Question about Samsung Washing Machines
LG WP1250R spin Dryer belt is loose where is it located
3 Suggested Answers
SOURCE: lg dryer
My LG dryer makes too much noise during dry cycles. What part do I need to replace? Do you have an online manuel? My email is drlofton@aol.com
Posted on Jan 27, 2009
SOURCE: WHIRLPOOL ELECTRIC DRYER.MODEL # LEQ9508PW1. DRYER
HOW TO REMOVE THE MOTOR TO THE DRYER
Posted on Nov 13, 2010
Lg dle2101w is making a loug hum and rattle but works fine
the hum is usually a bad motor? perhaps u hear what u think is a hum? the rattle can be due to bad bearings, for example transmission spin bearings, tub thrust washer bearing, loose belt or worn belt.
Mar 08, 2015 | LG DLE2101W 7.3 cu. Ft. Ultra-Large...
Lg tromm DLE5977 won't start the tumble
Sounds like loose belt. If the drum spins by hand, it's almost guaranteed to be a bad belt.
Nov 27, 2013 | LG DLE5932W Electric Dryer
LG dryer wont start at times and will at others. If I spin the barrell it will work on speed dry only. Any other selection and it just makes a buzzing sound.
The belt may be too loose or the motor is over loaded. In worse case you need to replace either the motor or control board.
Sep 07, 2013 | LG Dryers
I have a LG Dryer, DLG2102W. It is about 2yrs old and is making rumbling and screeching noises when on. I am thinking is is a belt or roller
The problem (noise)can be from both side or area !
However, Loud noises coming from a Whirlpool dryer are most oftencaused by loose objects inside the unit or by a broken dryer belt. The dryerbelt allows the dryer's motor to run smoothly. Continuous wear and dry conditionsmay cause the belt to dry out, eventually cracking and then snapping. This willcause a loud noise within the unit. Repair and fix the dryer belt of aWhirlpool dryer to get rid of loud noises. Instructions And Things You'll Neededto solve the problem.
Screwdriver ,Replacement dryer belt 1 Stop the Whirlpool dryer and look inside thedryer's drum for any loose objects such as coins, pens or anything else thatmay have been in a pocket of clothing. Remove the object and restart the dyerto determine if the noise has stopped.
2 Unplug the dryer from the wall outlet todisconnect all power to the unit. 3 Remove the lint trap from the lint compartment onthe top of the dryer. 4 Remove the screws that hold the top panel inplace. Pull the panel off to access the
dryer belt.
5 Tilt the dryer forward and lift the dryer drum toremove the belt. Check the dryer's belt. A belt that is worn, cracked, split orbroken will cause loud noises. 6 Slide the old belt off of the drum and pull it outto remove it. Take note on how it is positioned over the drum.
7 Install the new belt. Lean the front panel awayfrom the dryer and slip the new belt over the drum. Locate the position of theold belt and slip the new belt following the old belt's position ensuring thegrooved side of the belt faces down. Push the idler pulley towards the motor toallow you to slip and loop the belt around the motor pulley.
8 Place the top panel on the Whirlpool dryer andscrew it in place.
9 Open the dryer door and use your hand to rotatethe drum counterclockwise a few turns to ensure the belt is secured.
10 Plug the dryer into the wall unit and begin use.If the noise still exists, you'll want to call a professional repairtechnician. Thanks for using fixya.
Jul 31, 2011 | LG Dryers
Dryer wont start, makes a humming noise. I have to manualy turn the drum then the dryer will start
Check the belt to see if it is worn or loose. If it has a capacitor start motor, the capacitor or motor could be going bad also. If the motor is spinning but the belt is not turning then you have a loose belt.
Jun 14, 2010 | LG DLE2532W Electric Dryer
My LG dryer does not spin...everything gets hot and works except either it spins VERy slowly or not at all
Open the back to get to the motor and check to see if the belt is loose on the motor pulley. Try to turn the empty drum by hand--does it seem bound up? Turn the motor pulley, does it seem hard to turn? Maybe the motor pulley is loose on the motor shaft. Run the dryer for a short time to watch the action of the drive belt.
Sep 27, 2009 | LG DLE0332 Gas Dryer
Drum won't spin. It will turn manually. Motor is working.
remove the access panel from rear of dryer. locate what is called the tensioner pulley. try lubricating it. may as well service it while youre in there. dryers are reasonably simple. lube all moving parts and clean. check belt tension. lint could also be a problem. dont be scared.
Mar 28, 2009 | LG DLE5977 Electric Dryer
Drum Won't Spin
Sounds like either the drum belt is either loose or is broken, otherwise the motor may need replacing.
Jul 28, 2008 | LG DLE2514 Electric Dryer
Dryer won't spin
step 1- remove the face of the dryer, then remove the cover for the fan, check to see if object is blocking the fan, if object is there , remove object, if not go to step 2
step 2- check to see if the belt is broken, if the belt is broken replace the belt.
step 3 - remove the belt from the motor and turn the dryer on, if the motor doesn’t turn then you need to replace the motor.
Jan 01, 2008 | LG DLG5988 Gas Dryer
Washing Machines Logo
41 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
