Question about Pool & Spa
How do I wire my EB 853 pool pump motor?
My pump is not working It is anew motor. I am not sure where to connect the white, black wire to the L1 and L2 connectors. Each lead on the pump has two prongs also . Which of the two do I use to connect the wires
4 Suggested Answers
john224
  • 1378 Answers
SOURCE: wire Hayward Super Pump for 115
If you look closely, you should see a small arrow on the black plastic piece on the terminal block(jumper). That arrow lines up with either the 115 or 230 mark on the white terminal board. Make sure it is aligned with the 115.
Then put you two line wires on. It does not matter which wire goes to line 1 and line 2, just be sure you DO NOT put them both on the same terminal. A plastic divider usually seperates the two line connection terminals.
Posted on Jun 13, 2009
john224
  • 1378 Answers
SOURCE: I am not sure where
None of the above. You hook your two line leads (the two hot 115 lines) to L1 and L2 and you hook up the ground to the green screw. Do NOT connect the neutral to the motor.
Posted on Jul 29, 2011
MOTORWIZJ
  • 1384 Answers
SOURCE: I need to verify the wiring on a Hayward MaxFlo II
Posted on Sep 08, 2011
Open Question Wiring problem: I purchase a UST1072 AO Smith Pool motor. I have 230 volts. Does the black wire go to L1 and the white wire to L2? I have the ground wire connected.
measure across black and white if 230 volts L1 black and white L2 make sure to put black tape on end if measures 230 volts someone changed a wire to hot if only 120 volts across them see side of motor for low voltage wiring
Jun 02, 2018 | AO Smith Pool & Spa
AO Smith 1.5 HP pool pump motor. Voltage selector broken. Three wires to the switch,Purple, black and white w black stripe. Which two should be connected for 230 volt operation?
Try the black to L2 (L2 will be your Purple). L1 should be connected direct and separate. The black/white striped wire should get capped off.
http://www.inyopools.com/HowToPage/how-to-use-a-multimeter-to-test-a-pool-pump-motor.aspx?CommentPage=1
Jun 17, 2017 | AO Smith Pool & Spa
How do I wire up a A.O. Smith 3/4hp PB4 Booster Pump for 230V operation?
Here's some more info diagrams for you http://www.electricmotorwarehouse.com/aosmith/AO_CONNECT.PDF L1 is one hot wire L2 is the other hot wire. L1 can not be connected to a L2 wire and L2 can not be connected to a L1. Ground only to ground.
May 27, 2014 | AO Smith 1.5 hp Swimming Pool - Jet / Well...
Proper wire hook up
black goes to L1 white goes to L2 make sure to look on side of motor to change from 220 volt to 110 volt either a knob or changing wires brown and white to different locations hope you didnt fry motor
Jul 26, 2013 | AO Smith 1.5 hp 3450rpm 48Y Frame 115/230...
I need to wire my century pool/ jetted tub motor 1081/1795 where do the wires go? green white black
see side of motor for schematic usually black to L1 white to L2 green to case make sure wiring is changed from 220 to 120 come for 220 volt usually
Jul 02, 2012 | AO Smith A O Smith Motors Century 1hp 115v...
I have old spa motor with Red - low speed, Black - High speed, White - Neutral, Green - ground. New Dayton 5PXG3 motor has only L1, L2 and ground. How do you wire that?
The motor should work if you connect the black wire to L1, white wire to L2 and green wire to ground. The red wire should be cut so the conductor does not extend past the insulation and the end wrapped with electrical tape.This should be correct if the motor is a 120 VAC motor. If the motor is a 240 VAC motor then the white wire is not really neutral. It should be wrapped in both the motor wiring area with black electrical tape and the other end in the timer should also be wrapped with black tape.
If this causes a problem because you now have no low speed for the spa then the only way to get the low speed is to squire a 2 speed motor.
I hope this helps.
Sep 05, 2011 | AO Smith 1.5hp Pool Pump Motor 2 Speed Ao...
I am not sure where to connect the white/nuetral wire at the connection points under the back motor cover of a 1hp,pool pump. I am wiring pump for 230V, and have four wires running to pump motor.does the...
Jul 29, 2011 | Sta Rite Sta - Rite 1hp Dura - Glas...
Does it matter if use 220 or 115... looks like i have 25 amp in the box with gfi.. need connect the wire to back of the motor.. outside i have the big circular 3 pronged connection to the outlet... do i...
220 VAC is more efficient ... so there is some cost savings in the money department. Volts X amp = watts generally ... there is still a savings because you will actually consume fewer watts at 220 (watts is what you are purchasing form the power company)
Wiring depends ...you going to use 110 or 220? if 110 ... black is hot and goes to L1 ... white is nutral and goes to L1.
If 220 ... black is hot and goes to L1 - white is hot and goes to L2.
Your owner manual has a good picture and description of this.
In the plug ... 110 - neutral should go to the left slot.
Is your breaker 110 or 220 (single pole or double pole - one slot or two slots)
These voltages are not compatable!
I suggest you use this pump at 220.
Jun 04, 2010 | Hayward 1.5hp Pool Pump Motor Motor A O...
Wire Hayward Super Pump for 115
Jun 13, 2009 | Hayward SUPERPUMP 2.0 HP, 115/230V
Pool & Spa Logo
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
