Question about Hotpoint Washing Machines
Hotpoint wmyl 7151
I have noticed a strange smell coming from my hotpoint washing machine-I have taken the bottom flap down and unscrewed the cap to try and see if it was any trapped dirt. There was nothing
  • 14 Answers
SOURCE: Bad Smell
this is caused by a build up of old detergent and limescale.there are some industrial strength descalers around.wpro descaler is one.add the sachet to the drum with no wash load.pour in a kettle of hot water(not boiling)and leave for thirty minutes.then put washing machine on a 60 degree cycle and allow to run right through.you will need to repeat approximately every three months
Posted on Dec 30, 2007
Master_Tech
  • 770 Answers
SOURCE: Miele leak when switched on for wash, from filter unit front LHS bottom of machince
You can replace the Bellows as it is called but to fix it before you replace it clean it with Bleach to kill the mold and then dry it ALSO after any load you do leave the door open a bit this allows the mach to air dry out and prevents the build up of mold ..Good Luck plz rate this post for me
Posted on Feb 17, 2008
  • 185 Answers
SOURCE: Hotpoint First Edition 1200 Spin - lint tray?
there is no lint tray thats why you have a dryer to do that
Posted on Apr 08, 2008
  • 9 Answers
SOURCE: How can I unscrew the drain outlet at the bottom
Keep trying to unscrew it, as it should come right out for cleaning. A little water will come out too so put a small tray under the machine first.
Look at my other solutions, as for DOOR light flashing.
Posted on Apr 04, 2010
  • 662 Answers
SOURCE: Brown dirt-like looking "gunk" coming out of the washer
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the hose you see. The white filter cover is right in front. Get yourself a bunch of towels or a good big plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully.
Next: You can use Affresh to clean your front loader. Deposits of soap and other such things can be stuck around the inside tub of your washer. Try this product, it works great on all front loaders. Use hot water with the Affresh pellet with no clothes and run the machine through a cycle. Also helps with any stagnant water smells. Have you cleaned out your pump lately. Put the pellet inside the machine, not in the soap dispenser.
Pl give me a good rating for the free help, thanks.
Posted on Jun 03, 2010
Smell coming from AWN32 speed queen top loading washer
All washing machine "smell" when the lid is left closed for more than one day. If it is really bad it might be something inside the body of the machine or something caught under the agitator.
Inside the body work. Unscrew the three screws at the bottom of the front panel. Lift the bottom of the panel forward and up. Remove. Make sure the machine is unplugged and switched off before reaching into the body work. Look for something "smelly"
Agitator - switch off and unplug - depending on the model unscrew the top cap on the agitator. Some models do not have an screw cap although it might look so. Reach with both hands into the machine and grab the agitator at it bottom flanges hands opposite each other. Pull up hard - it does not let go easily- make sure it doesn't have a top screw cap. To replace just push back until it clicks or replace and tighten the top cap.
Dec 13, 2013 | Speed Queen Washer Top Load AWN432
How to clean filter on wf100
There should be a flap or door on the bottom on the front of the machine. Open the flap or door and unscrew the filter.
Jul 31, 2011 | Hotpoint Aquarius WF000 Front Load Washer
I have a hotpoint Aqrius wml 560. Everytime I put the washing machine on there an dreadful smell come's out from machine. I have tried putting machine on hotest temp empty but still I get this...
Locate the area from where the smell is emiting. You need to see the rear bottom to see the pump and the motor. Check after the smell is noticed - remove the power and touch the pump and motor - If so there is fault on one of them. If not check the capacitor to the motor, the program controller unit. Your observation is most important to confirm.
Jul 09, 2011 | Washing Machines
Hi, how do you clean filter in Hptpoint Aquarius WMF540 washing machine? Where is the filter? Thank you, Davorka
under cover bottom ...unclip then you will see a cap you then unscrew... have a baking tray under machine first as water will come out..
Jan 23, 2011 | Hotpoint Washing Machines
My Hotpoint WMA31 will not drain - the smell is
check for blockage under cap bottom of washing machine
May 26, 2010 | Hotpoint WMA31 Front Load Washer
How can I unscrew the drain outlet at the bottom front of my Hotpoint WT540? Our machine has completed a wash and drained, but isn't spinning. The door light flashes when I try and run a spin. I decided to...
Apr 02, 2010 | Hotpoint Aquarius WD63 Front Load...
Bosch classixx 1200 express smells
If you have not already done so, then check and clean the filter.
This is usually located at the bottom front right of washer behind a drop down flap or cover.
Unscrew anti-clockwise to remove and clean.
Please rate my solution.
Thankyou.
Jan 28, 2010 | Bosch Washing Machines
A strange smell is coming from the drum
go on espares and buy the limescale and detergent remover this should clean the machine out
Jun 28, 2009 | Hotpoint WMA54 Front Load Washer
Problems draining an aquarius wf445
hi if you pull out the machine so you are faceing the back of it there is a flap at the bottom unscrew the 4 screws if you can lean the machine forward it makes it easier,then with a cross head screwdriver undo the big jubilee clip from the hose coming from the bottom of the machine you will find a plastic ball inside pull that out and then clean the filter replace in reverse order hope that helps.
Nov 30, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
My hotpoint aqualtis smells awful. the smell is coming from the drum. we have taken the pump off and although this smelled it was nowere near as bad as what is coming from the drum.
run a large load with no clothes and no soap. use hot water and a full gallon or more of bleach. do an extra rinse to make sure all the bleach is rinsed out before putting clothes in it again.
Jun 28, 2008 | Hotpoint Washing Machines
Washing Machines Logo
50 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
