Question about Technics SL-1200MK2 Turntable
Technics sl-1200 tonearm problem
The tonearm keeps pulling back to the right. I cannot get it to stay in the groove at all, it just slides to the right. Yes, I have adjusted the weight and anti skating correctly but it doesn't matter. Any ideas? thanks. Jim
    Brigadier General:
  • 6,966 Answers
Hi, Assuming the the turntable is on a level platform and that you have "adjusted the weight and anti skating correctly", might it not be just the styli/cartridge that's left in question? Visually check the styli/cartridge assembly, look for unevenness of wear on the needle itself, compare with a known good styli the angle. On some rare instances, it is the shielded wire inside the arm. Hope this be of some help/idea. Post back how things are or should you need further information. Good luck and kind regards.
Posted on Aug 30, 2007
SOURCE:
How do I fix the tonearm of my Technics SL-1950 so it doesn't keep pulling to the right when in neutral balance?
The anti-skating control adds an outward pull to the arm to compensate for the inward pull exerted on the arm when a record is being played.
Setting the anti-skating control to "0" should virtually eliminate the drift you mention when the arm is in neutral balance. Also make sure that the whole unit is level as this may also affect the arm's tendency to drift.
Dec 11, 2014 | Technics Audio Players & Recorders
Tone arm cueing problem on technics sl 1210
The turntable may not be level and consequently beyond the ability of the balance and antiskate adjustments to correct
Jun 26, 2013 | Panasonic Technics SL-1210MK2 Turntable
MY TONEARM ON MY TECHNICS 1200 SLIDES TO THE MIDDLE OF THE RECORD! DOES IT NEED TO BE REPLACED & HOW MUCH WILL IT COST?
No it's either the stylus or the pressure to the stylus is not enough. The weight at the end of the arm will increase the pressure on the stylus. Turn it up in slightly testing a record till the stylus tracks in the grooves. The trick is to get it so that it stays in the groove without creating a rumble sound. Remember though a worn stylus will not track at all.
Most cartridges track at 2 to 3 grams. If the Weight on the arm has numbers they will correspond to the weight in grams. If you have to raise it very high the stylus is too worn.
Jul 30, 2011 | Technics SL-1200MK2 Turntable
When i play a record it skips and when i play it on another turntable the same record doesnt skip
Hi, most likely a worn stylus or the tracking weight is set too lightly. Adjust the balance weight at the back end of tonearm forward slightly. If no weight adjustment available put a very small coin on the end of tonearm above the stylus. [email protected]
Jul 08, 2010 | Technics SL-1200 Turntable
I have recently removed the tone arm assembly and replaced the tonearm rest on my 1210's and now the tonearm is stiff horizontally so it stays in the same place and won't move across with the groove....
Check the arm wires have not got caught around the anti skate mechanism.
Did you adjust the screw / lock nut on top of the arm?. It's not supposed to be moved but if you did it might be to tight.
May 19, 2010 | Technics SL-1210 Turntable
I need to replace the wires of a technics 1200 torearm . May I buy just the wires instead the whole torearm?
the usual problem with the 1210 is int. sound in one channel caused by the phono cable breaking at the clamp underneath.this can be replaced.tonearm wire faults can only be fixed by tonearm replacement.
Dec 15, 2009 | Technics SL-1200MK2 Turntable
How do you balance & adjust tonearm after changing stylus
turn the whole weight until arm sits just above platter.hold back of weight and turn front disc to zero. turn whole weight to spec for cartidge fitted,usually around 2.
Nov 21, 2009 | Technics SL-1200MK2 Turntable
Technics SL-1200MK2 Turntable Logo
275 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
