Sony bravia kdl 37v4000 no picture
We have sound but no picture - just a white screen. don't know what happened before it went "dead" wasn't in the room.
vinnyq
  • 157 Answers
SOURCE: sony bravia kdl-52w3000, turn tv on, no picture or
Most likely this is caused by a defective main board. Changing the main board will fix the issue about 95% of the time.
To be absolutely sure, the voltages need to be checked on the power supply. If they are not the values listed in the service manual, then you should replace the power supply instead (accounts for the other 5% of the time).
Posted on Oct 07, 2009
  • 148 Answers
SOURCE: 2 years old Sony Bravia KDL-52W3000 flat screen- I
The caps (capacitors) in the powerboard are going out. This is a very common problem in all class and price ranges of modern lcd and plasma tv's/ monitor's. I don't know if this problem has been like this for awhile or it just started, but either way, if the tv takes an abnormal amount of time to "warm" up then it most likely will go out all the way sometime in the (near) future. If you have a tiny bit of will and knowledge ypou can open the unit and get to the print board. Examine this for "popped" capacitors, they will have a buldging top instead of a flat one. Im gonna try to include a pic of them here, if i can get it this time, I've tried bfore lol. But you can google image a "popped" or "bad" capacitor and you would be able, with ease, to diagnose if you have any of these. Usually only one or two. Radioshack sells capacitors (couple anyway) for $1.59 each. MAKE SURE the replacement is of the SAME voltage or HIGHER, or you will be right back replacing those 2. Every capacitor has a negative pole marked with an (-) on the side of the capacitor(by one of the "legs", always puit the negative (-) "leg" of the new capacitor in the same hole in the printboard as where the previous negative (-) "leg" of the capacitor was ( a capacitor with the negative and positive "legs" put in backwards will result in the new piece "popping" as sson as you turn it on!!) make sure the "uf" rating (for example the most common popped capacitor is the 1000 uf) is the same as the one you are replacing. I needed 1000 uf, 105 c and 26v (volt) ratings for the 1 capacitor I needed to replace to fix my LG 19" lcd panel monitor I found by the trash that the light came on off, but it didn't come on. I replaced that capacitor with ; 1000uf, 85 c and 36 v (volts0...It works fine eventhough the volts and the temperature rating (36v and 85c) was not the same as the (26v(volt) and 105c ) capacitor I removed !! Further, I've replaced capacitors that had the celcius rating of 105 with the only ones Radioshack had, namely 85 c(celsius) they have been working great, but I'm not sure about any effect, nor have I heard or read (yet?) about that making an urgent difference. Many threads that I've read people have done the same, so we should be ok (my stuff has been running good for a while longer then most brand new ones!.............(all these ratings ; 'uf ' and 'c' etc are on the side of the capacitor you are replacing and on the side of the ones you are replacing them with)...For all this all you need is the cheapest solder gun u can find (I bought one for $7.99 at Radioshack), a camera (to take pictures as you go to remember how to reassemble the unit) and, once you have your materials, 20 minutes to replace 2 or 3 capacitors and you are good to go...Most monitors and tvs (lcd/plasma) I've seen you have to lay flat on the ground/bed/blanket etc, to work on (screen side down). Usually there are 2 or 3 screws (or a few more) to remove, then you will have to carefully (its comes off easily most times)insert a flat screwdriver inbetween the casing and gently pry it up as you go around the whole frame. Sometimes you have to remove the little washer arouind the cable input orso, just be gentle and you cant go wrong. Once insidet here will be a box with wires running to the sides etc...unplug, gently, these wires and open the box. Inside you will find 2 or 3 circuitboards, check them all for "popped" capacitors, replace, reassemble and plug it in....Have fun becoming an overnight tv mechanic lol! ..Here is a picture of what you are looking for inside the tv...I hope this helped, if it did (or not)please rate, thank you!9441f5a.jpg
Posted on Feb 03, 2010
tvhelp-Dave
  • 178 Answers
SOURCE: Bravia KDL-46VL130 TV: Our Sony KDL-46VL130 picture is streaking and some...
That symptom may cause by the main board or t-con board, I suggest you do software up grade first.
Posted on May 07, 2010
SOURCE: sony bravia kdl 46s4100 no picture
it sounds like your back light might be going out. You might be able to fix this by installing a new backlight inverter board.
Posted on Aug 05, 2010
SOURCE: Sony Bravia KDL-46S4100, No Picture
I have a sony bravia kdl 40v 5100 for less than two years and i did not purchased an extended warranty and now my tv is down.
I have no picture, no sound just a black screen when i turn the power on, the power (green) light is lite up and the tv turns off by itself for like less than 30 seconds. I have tried to press as many buttons on the remote control and on the side of the TV to get any message but nothing seem to happen. Any suggestions and solutions? Thanks
Posted on Aug 30, 2011
Where is the reset button on a sony 37v4000
There is no such button marked as Reset; to modern LCD TVs, like traditional ones. To reset it to factory settings, you should enter its Service Mode option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Sep 13, 2014 | Sony Bravia KDL-37V4000 37 in. LCD TV
KDL 37V4000 picture fault.
Sounds like T'Con fault. Contact the authorized service center for Sony. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
Apr 16, 2014 | Sony Bravia KDL-37V4000 37 in. LCD TV
Hi we have a 3 year old sony bravia kdl-37v4000, when we switch it on the green light flashes and a clicking noise can be heard coming from inside the set, allso when we turne the set back on from sta
Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1100 posts to different brand TVs now. Pull up older posts there.
Oct 30, 2012 | Sony Bravia KDL-37V4000 37 in. LCD TV
Sony Tv Bravia won't switch on for days, when on only white light and sound no pictures. Help
I think fault is in electrolyte capacitor.You should check the supply volt of cathode & all relative component of RGB input.
Jan 12, 2012 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Black screen w/ my sony bravia KDL-40V4100 and it will turn on, but there is no picture or sound. I was told it could be a possible issue w/ the kdl 40s4100 board, but I'm not entirely sure. I've...
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Apr 10, 2017 | Sony Bravia KDL-40S4100 40 in. LCD TV
I laid my sony bravia lcd tv kdl 26s3000 down on the ground while it was on and now the screen has gone white and there no picture, but i can still hear sound, what has happened and how can i fix it ?
You will need to take covers off and physically check all cables and connectors see if any were dislodged. Pay attention to the ones that go to the lcd panel itself
Jan 07, 2010 | Sony Bravia KDL-26S3000 Television
Sony BRAVIA KDL-52W3000
I would take that puppy back to store and get exchanged out. According to lemon law. Let me know what happens. Thank you Jay.
Jan 31, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
