Question about Soleus 4 in 1 Portable Air Conditioner
Carrier model 38eb030310
SYSTEM DOES NOT WORK
CARRIER TRANSICOLD A/C SYSTEM
I can find no A27 fault code for this unit, what is it doing? You can call carrier and ask for the definition, I think they will give it to you, just have the specific model number in hand when you contact them.
Aug 18, 2016 | Carrier Transicold Division Heat/cool...
CENTRAL ELECTRIC HEATING SYSTEM carrier model #fa4anf036 heater does not turn on. a/c works. fan works
Sorry to read about your problem, I hope this helps you out.
you may have a pilot start issue....
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 25, 2010 | Carrier Heating & Cooling
Need to know the tonnage ofCarrier s/s Model #38ARZ008, ser # 1404G20031
Brand: CARRIER Manufacturer: CARRIER CORP SYRACUSE Model Number: 38ARZ008(5/6)0 Condenser Type: air-cooled Coil Model Number: 40RM-008--B5/6GC System Configuration: Split System Air Conditioner Energy Efficiency: 10.6 EER Cooling Capacity: 90,000 BTUs / hour ARI Type Code: RCU-A-CB Electrical Service: Triple-phase Electrical Input: 8,490 watts per hour Voltage: 230 and 208 and 460
12000 btu's per Ton, equals to 7.5 Tons.
Sep 29, 2010 | Carrier 38CKC042 Air Conditioner
Unit Just working Half an hour
Without any tools it's hard for you to know what to do and without a manual you are better off having an exper to fix. here is cairrer web site where you can type in your zip code and buy the manual or get someone certified on carrier ac systems. carrier desert master Model No.38HKC24US70-01
Aug 25, 2009 | Heating & Cooling
Carrier Comfort Zone 2 Master is flashing E5
Check float switch. E5 is loss of 24 volt power on some models.Russ
Jul 27, 2009 | Carrier 38CKC060 Air Conditioner
System Malfunction, No communication with outside unit
I work on Carrier Infiity systems. The outside board has a Model plug on it. This tells the system what size unit it is. They do go bad. You can reset your self by turning the power off to the Air Handler. These system have 10 year warranty and if you still have a problem have the replace the outside control board and model plug. Also you can contact Carrier on the their website and get answers. You may need to talk to a service rep in your area. Carrier is good about their Tech support. You should have to pay for a service call if you your problem continues. Sometimes power surges or stoem cause these problems but not often Rusty
Apr 26, 2009 | Heating & Cooling
Match up Carrier equipment
carrier did sell some systems with R407c as a quick fix to gov regulations for about 2 yrs. R407c is a blend . and is treated like R410a except R407c pressures are more simular to R22. being that the pressures run the same the system should work with out changing any parts that being said if the evaporator has been used for R22 the oil residue wiil give you problems ifit is a new unit you would be ok.
Jan 08, 2009 | Carrier 38CKC042 Air Conditioner
Carrier Product # 38BRC042320
This unit was manufactured 1/8/00 and is a 4 1/2 system
Sep 30, 2008 | Carrier 38CKC036 Air Conditioner
Soleus 4 in 1 Portable Air Conditioner Logo
Top Soleus Heating & Cooling Experts
Coss
Dennis Boxerman
Harjeet Singh
Are you a Soleus Heating and Cooling Expert? Answer questions, earn points and help others
