Eclipse e777 projector will not change screen size to 16:9 when hdmi cable is attached, but if a coaxial cable is attached it will let me change the zoom size. How can I fix this?
5 Suggested Answers
simplemitch
  • 752 Answers
SOURCE: No input detected on projector
it sounds like the A/V reciever does not upconvert the component signal to HDMI. Not many do. The Marantz recievers will (SR6001, SR8001, etc..). Also bear in mind that HDMI cables are finicky and may require amplification over a few meters long.
Posted on Dec 04, 2007
tinamarie49
  • 34 Answers
SOURCE: image bigger than screen
Try changing the keystone. Also you may have the projector too far away from the screen. Changing the resolution on your laptop will not solve that particular problem.
Posted on Dec 05, 2007
rickbrashear
  • 176 Answers
SOURCE: Projector powers up as normal, bulb comes on,
There is a source lock and source button I would unlock source lock button and the push source button until you get to your hdmi input you are using. You also may just plug in one input first and once you get the input right play with the multiple hdmis
Posted on Aug 11, 2011
SOURCE: I bought a usb-vga cable for my optoma widescreen 16:10 enhanced projector but its saying
hi sir,
try to switch the way of output, so that choice suitable screen output way.
certainly, it is possible with compatible problem. review your projector instruction, check it can support USB function or not by the manufacturer.
hope it is helpful for you.
regards,
Jack
flying200809@gmail.com
any friends who were looking for below products, welecome you to contact me,
Professional wholesaler and retailer: for below products
1) projector spare parts, such as color wheel, lamp, mother board,DMD. lens, etc.
2) computer mother board,
3) HP server, switch, router. Cisco router. switch etc. complete machine or asscessories or parts
4) server or router memory
5) GBIC OR SFP
Posted on Dec 03, 2011
Replacing coaxial input
Coaxial cables are all standard for that kind of TV. I'm about 99% sure on that so just go to a electronics shop and buy one and double check with the person at the shop but I'm sure you'll be save just replacing your old one with the same size!!!!
May 10, 2015 | LG 50PV450 50 in. HD-Ready Plasma TV
Eclipse 3d immersive e777
Have just un-boxed with same problem. I kept changing out-put on Windows 7, selecting 'extend projector' and 'duplicate' under display settings while changing input source from HDMI 1 to 2 for about 2 mins and I'll be damned, it worked!
Good Luck
May 23, 2012 | Blenders
How to you connect PS3 to to model 37PD5000
Good day!!!
Please try this procedure to connect the PS3 to TV..
The PS3 has a Blu-ray drive that can be used not only for playing games but also for watching high-definition movies. The best way to connect a PS3 to a high-definition viewing device such as a video projector is through the PS3's high-definition multimedia interface (HDMI) output. The HDMI connection can transmit up to 1080p high-definition from the PS3 to the video projector using a single cable. Attaching and setting up the HDMI cable will only take a few minutes and will let you watch high-definition video from the PS3 on the video projector.
  1. Connecting HDMI
    • Attach one end of the HDMI cable to the HDMI output connector of the PS3. Turn the HDMI cable around if it does not slip right into the HDMI output, because the HDMI cable can only fit into an HDMI connector one way.
      Attach the other end of the HDMI cable to the HDMI input connector that is on the video projector. Make sure both sides of the HDMI cable is securely pushed into the connectors of the PS3 and of the video projector. Turn on the video projector. Press the "Menu" button on the video projector's remote. Navigate to the "Sources" setting on the video projector's Menu. Select "HDMI" from the "Sources" setting. Press the "Menu" button on the remote control again to exit the Menu.
    Adjusting the PS3
    • Turn on the PS3. Wait for the "Home" menu to appear on the video projector, although the quality of the video seen from the video projector will be muddied and dark. Navigate from the "Home" menu to the "Systems" icon using the game controller and select the "Display Settings" tab. Choose "Video Output Settings" from the list presented in the screen that appears. Press the right side of the directional pad on the game controller to move to the next screen.
      Choose "HDMI" from the list presented in the screen that appears. Press the right side of the directional pad on the game controller to move to the next screen. Choose "Automatic" from the list presented in the screen that appears. Press the right side of the directional pad on the game controller to move to the "Confirmation" screen. Press the "X" button on the game controller to make the settings active. Return to the PS3's "Home" menu.
    Watching the PS3
    • Insert a Blu-ray disc into the slot at the front of the PS3. Wait as the Blu-ray disc begins to play the video content on the video projector from the PS3 through the HDMI cable.
Please don't forget to rate my answer...I really appreciate any ratings you done..
Thanks for using fixya..
Jul 16, 2011 | Hitachi 37PD5000 Television
Picture too big tops of heads mjssing
Press the hd zoom # button or format/aspect button on your cable box/satellite box remote to adjust picture size. If that doesn't work try the below troubleshooting steps.
First make sure that your television is on the right input. i.e your cable box might be connected with both a coaxial cable and a component or hdmi cable. You might be on the input for the coaxial cable by mistake. Next check the resolution of your cable box and make sure it matches what your television can display. For example you should not have your cable box set at 1080i if this is a 720p television. Next make sure it is formatted for a 16:9 television under its (the cable box's) set up menu. Try pressing the wide/view mode/aspect/format button on your television's remote to adjust picture size.
Dec 05, 2010 | LG 37LG30 37 in. LCD HDTV
Connect laptop(with HDMI output) to TV( with s-video input)? Hi I have a laptop in which there is port for HDMI output and TV with S-Video input. I bought a cable (HDMI HDTV to VGA HD15 Y/Pb/Pr 3 RCA...
Here how you can connect a computer running windows vista to projector or other external display.
  1. Open Personalization window by right clicking on empty desktop and choose "Personalize",
  2. In the Tasks list click on "Connect to a projector or other external display" link,
  3. The Windows Mobility Center appears, in the presentation settings box click the turn on button to turn on projector,
  4. Now your screen will show up on projector screen around large display as well as your own computer screen,
  5. If you want to change the presentation options click the Projector icon inside presentation setting box,
  6. The Presentation Settings Windows appears, if you turned on the projector the "I am currently giving a presentation" checkbox is selected,
  7. When you are giving a presentation your computer stays awake, system notification are turned off and by default the screensaver is turned off,
  8. You can also set the system volume to show different windows wallpaper in the one you usually use, when the presentation ends and you turn off the projector your regular desktop wallpapers returns,
  9. If you are not sure what displays are connected click "Connected displays..." button on bottom of existing window.
Jan 10, 2010 | Office Equipment & Supplies
Samsung lcd 720 ln32b360 doesn't fill screen in 16:9 mode. Went through tv setup, connected it to hd box (verizon Fios) plays all HD channels but does not fill screen as it should. TV is connected to set...
If by regular cables you are talking about the standard red/yellow/white composite cables, then, yes, it will affect HD as composite cannot send an HD signal. Only HDMI and component (red/blue/green video only) cables.
Change to HDMI and let us know if it works for you.
Jan 07, 2010 | Samsung LN32B360 32 in. LCD HDTV
My projector optoma ep719 has a blue screen went turn on with or without cumputer hook up
please check the signal and the display properties as per SVGA or XGA resolution
Jul 16, 2009 | Optoma EP719 XGA DLP PROJECTOR 2000L...
Lose audio unless projector is on or unplugging hdmi cable from sharp xr-32x projector. works fine when watching projector
Your receiver is sensing the video source. Try using optical, or coaxial digital audio for an input, this may work.
May 11, 2009 | Yamaha HTR-6160 Receiver
35 people viewed this question
jasbo
jasbo
