Question about Whirlpool GS6NBEXR Side by Side Refrigerator
Whirlpool side by side GS6NBEXRS01
Makes ice and dispenses water fine, but will not dispense the ice - maybe motor went out? Is only 1-1/2 years old, when you depress ice dispense pad, it hums slightly, but no indication it's going to dispense ice. No sound of motor working - shouldn't this last longer than 18 mos.? Have cleaned out bin and made sure blades were not obstructed.
  • 5 more comments
  • mikereap Nov 19, 2007
    I have the same problem with my side by side whirlpool GS6NVEXSL water dispences fine makes allot of ice but will not dispence the ice. it hums opens the door but nothing comes out.Hopefully someone can advise on problem only had the fridge for 14 months and of course its warrnety expired after 12 months
  • rmclendon Dec 15, 2007
    same problem with my side by side. Water works, ice makes fine, but will not dispense. Just over one year old.
  • Mike7499 Dec 24, 2007
    I have the same problem, the IR sensor seems to work fine and the pressure switch is working. The dispenser door even opens and closes, so I assume it is the motor. Is it normal for them to only last 18 months?
  • sunmanor Dec 31, 2007
    We have the same problem. Fridge is about 16 months old. Pushed the control to get ice....forget it. Guess it means it's only good for 18 months.....Whirlpool doesn't seem to care. Sent them a note and they said they couldn't diagnose via email. Funny, you all can.
  • Anonymous Dec 21, 2008
    mmY
    I've had this fridge going years now and the ice maker is not working, it makes the ice but when i push the tab to dispense the ice i can hear the motor, the flap opens but no ice. What is the problem? I would love to kow.
  • Anonymous Dec 24, 2008
    What can I say. About 2 years old and having the same syptoms as everyone else. I am going to look for a diagram to see how hard to fix and cost of motor. May try hair drier trick as we had power out for 1 week. I maker messed up for a while so can not remember if it quit working around that time.
My unit suddenly started melting the ice into a solid block all the way through the crusher. It turned out to be the trap door getting hungup from opening too far. There are 2 screws behind he slide out shelf . Remove these and the the icemaker cover rotates to the right. You may have to remove the selonoide to adjust the travel and then reassemble.
Posted on Jun 29, 2012
Ice maker got stuck, took it out and get rid of ice build up, put it back turn water supply on, still not making ice. did i missed anything
Posted on Jun 30, 2010
We had this problem after a power outage let the freezer thaw a bit. Some water had gotten down to the auger motor, freezing it up. Revoved the cover underneath the auger motor (bottom of a shelf inside the door) and hit it with a hair dryer for about 30 seconds. Worked like a charm.
Posted on Jan 21, 2008
  • 291 Answers
If nothing is blocking ager .. sounds like motor bad or something binding it up. If you took in out and cleaned all ice out and still dont work with no ice.. sounds like motor ..if it hums power is to motor
Posted on Aug 29, 2007
If the motor is humming, Take the ice bin out, rinse the bottom shaft connection with warm water, it may just have ice build up.
Posted on Jan 11, 2008
SOURCE:
When I manually add water to ice maker it works. Door water dispenser works. Whirlpool GS6NBEXRS01 Side by Side Refrigerator
You have a bad valve or timer , if the ice maker empties the ice tray then its more than likely a bad valve . should be under the front or back of the refidgorator .
Jan 24, 2011 | Whirlpool ED2FHSS Side by Side...
My Whirlpool Gold side-by-side refrigerator GS6NVEXSL00 wont give me the ice out the door. It makes ice, but when I press the button on the door nothing happens. Seems like the button went out. HELP!
Does the water dispenser work? Is there a light at the dispenser panel, does it light? Do you hear any noises or motors running when you actuate ice dispenser? You could have a power issue for the dispenser. Some newer whirlpool models have an issue with the wiring leading into the door at bottom being so securley fastened to frame, the lack of movement forces the wires to bend, and in time break, with door usage. If water dispenser works, and you hear no sounds when the ice lever is actuated, then you have a problem with the dispenser panel circuit board. if water works and you hear some sounds when ice lever is actuated, such as a loud popping noise, then you have a bad ice dispenser auger motor, not churning the ice out of the bucket.
Mar 18, 2010 | Whirlpool GS6NVEXSL Side by Side...
Whirlpool Water Dispenser not working and not producing ICE.
check the fresh water solenoid on the back of the unit theres a screen in the water line to it that maybe clogged also crak the line lose gently to isure water is passing through it if not? then change the water solenoid
Jan 15, 2010 | Whirlpool GS6NBEXR Side by Side...
Ice Dispencer is not releasing ice (cubed or crushed)
I would remove the ice bucket in the freezer and make sure that nothing has gotten between the motor and the auger that pushes the ice forward.
Jul 09, 2009 | Whirlpool GS6NBEXR Side by Side...
I have a 12 year old Whirlpool side-by-side refridgerator (ed20db) with water and ice dispenser. I have not used the water dispenser for years, but for some reason when I hit the lever yesterday, it did...
you have a possible water valve that is not shutting off all the way on the water dispensing side, it has 2 coils, one for ice and one for water. the other possibility is the dispenser tank is frozen, from being too cold in the refr. section and thats causing water pressure to continue running even when not pushing the lever. let the unit warm up slighty on the refr side and see if you can get water to flow properly.
if not working after warming up, then you might have to replace the water inlet valve.
Dec 29, 2008 | Whirlpool GS6NBEXR Side by Side...
Ice/water maker won't dispense
Icemaker only dispenses crushed ice even when in cube position. Water/light work fine. Have already replaced control module circuit board.
Nov 17, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
Whirlpool Side by Side Refigerator won't engage ice dispenser.
Could be that the auger in the ice bucket is obstructed or broken, or the auger motor is bad.
Nov 02, 2017 | Whirlpool GC5SHEXNS Side by Side...
Ice dispenser not dispensing.
the hex wrench your after is know as nut ddriver screw drivers / you can remove the auger assembly quite easily the activation switch is located in the door assemby. be carefull the auger is powerfull.
Aug 22, 2008 | Whirlpool GS6NBEXR Side by Side...
Whirlpool GS6NBEXR Side by Side Refrigerator Logo
1,457 people viewed this question
Top Whirlpool Refrigerators Experts
Bruce Denton
Steve Allison
Steve Allison
Norman Worley
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
