Question about HP Pavilion a800n (PP163AA) PC Desktop
Start up issue
When powering up the PC the monitor led is blue for a few seconds then turns amber whti a black screen. Unable to boot at all.
  • 3 more comments
  • dknapp1 Aug 28, 2007
    I have tried connecting to another monitor already and the same problem arises. Also... I checked the video card and all the cables as well.
    I do not ever see anything on the monitor nor do I hear any beeps
    By the way, I have an on board video card. Would it be possible to add another video card and connect my monitor to that?
  • dknapp1 Aug 30, 2007
    Still need help!!
    I cannot remove the onboard video card. However, I did install a new video card and still have a black screen and no beeps.
    Problem Solver:
  • 12 Answers
If 3 beeps motherboard are damaged or cpu
Posted on Oct 01, 2008
    Brigadier General:
  • 6,966 Answers
Hi again,
Have you seen your newer post.
Cheers.
Posted on Sep 05, 2008
    Sergeant:
  • 395 Answers
Remove RAM memory - does computer beep?
If not then CPU/mainboard/ PSU is dead.
If it does beep then CPU is working.
Posted on Aug 18, 2008
    Scholar:
  • 72 Answers
If you have tried another monitor then your down to the problem being your video card or computer. Is this the first time using this video card? If so, try removing it and using the one you had in before hand. Once your back into the computer, check to see if there is a driver update for your video card.
Posted on Aug 28, 2007
  • HP Master
  • 12,061 Answers
What ya need to do is isolate your problem.. you need to see if your monitor is faulty OR ya PC.. OR both? ... So, test your Monitor on another PC... see if it works OK... Try another Monitor on your PC and see if it works... I think it is possible ya may find that it is your Monitor that is faulty and NOT ya PC itself.. but by doing what I described you at least will be able to isolate where your problem(s)? are. Which will dictate the steps that must be undertaken from that point to effect repair.
  • 1 more comment
  • electronic & computer repair&  servicre
    Well done on ya troublshooting so far...
    well as Valiis so wisely says, well the Video card must be next in line to check... if ya do have onboard video, old working card, then yup go back to that .... see if ya can "Boot" if yes... well then ya card may indeed be faulty.. OR maybe it's Driver related.. less likely.
    Are ya sure ya Power Supply is OK? ..see if ya Fan is going..
    Do you see anything ever on monitor?
    Do you hear any "Beeps" during attempted Boot?
    Yes you can add another video card no problem, simply remove old, insert new, hopefully boot to windows.. windows will ask for New Video Card "Drivers", so point them to the driver CD or files and install, reboot... & ya should be all good
    OK you must disable the ONBOARD Video card in the BIOS... Try that.. if that don't work.. then maybe I think ya have a Faulty "Motherboard" .... The only "Other" thing maybe the RAM, ya may wanna try replacing that.. a bit of a long shot tho...?
SOURCE:
HP Pavilion F1503 only displays a split second?
well, its a 2003 LDC 13 years old ,
its bad
the monitor itself of the power pack to it is bad.
you can test it on any PC< or laptop made
if its dead on all , then its dead.
what more needs saying,
older LCD monitors had old CCFL, lamps. that love to fail
newer are LED back lights that last for ever. it seems
so up grade?
seems your back light is dead
ever do the flash light trick
shine it at the dead screen see good data
yes, then the CCFL is DEAD< (or its power supply ,deep inside)
fixed may but would never do a 2003, not now.
lots of used good LED for sale,
Mar 09, 2017 | HP Pavilion F1503 15" LCD Flat Panel...
HP Touchsmart IQ526- Black Screen and Amber LED please help! No display. Is this a hard drive issue?
Also had this issue on the Touchsmart IQ526. Removed the CMOS battery, waited some minutes, then powered on. The power button remained blue and had video again. Reinserted the CMOS battery and put the unit back together. Note - the battery was on the mainboard.
Mar 24, 2012 | HP TOUCHSMART IQ526 PC PC Desktop
My flatron L1710S flat screen will not come out of power saving mode. When I turn on the monitor the power button/light is green for a few seconds, the screen indicated "power saving mode", then...
I switch on my PC, ensuring that all cables, leads and power supplies are connected properly. The tower powers up no problems at all. I switch the screen on, the green led lights up, the screen is completely black. A blue box appears centrally on the screen with the text 'power saving mode'. The green led light turns amber and then the screen just goes black.
Please don't suggest going to control panel, as I can't get that far.
PLEASE PLEASE CAN ANYONE SUGGEST ANYTHING give me
Mar 08, 2011 | LG Flatron L1710S 17" LCD Monitor
The moniter blacked out, blue light is saying the moniter is still on, but screen looks like there is no power. When you turn on the moniter, the screen shows up for a few seconds, then blacks out again!...
Unplug power. Unplug VGA cable. Remove back of monitor. (four small Philips headed screws along the bottom rear. Remove screws attaching Monitor to it's base. Carefully, lean the screen away from back of case. Gently unplug 25 pin cable from the screen.
Connect AC power.
Screen should power on Gray to White. Ble light comes on Blue.Flickers then changes to Amber.
Reconnect VGA cable. Monitor should work.
Close up the monitor in reverse order to opening it.
If these steps don't solve your monitor, consider replacing as cost of repairs may shock you.
Sep 09, 2010 | Proview PL926WBi 19" LCD Monitor
My AOC screen goes black after about a few seconds after booting.
The picture board on your monitor is bad, since it goes off after few seconds and the power led or button is on, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer or service center within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
Jul 26, 2010 | AOC LM729 17" LCD Monitor
I have a Dell 1707fp monitor. When I power the monitor on it powers on normally. After a few miniutes, even though the power button is still green the display goes blank. I have tested this on other known...
I just fixed my for less then 1 minute. Here was the problem, when turn on the PC with the monitor connected. The screen appear like normal for about 2 seconds then shut off black but the GREEN power LED stay on, if i press the power off and turn it back on the screen act the same thing.
Here how to fix it, turn off the PC, unplug the monitor power cable then plug it back. The power LED will stay amber. Hold down both brights minus - and plus + same time, turn on the PC, keep hold the - and + buttons press the power button turn on the monitor.
You will see the screen back on, just hold for about 10 more seconds till you see the screen seem to stay on fine then realse them. That's it how i fixed my.....GOOD LUCK
Oct 27, 2009 | Dell E173FP 17" LCD Monitor
Monitor Screen goes black every few seconds!
Check the capacitors on your monitors circuit board. If they have opened up at the top, they are fried. Buy new ones, make sure nothing has leaked from the old ones, and replace them.
Sep 26, 2009 | Dell SE198WFP LCD Monitor
COMPAQ PRESARIO DESKTOP PC SR1215IL. When switched on, cpu boots normal but no display on monitor. instead a sharp and bright blue vertical line appears for few seconds on the middle of screen. led of the...
tricky!! oh hi im Dyanne.. a totally unresponsive black screen can be th result of failure of th LCD or LCD inverter.( a specialized piece of electronics that energize th screen) to rule out th failure of th video display adapter or circuitry, try plugging in an external monitor..a standard pc monitor.. attached direct to th lappy. if it works, (as i susopect) th motherboard and video display are both working ok and its th LCD which is at fault. this can sometimes be repaired by a competent specialist. good luck xx
Dec 25, 2008 | Compaq Evo D300 PC Desktop
DEAD IIYAMA AS4636D
Hi Sammy7!!
I have such iiyama AS4636D monitor. In this day purchase.
I have such problem with you.
My solution:
Desktop pc and lcd power off (230VAC or 110VAC)
Power on lcd, after early desktop pc.
This moment, when running the pc booting, press and hold you the " + " button.
In this moment come in one blue screen. May be running on the sreen short message: check or select input mode: VGA DVI 1 2 . Select your correct cable connection type.
Have a nice day! and happy new year!
Lajos from Hungary
Dec 13, 2008 | iiyama Pro Lite AS4636D (Black) 18.1 in....
HP Pavilion a800n (PP163AA) PC Desktop Logo
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
