 10secs when it spin fast...
Dec 02, 2012 | Washing Machines
My Roper Washer RTW43405Q0 won't spin.
For the washer to operate the lid must be fully closed, the timer must be pulled out, and the water must be drained.
The main causes for not spinning are:
  • Lid partially or completely open
  • Lid or other object has hit the timer knob and turned the washer off
  • Lid not locked (by the way, not on all washers) and may be not draining.
    Make sure the lid is completely closed. Make sure that no clothing is in the lid area.
    Make sure the Timer knob is pulled out.
    The lid must be closed and locked for the washer to operate. Once the lid is closed, make sure the desired cycle is still selected and then press the Start button and listen for the lid to lock.
    Make sure there are no loose metal objects such as coins and paper clips in the lid opening area. Metal objects can prevent magnetic switches from reacting correctly when the lid is closed.
    If the washer has not drained, it will not go into spin.
    Hope this works.....
    May 01, 2010 | Roper RTW4300SQ Top Load Washer
    Washing Machines Logo
    88 people viewed this question
    Top Washing Machines Experts
