Question about Insignia IS-DVD1001 DVD Recorder/VCR
Insignia nr-drvcr I have made copies of a vhs tape in my insignia machine onto both dvd-r and dvd+r and it will only playback on the insignia machine. It will not play on my toshiba tv/vcr/dvd combo or on my pc - which is what I really need the dvd's for. I am new at this - what am I doing wrong?
  • sunfish13424 Nov 26, 2007
  • 67 Answers
Did the speed you chose exceed 2 hours?. If so, that is your problem. Any other machine will read that time frame, beyond that it is iffy.
Posted on Dec 04, 2011
After you record, you must go to menu and finalize disc. Have you done that? [email protected]
Posted on Sep 15, 2007
SOURCE:
Can DVD DISKS BE COPIED FROM VHS TAPES ON A dual; DECK MACHINE?
There are machines made just for that task such as the Magnavox DVD recorder. There is a VHS tape deck on one side and a DVD recorder on the other side. You can copy a VHS tape to a DVD and copy a DVD onto a VHS tape as well
Jan 21, 2017 | Televison & Video
Will this model record from the vhs tape to the dvd?
You don't state the manufacturer or model number in your question, thus we cannot answer. I will say that many do, but there is a caveat. If the the VHS tape is a commercially made movie, chances are it has copy protection on it. Most machines will sense this copy protection and will refuse to copy the protected VHS tape to DVD. This was done to prevent piracy. Home recorded tapes and non-protected tapes will usually work ok. Do not confuse write protection with copy protection however. Write protection is merely the tab on the tape that prevents re-recording of the tape. Copy protection is recorded right onto the tape itself and is read by the machine during playback.
Nov 19, 2015 | Televison & Video
How do I record a vhs onto a dvd on the combo?
I have researched the manual for this particular device and you will not be able to convert/record VHS tapes to DVD discs. You can however record content from a DVD to VHS tape as this model only has a readable disc player not a DVD burner. Sorry, but you may want to research DVD recorders that also have VHS playback.
May 02, 2011 | Insignia IS-DVD040924 DVD Player/VCR
Have a toshiba tp 61H95 proj TV- want to connect panasonic dvd recorder and toshiba vhs recorder so I can copy family videos to dvd- can't get hook ups set up for both to work.
Select AV-1 or some thing in TV and plug DVD recorder Video-Audio output in AV-1 input of TV, playback any DVD and confirm its picture and sound in TV. Press Stop button of DVD recorder to stop playback.
Now plug Video-Audio output of VCR in DVD recorder input and select AV Input in DVD recorder, insert VHS tape in VCR and playback it and confirm you get VHS picture and sound in TV via DVD recorder.
Hookup between TV, DVD recorder and VCR is completed.
Playback VHS tape in VCR, Insert blank DVD disc in DVD recorder and press Record while you see VHS tape picture in TV.
Hope this info will help you.
Feb 03, 2010 | Toshiba TP61H95 61" Rear Projection...
Instructions on how to burn from my insignia DVD to VHS
my Insignia is a different model (NS-drVCR) but I always use the "DUBBING" button on the remote (which is basically the tech-term for a Recording-Transfer). The screen-dialog then shows VHS Dubbing to DVD with quality options to choose. I'm not as familiar with going the other way (from DVD to VHS) but I know that mine can since I've done it once with a similar method, starting with the DUB-button.
Jan 11, 2010 | Insignia IS-DVD1001 DVD Recorder/VCR
No Instruction Manual
1. Insert a blank DVD disc in the DVD deck and
close the disc tray.
2. Insert the VHS video tape you wish to copy into
the VCR deck.
3. Find the place on the VHS tape from which you
want to start dubbing using the PLAY, FF, REW
and PAUSE functions. For best results, pause
playback at the point from which you want to
record.
4. Press the DUBBING button on the Remote
Control or DUB on the front panel.
The Dubbing menu appears.
5. Use the arrow keys to select the desired Record
Mode: EP, LP, SP or XP.
6. Select [Dubbing] then press ENTER or DUBBING
to start copying.
7. To stop dubbing at any other time, press STOP (x).
Dubbing will stop automatically when the VHS tape ends.
Mar 01, 2008 | Insignia IS-DVD1001 DVD Recorder/VCR
Recording from vhs to dvd
Direct copy VCR to DVD:
- Insert VHS tape you want to copy
- Insert a recordable DVD disc
- Press DVD copy button on front panel or remote control (to DVD).
- To stop recording press the stop button.
IMPORTANT: If attempting to copy copyrighted material the Samsung DVD-VR320 will detect the encoding and will not allow the copy to be made.
Jan 20, 2008 | Televison & Video
Insignia IS-DVD100121
thisCD recorder wont DUB COPY PROTECTED MATERIALS (COPY RIGHTED) AS IT WILL RECORD HOMEMADE VIDEO FROM A VIDEO CAMERA BUT NOT FROM A STORE BOUGHT TAPE AS THEy ARE COPY PROTECTED.
Dec 31, 2007 | Insignia IS-DVD1001 DVD Recorder/VCR
Insignia dvd recorder
Unfortunately, no, unless the DVD is not copy written material. Commercial DVD and VHS tapes have a built in copy protection called Macrovision. Basically, it prevents copying them with any Macrovision enabled recorder. All DVD and VHS players sold in North America are required to have Macrovision Enabled. Though there are certain players that get around this (such as the Apex AD-1500, in which Macrovision can easily be disabled), unless you research and purchase one of those specifically, you're not going to be able to avoid Macrovision, and therefore won't be able to copy anything to or from a commercial DVD or VHS tape. Hope that answered your question completely, even if it wasn't what you wanted to hear.
Aug 29, 2007 | Insignia IS-DVD1001 DVD Recorder/VCR
Insignia IS-DVD1001 DVD Recorder/VCR Logo
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
