Ive got a hi super aircon wich gives me a code CL when i switch it of with a beep sound
Beeps 4 times when I switch it of with a code CL on the display
MicrowaveSvc
  • 9047 Answers
SOURCE: ge spacemaker xl1800 microwave
F3 on a GE microwave indicates a defective keypad.
The keypad is a thin plastic membrane type that is glued to the plastic control panel frame.
If none or only some of the pads are working, there may be some foreign substance on the circuit board, the keypad connection, or inside the layers of the keypad, the latter of which cannot be repaired.
Trouble is sometimes due to spray cleaner being sprayed directly onto the keypad. Cleaner should be sprayed on the cloth first, then use the cloth to wipe the keypad clean.
Never use an ammonia-based cleaner on plastic as the ammonia can attack and crack it.
A handy person can remove the control panel frame and see if there's any liquid inside on or behind the panel. If so, it is possible to dry it out, but often that does not work.
Another thing is to unlpug the power at the mains for several seconds. Plug it back in and see if it works. A reset may do it.
At power-up, the display should flash or show a text message. If not, a key may be stuck due to a foreign substance or a defective keypad.
If certain keys are not working, there may be some foreign substance at the point where the green or blue plastic strip from the keypad plugs into the circuit board.
To check that, see our critical safety, disassembly, and troubleshooting info at our site. You'll find a link to our site in our
listing here on FixYa: http://tinyurl.com/yzjozk
1. Be sure the oven is disconnected from the power line while you are taking it apart.
2. The keypad connection is the green or blue translucent plastic strip that plugs into a connector near the edge of the board.
3. There are two tiny tabs (one on each side) of the connector that you can gently pull up on to unlock the connector.
4. Then the keypad strip will lift out. Clean both sides of the end of the strip with a pencil eraser or alcohol-based cleaner if you like, but do not use ammonia-based cleaner. Dry the end of the strip.
5. Put the keypad strip back in, making sure both sides are down fully.
6. While holding the strip down, push the connector back down to lock it.
7. Try the keys again with the door closed.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jan 13, 2008
  • 1314 Answers
SOURCE: Frigidaire Electric Dryer error code "dr"
try pressing options and select for ten seconds loc shouls come on then do it again to turn it off also check to see if the door is closing properly and that the door switch is closing and let me know i cant find no dr code so i dont think an error code i suspect it has something to do with the door closing
Posted on Jan 24, 2008
rickzilla
  • 706 Answers
SOURCE: LG-Trom Getting error CL .now not able to operate.after switch on it gives CL in display
IE is a water inlet error...meaning that the correct water level was not achieved within 8 minutes or it did not reach preset water level within 25 minutes...
CL is child lock feature which can be toggled on and off by by holding the Pre wash button in for 3 seconds.. Hope that helps...
Posted on Aug 17, 2008
Hai Idiots
ITs on CL (Child lock)
This occurs only if the power is turned off during the washing period
Press the TEMP and OPTION together for 3 seconds and it will go off
Amber
Posted on Nov 11, 2008
Daholk
  • 41 Answers
SOURCE: My HP dv5000 laptop has AMI BIOS beep code - 4 beeps
It sounds like either RAM or VIDEO problem to me. (I can't remember the specific beep sequence for AMI bios errors).
Hard to diagnose in Laptops.... if it was a desktop you can just start swapping out the RAM DIMMS..... are you techo enough to check whether you have 1 or 2 RAM cards installed? If 2 then run it with each card in turn to see if it boots (indicating 1 faulty RAM stick). If only 1 then try running MEMTEST on it to see if any errors. (I like HIRENS if you have it... I think it usually has latest MEMTEST on it).
If your cards all pass then its very likely a video problem. If its onboard video with no expansion slot (likely in a laptop) then you may be buggered.
Let me know if you need a hand doing any of the above.
Posted on Mar 25, 2009
2003 f 250 super duty truck five beeps five times
5 beeps 5 times - Ford Truck Enthusiasts Forums
www.ford-trucks.com > ... > Super Duty & Heavy Duty
Jan 2, 2009 - 5 beeps 5 times Super Duty & Heavy Duty. ... 2003 F250 4x4 CC V10 4" Procomp, all white beauty "list of previous owned Fords much to long to ... Beeping under my dash
Jun 17, 2012
Getting these strange beeps from Dashboard
Nov 13, 2010
beeping noise
Dec 22, 2009
5 beep tones 2000 f250
Oct 14, 2015 | 2003 Ford F-250 Super Duty
Laptop beeps 7 times
Try link: http://blog.parts-people.com/2014/06/27/dell-inspiron-m501r-m5010-beep-codes-diagnostic-indicators-2/ How to identify beep codes: When a laptop or computer first powers on, it goes through an initial set of diagnostic tests to make sure vital components are preforming correctly. These tests are called POST or Power On Self Test. When a test fails, the user is notified via POST codes, Light codes, or Beep codes. For diagnosing Beep codes you need to:
  • Power on the laptop or restart it if it is already on.
  • Listen to the number of consecutive beeps when the computer begins to boot. Restarting the laptop may be necessary and should not harm the laptop at this time.
Dell Inspiron M501R (M5010) Beep Codes # of Beeps Description Possible Cause(s) 1 BIOS ROM checksum in progress or failure System board failure, covers BIOS corruption or ROM errors. 2 No Memory (RAM) detected Memory or Memory slot failure 3
  • chipset Error (North and South bridge error, DMA/IMR/Timer error)
  • Time-Of-Day Clock test failure
  • Gate A20 failure
  • Super I/O chip failure
  • Keyboard controller test failure
System board failure 4 Memory read / write failure Memory failure 5 Real Time Clock (RTC) power fail CMOS battery failure 6 Video BIOS test failure Video subsystem failure 7 CPU Cache test failure Processor failure or motherboard failure 8 LCD LCD failure Most Common Fixes:
  • 1 Beep: Replace the motherboard / system board.
  • 2 Beeps: Reseat the memory or replace the memory.
  • 3 Beeps: Replace the motherboard / system board.
  • 4 Beeps: Reseat the memory or replace the memory.
  • 5 Beeps: Replace the CMOS battery.
  • 6 Beeps: Reseat or replace the video card or replace the motherboard / system board.
  • 7 Beeps: Reseat or replace the CPU or replace the motherboard.
  • 8 Beeps: Reseat the LCD cable or replace the LCD screen.
Jul 21, 2014 | Dell Inspiron M501r Laptop Computer (AMD...
Dell Studio XPS System 435MT beeps?
Here is a list of beeps that can help you:
1 beep BIOS ROM checksum in progress or System board failure
2 beep No memory modules detected
3 beep System board failure. Power LED is blinking amber
Gate A20 failure
4 beep Memory failure
5 beep CMOS battery failure
6 beep Video card failure
AK
Jul 17, 2014 | Dell Computers & Internet
My desktop sounds like its on but the monitor, keyboard & mouse don't seem to also when I press the power on button after a little while it beeps about 4 times.
DELL BEEP CODES
Beep Codes Beep Code Description Failure Coverage 1 System Board: BIOS ROM failure System Board, covers BIOS corruption or ROM error 2 Memory No Memory / RAM detected 3 Chipset Error (North and South Bridge Chipset DMA/IMR/ Timer Error for Intel platform); Chipset Error System Board Chipset Failure Time-Of-Day Clock test failure. Gate A20 failure Super I/O chip failure Keyboard controller test failure. 4 RAM Read/Write failure Memory failure 5 RTC Power Fail. CMOS battery failure 6 Video BIOS Test Failure Video card / chip failure 7 CPU Cache Test Failure CPU failure 8 LCD LCD failure
Feb 02, 2013 | Dell Alienware Area-51 Gaming Desktop...
X58 pro e hard to cold start
Three long beeps may signify a keyboard error, and 3 short may refer to memory error. These are best guesses, because MSI uses several BIOS manufactures. Test your RAM one chip at a time to help isolate bad dimm.
Aug 31, 2012 | MSI X58 Pro-E Core i7/ Intel X58/ DDR3/...
My Dell Latitude D620 will randomly give off a beep sound when powered on
those windows sounds are adjustable
start
control panel
sounds icon
look for windows sound settings find the one that says beep and disable it
May 25, 2012 | Dell Computers & Internet
Tha laptop just beeps when switched on. power ok, nothing on monitor - beeps 4 times then that is it!!!
4 short beeps might mean you have a bad memory module (beeps are coded) .. if you have two memories installed you can try takeing one out at a time .. it will start working when the good module is the only one plugged in .. just removing and replacing the memory sometimes cleans the pins so that it works again .. ... there are other possibilities that are more expensive usually ... so you hope its just the memory .. here is a site that gives beep codes for many machines ..
http://kb.iu.edu/data/afzy.html
Oct 06, 2009 | HP Pavilion dv6000z Notebook
Computer problem
during these beeps there should be pause between them at some point...in other words you may get 2 beeps/pause/1beep/pause/2 beeps noting the number of beeps and where the pauses are will help. From what you are describing and without more info it sounds as if you are describing beep codes, and they generally can give us a lot of information.
Aug 09, 2009 | Computers & Internet
Hi. My motherboard (MB) M925 V7.3 gives 3 long
Here's everything you ever wanted to know about Power On Self Test codes:
<a href="http://www.computerhope.com/beep.htm">http://www.computerhope.com/beep.htm</a>
Your three long beeps indicate the absence of a peripheral device known as a keyboard or mouse or other input means as follows:
Three Long Beeps Keyboard / Keyboard card error. CH000304
Mar 26, 2009 | PC Chips (M925G) Motherboard
Heating & Cooling Logo
61 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
