Defy dishmaid drain hose replacement
How do I gain access to replace the drain hose?
4 Suggested Answers
jsrock516
  • 5911 Answers
SOURCE: We need to replace the drain hose in our Kenmore
To replace the drain hose, follow these steps:
1. UNPLUG the washer and turn it around so you can access the rear panel.
2. Use a wet/dry shop vac and pull a vacuum on the drain hose. This will remove any existing residual water that remains in the drain line and pump minimizing any mess you may have to clean up later. NOTE: There is about a gallon of residual water that normally remains between the lower wash basket, drain lines and pump.
3. Remove the rear panel by loosening the screws around the perimeter of the back panel. With the screws removed,the panel should lift off. NOTE: There is a smaller access in the center of the back panel that can also be removed. Removing the entire back allows for better access though. Trying to work through the center access can be a cut hazard due to the sharp edges on the metal.
4. Move around the the front of the washer and remove the lower toe panel under the door. You may have to prop up the two front feet of the washer to access the screws under the bottom front edge. With the screws removed, the panel will drop down, then lift off.
Additionally removing the front toe panel will give you full access to the drain pump from the FRONT and the REAR. The pump sits closer to the front of the washer where you can easily access the hose clamps. The drain hose inserts from the rear, however.
Since you have the washer apart, now would be a good time to check the drain pump clean out trap to ensure there is no debris build up that can restrict drainage. The following link explains the recommended procedures to check the drain pump:
http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loade
If you have any questions about any of this advice, please post back and let me know. I hope you find this information helpful.
Posted on Feb 08, 2010
Krazytech
  • 725 Answers
SOURCE: Drain hose leak
Hi Krazytech here, You will have to remove the cabinet to get to the pump end of the drain hose. First you must remove the top insert a putty knife to open the top lift up then remove screws that hold on the top then remove the screws that hold on the bottom. then you can get to the pump I alway replace the factory spring clamps with a screw hose clamp they are much better.. let me know
Posted on Aug 24, 2007
tborn6
  • 700 Answers
SOURCE: need to remove outer sheel to get access to drain pump
first remove the two screws that hold in the control panel and tip it back, then there two clips that the shell is locked onto undo them and pull the shell away from the unit. remember to shut off the power first. remove any wires that are hooked up aand the replace the pump. good luck
Posted on Jan 11, 2009
Require a wiring diagram for my Defy Dishmaid DDW140 dishwasher
here is a link to there manuals . Hope it is what your looking for.
Product manuals
Feb 27, 2016 | Cell Phones
Defy Dishmaid - The water from the bottom spray arm only comes out a about 3 inches and no water from the top arm. The water pressure into the machine is good/normal. What can I do/check?
Sounds like the machine has an internal problem of plugged passageways.
If you can figure a way to take the arms off the machine, and get a compressed air hose with a blower, unhook the machine at the fill hose in the bottom of the back and see if you can blow the sediment out backwards. \
DO NOT try to blow the air through the solenoid that turns on and off the water.
This will require completely dismantling the machine in a work area. God bless your efforts.
Feb 21, 2016 | Dishwashers
What should the run time be for programme 2 on Defy Dishmaid?
Go by what they really know or if they steal
Dec 04, 2015 | Cell Phones
I have a Defy dishmaid 8, the programmes are all out, how can I reset the programmes?
Hi Jacky Marcus,
Just keep the start button pressed in for about 5 - 10 seconds.
Should reset the cycles.
Hope this helps :-)
* If you found this solution helpful, please rate it
Jul 12, 2011 | Dishwashers
The grey drain hose split, anyone know how to replace this? Is it attached to the drain pump in the front? Also discovered that black drain tube is clogged at the front filter. This tube seems to be...
the drain hose is indeed attached to the pump area... sounds like you may be on well water if it is breaking the hose down that bad... if not that is unusual to have hoses break down like that... its not hard to replace the hose as they just have hose clamps on them ,but yes you do have to tear apart unit to get down to drain pump assembly... some of the units have a front kick plate you can remove to get to them and some you actually go into from the rear... i didn't look this model up but we work on all appliances and normally there is a way to access the drain pump.... some units front loaders you can actually tilt up and the bottom plate will remove to gain access to it also... just going to have to look around and make access the easiest way for you... once your in though it is a simple task to replace hose...
Jan 01, 2011 | LG WM1814CW Front Load Washer
How do I best replace a heater core in a corsica 1995
You will have to drain all engine coolant.Disconnect your battery and your two heater core hoses that are on the fire wall in the engine compartment.Now inside the car start removing your dash.one dash is removed you will have to open you heater box to gain access to the heater core once you have gain access remove and replace.Now start replacing heater boxes dash board and reconnect heater core hoses and reconnect battery.Now top up your engine cooling system with the engine antifreeze drained you should have a extra jug of coolant in case you spilled or just needed it to top up.Now start car make sure coolant is full when cooling fans come on put rad cap on you have completed the replacement of your heater core.
Dec 27, 2010 | 1995 Chevrolet Corsica
Washing Machines Logo
421 people viewed this question
Top Washing Machines Experts
