Kodak EASYSHARE 5100 All-In-One Printer Logo
Posted on Mar 29, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Printer will print pictures, but won't print documents.
When I try to print documents, hardly any ink at all shows up on paper and I just put in new cartridges. I cleaned print head and calibrated it, but nothing changed.
Anonymous
Level 2:
Scholar:
  • Expert 95 Answers
  • Posted on Mar 29, 2009
Anonymous
Expert
Level 2:
Scholar:
Answers
95
Questions
0
Helped
50283
Points
287
Sometimes this happens because the ink dries in the print head. If multiple cleaning doesn't improve it you can try cleaning the print head itself with alcohol or an electronic spay can type cleaner. This should fix the problem for you. Also resetting the cartridges in the slots sometimes improves the ink flow.
Hp 2280 wont print says no paper or ink
Start by uninstalling the printer software... then re-install the newest software from the HP website. Always works for me...
2answers
Installed new printhead,took new ink I had just put in old printhead and put it back in new printhead. Will print nothing.just spits put blank 4x6 photo paper it says to load in to get calibration.Then it...
The document specs of your printer is given below:
Document & Media Handling Max Original Size Legal (8.5 in x 14 in) Original Type Sheets Min Copy Size 3.5 in x 5 in Max Copy Size Legal (8.5 in x 14 in) Standard Media Capacity 100 sheets Output Trays Capacity 50 sheets Document & Media Handling Details Input tray - 100 sheets size: 3.5 in x 5 in - Legal (8.5 in x 14 in) ¦ Output tray - 50 sheets size: 3.5 in x 5 in - Legal (8.5 in x 14 in) ¦ ADF - 3.94 in x 5.9 in I would rather suggest to take a print in normal A4 size plain paper and see what you get. Please revert back Suspected 1) paper scanner faulty not able to judge paper.
The black ink is NOT showing empty but it will not print
Firstly two things here assuming everything is fine with your printer.
Firstly have you changed the options in the document or picture youre trying to print? For example, if printing a document from Word, go to printing options and click advanced then print in 'black/white' rather than 'color'.
Secondly when you installed the ink cartridge in the printer, have you removed the plastic/paper sticker attached which protects the circuits and ink leakages?
good luck,
kc
I put new ink cartridges in my hp 2575 about ~six months ago and hadn't used the printer since then. I tried to print and it goes through the motion of printing but nothing shows up on the page. The...
The Ink at the head of your Printer Cartridges has dried up.
Try this:
Load some plain paper in the printer
Remove the cartridges from the printer and carefully dab the print heads of the cartridges with a damp paper towel. ( when you start to see ink, the ink is starting to flow).
Replace the cartridges into the printer.
Go to:
Start
Control Panel
Printers
RIGHT click on this printer
choose Printing preferences
services
clean print cartridges 9some papers may print)
follow the instructions and do the heavier cleaning as well
Run the calibration function and allow the paper to print.
2answers
PUT IN NEW INK CARTRIDGES BUT COPIES STILL BLANK AND PRINTING EVEN CHANGING ALL SETTINGS
how did the paper exit inot your pritner? Its act like printing or its fast and smooth? If its act like printing you just need to clean the printhead or if cleaning printhead did not solve the issue you need a printhead replacement, Now if the paper exit in your printer fast and smooth you need to replace the printer and the printhead., You need to call kodak for support toll free 1 800 421 6699 ext 05., The troubleshooting may apply also for blank documents using word or any other application.,
Color ink for ip1000 does not flow..??
Now put out u color cartridge and take one tissue paper or toilet paper then put ink color head to paper(soft pressure).after that see u paper are inside show three color appear in paper????(red,yellow and blue).if all have means you cartridge ok if only same or no any coming out means u color ink problem need to replaced new unit.
if got all color out better u open u printer body and check are all cable u plug in back is correct or wrong position??.second u can try go to printer preferences go to find print out in color or in gray-color and change their setting to print out in color
Having difficulty on printing documents by using epson cx2900?
Have you changed the ink cartrage? Could simply be out of ink.
Check your last printed item. See if it is getting lighter toward the end of the document.
2answers
Error messages
Simply pull all the paper out, cancel all printing documents and then print the document (without putting the paper back) and if it comes up with the error that there is no paper than there is no jam and putting the paper back should be fine, however to be on the safe side try printing at first with one piece of paper for the first sheet then put a buch slowly adding to the pile per page utnil all the paper has been put back.
Hope theat Helps ^^
~VD
Not printing text
with a wet paper clean up the head of the cartridge, and let some tint go to the napkin, or paper :) Resulted for me
Top Kodak Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
