I bought a Sears Craftsman Platinum 7.00, 190 cc B&S, Precision Plus low-wheel push mower - mod # 24738917 "used" from Sears last May 25, 2012 and I want to find out if there is a solution to the problem of having to pour gasoline into the tank verrry slowly or it will run over. Have to stop to let it go down and pour more slowwwwly. This is very bothersome. Is there a fix or is it some mfrg/engineering oversight/mistake that could be fixed to work better ? Any other complaints like this ? Ther are a couple other things about it that I think could have been done better but this is the most bothersome. Appreciate any suggestions. It's still under mfrs warranty. thanx C Gibbs
SOURCE: craftsman lawn mower
I had both my front wheels wobbly - so I cut shims from a tin can - wrapped the axle of the wheels with the shims and then inserted them back into the plastic bushes. It was a snug fit - but helped quite a lot.
Posted on May 27, 2008
SOURCE: Craftsman 17.5 LT1000 Won't Start - Need Help
pull the flywheel and check if the key(latter models the flywheel itself will need replaced if stripped)is damaged. This is a possibility.
Posted on May 27, 2009
  • 95 Answers
SOURCE: prob with PTO on craftsman mower 917.273372
There is a idler pivot plate on the mower that must be cleaned and lubricated regularly, from the left side of the mower deck if you look in the middle of the mower deck while someone engages the mower(with the engine off) you will see the pulley try and move,there is a 3/8 bolt that comes up through a bushing that this pivots on, soak that area with wd-40 and see if that improves the movement. Be sure not to get any wd-40 on the belt or pulleys. Always try and keep that area clean and lubed.
Posted on Jul 30, 2009
  • 724 Answers
SOURCE: belt came off 42 inch
there should be a small picture pasted to the top of the deck on the drivers side.
Posted on Aug 20, 2010
  • 3740 Answers
SOURCE: I have a Briggs & Stratton 500 series push lawn
Hi and welcome to FixYa, I am Kelly.
When a primer bulb is slow to return to a static conditon there is a restriction in the fuel supply. Since this carb is mounted directly on top of the fuel tank the troubleshooting for this involves removing the gas tank and carb as an assembly from the engine. Remove the end bolt and then the side bolt spacer that is just above the tank. Be careful or the spacer will drop. Pull out on the tank until it slides off of the intake. When the tank is free of the engine tile the bottom of the tank toward you and disconnect the throttle linkage. NOTE the hole the linkage is connected to! Set the tank on a flat surface and remove the carb mounting screws. STOP! Do not lift the carb off of the tank until your sure that the gasket and diaphragm are not stuck to both mounting surfaces. You may have to carefuly slide a thin knife blade FLAT across the top of the tank to free the carb from the tank. There will be a SPRING on the bottom of the cabr also. Do not lose this spring and ensure you see how it is installed! Once the carb is free of the tank clean the screen under the carb and the carb with carb cleaner. Reassemble carb to tank. Fill tank with gas and re-check primer bulb BEFORE you reinstall the tank and carb on the engine. If it still does not work.. properly you need to clean the passages again. Worst case you remove the primber bulb to see if there is debris inside the bulb plunger area. Installing tank and carb to engine....
Tip the bottom of the tank toward you.. connect the throttle linkage, watch the o-ring that is in the carb intake sealing area and make sure it seals. Install side bolt and then the end bolt.
Just back tracking here.. I have determined this is most likely a 11A-B04E000 Yard machine with a 5.0 Hp engine... ( Briggs and Stratton refers to this engine as the 10T500 series.
ENGINE Parts list is here:
Thanks for choosing FixYa,
Posted on Jun 28, 2011
Throttle cable is loose from engine; where does it go?
Sears has thousands of illustrated parts breakdowns on their Parts Direct website that can be very helpful in solving this kind of problem. Along with their house-brands, they also have most other major brands available too.
Give it a try:
Sears Parts Direct
Jul 18, 2010 | Craftsman 675 Torque 190 cc 21" Push Lawn...
What is the part no. of the blades on a 42 in. mower
You can go to Sears' website at and enter your model # (usually found under the seat) to view the diagrams for your model and locate your part #'s. Once you find the Sears #'s, you can find replacement blades for your mower at Partsbuggy's Sears page here - It also lists Sears' part numbers along with the blades and belts by deck size.
Jul 06, 2010 | Craftsman 42 in. Precision Cut Plus 24hp...
I have been losing forward speed over the last 2 weeks, When I press the forward pedal the mower goes very slowly. My engine is working fine.
The automatic transaxle is driven off a belt that runs from the engine to the top of the transaxle, make sure this belt is not slipping and also ensure the neutral rod in the rear of the tractor is pushed all the way in.
May 24, 2010 | Craftsman 42 in. Precision Cut Plus 24hp...
I have a craftsman self propelled lawn mower The clip that holds the metal bar to make it go forward broke the speeds don't change it is difficult to pull backward the wheels won't move
i have a craftsman rope start lawn mower, the rope keeps snapping back on me and sometime will not come out at all. is there a way to fix this problem
May 18, 2010 | Craftsman 22" Rear Bag Rear Propelled High...
Will a 26 kolher fit a 24 kolher sears tractor
yes might have to change pulley size not much difference just a little more hp
Feb 22, 2010 | Craftsman 42 in. Precision Cut Plus 24hp...
Oil in engine
You probably have a blown ring in the cylinder.
Aug 20, 2009 | Mtd 22" Yard Machine Push Mower
Looking for manual for Craftsman 917.256552 15HP OHV Kohler 42" Hydro lawn tractor mower. I have the Spanish version but lost the English version with parts and diagrams!
if you go to click on parts direct
enter your mod # and to the right of the next page says get manual click on that and then click on view manual and it should come up for your mower
Jun 09, 2009 | Craftsman 42 in. Precision Cut Plus 24hp...
Open Questions:
Computers & Internet Logo
77 people viewed this question
David Payne
David Payne
