Question about Briggs & Stratton Starter Scott's Equip S2046 Briggs Stratton 20hp
Mower turns over but won't start - Briggs & Stratton Starter Scott's Equip S2046 Briggs Stratton 20hp
Mower won't start
Glenn, check the lawn mower engine trouble shooting links below for engines that do not start.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Top 5 Mower Troubleshooting Tips Briggs Stratton
Lawn Mower Won Start Here The FIX
May 07, 2016 | Garden
The mower won't start
Rocky , start by replacing spark plug and remove old gas for new.
check links below for why mowers do not start.
When Lawn Mowers Won Start
Mar 21, 2016 | Garden
Why does my torolawnmower take off when i start it?
I have a riding toro lawn mower that cut off on me and wouldn.t start back, what could be my problem? The crak wheel trys to turn but it won,t turn over
Dec 11, 2012 | Toro Lawnmower Lawn Mower SP Drive Belt...
Cub push mower starts but won't run. i changed fuel and spark plug. what next?
MAKE ADJUSTMENT TO CARBURATOR,TURN SET SCREW COUNTER CLOCKWISE, HALF A TURN,TRY STARTING MOWER,IF IT STARTS TURN QUARTER MORE,THAT SHOULD DO IT, GOOD LUCK
Aug 10, 2012 | Cub Cadet Street Sign- tractor lawn riding...
How can I move my exmark zero turn lawn mower when it won't start?
on the rear of the machine there is a release lever for each side pull that back and down to lock it in place
Jul 12, 2012 | Garden
Craftsman zt 7000 zero turn riding mower will crank but won't start and the starter get really hot
sounds like a safety switch problem. but maybe you can help me i have the same model do you have a lot of jerking when you start off of turn with yours?
Apr 10, 2012 | Craftsman Garden
We just replaced the belt on the deck of our mower. After we reattached the deck, the mower won't start. It won't even turn over. We checked the safety latch on the back of the machine, and it...
First check your battery, it should be around 12.5 volts, if not it is the battery. Because you changed the deck belt, is the mower a manual engaged deck? Make sure the safety switches are working properly. Seat switch, brake switch. When trying to start, do you get 12 volts to the starter? If not, check the 20 amp fuse.
Jan 07, 2018 | Husqvarna Zero Turn Mower Z5426
Have a john deere sabre turn key won't start thought battery was dead charged battery still won't start jump start with car battery it will start then . try to engage reverse with blades running it...
Some mowers have a mowing reverse safety switch. That safety will kill the mower if you try to reverse with the deck engaged. Some mowers even have an override button that has to be held while backing up. As for the battery thing, no matter how much you charge a bad battery you will not get it to start a mower if it has a bad cell or two. I would use a multimeter to check battery voltage, but the end result would still be the same, replace the battery.
I hope this gets you going again.
Aug 07, 2011 | John Deere 22HP VTwin 48" Riding Mower
Won;t restart..
Check battery,if it's good, check charging system.
May 08, 2009 | Garden
Briggs & Stratton Starter Scott's Equip S2046 Briggs Stratton 20hp Logo
37 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
