Question about Samsung Series 5 I5/1.7 13.3 4gb 500gb W7hp 64 NP530U3CA01US
Reset CMOS on a Samsung np530
"F2 setup" "F4 recover"not repsoning stuck in a loop start re-start
  • td1967
    td1967 Jul 18, 2013
    i have sorted the ploblem i removed the coms battery that was well hidden.
  • td1967
    td1967 Jul 18, 2013
    td1967i have sorted the ploblem i removed the coms battery that was well hidden.
2 Suggested Answers
  • 6771 Answers
SOURCE: when i turn it on
The hard drive probably is the problem, if the software is corrupted windows will not start, if you have a start up disc try re-installing windows, if that and does not work have the hard drive checked.
Posted on Dec 26, 2010
How to reset cmos on the motherboard for samsung laptop 500P4C. it is not responding to F2,F4 or even F10
If you get writing on the screen, there are no issues with the BIOS. Try a different method.
Nov 17, 2014 | Samsung Computers & Internet
Start BIOS/Reset Samsung ATIV One 7
I would recommend removing the CMOS battery inside the pc and replace it again to reset the CMOS, and then Reboot pc and while rebooting, keep tapping F4. MAKE SURE YOUR PC IS OFF BEFORE REMOVING CMOS BATTERY. ( CMOS battery is a round wafer battery of 3 volts DC) This may fix your issue.If you are uncomfortable doing this, get a PC Tech
Aug 10, 2014 | Samsung ATIV One 7 DP700A3D All-in-One...
Showing (F2) for Set up,(F4) for Recovery
This indicates hard drive issues, remove hardware and reseat back into place, sometimes this will start it, if no change! a recovery cd is the best option if you made one because it will work or not. If you have your owners manual review the recovery process just to be certain, other wise a computer repair shop is the next step.
Apr 04, 2012 | Computers & Internet
Showing F2 for setup,F4 for Recovery
Did this just all of a sudden start happening or were you doing something that caused it?
Where do you reset the cmos/bios on a prespa 1 mtherboard by acer aspire 3680 laptop.
For enter bios setup press f2 ,/f4 /f9 or dell.
Now choice fale save mode default.press.F10 for save .
Hope this helps.
Contract for further instruction.
Oct 29, 2011 | Acer Aspire 3680 Laptop
HOW DO I BATCH OUT
GETI CHECK SALE [F2]
PAYROLL/BUSINESS [F3]
MORE VERIFY ONLY [F4] Press the Purple key below the More option. GETI CHECK SCANNER MENU [F1]
BATCH MENU [F2]
REPRINT [F3]
MORE VOID [F4] Select Batch Menu [F2]. ERASE BATCH [F1]
CLOSE BATCH [F2]
HISTORY REPORT [F3]
BATCH REPORT [F4] Select Close Batch [F2]. KEY IN MANAGER PASSWORD
AND PRESS ENTER Press [1] and [Enter]. ARE YOU SURE? CLOSE BATCH [F3]
CANCEL [F4] Select Close Batch [F3]. DIALING . . . The terminal will dial in to close the batch. Once closed, the terminal will print the batch report indicating Batch Accepted.
See example below. BATCH ACCEPTED
EXIT [F4] Select Exit [F4] to return to the menu.
Oct 19, 2011 | VeriFone VX510
Mainboard GA-G31-ES2C Warning: Backup BIOS checksum error BIOS Auto-Recovering...
If you have reset the CMOS memory you need to go into the BIOS setup screen and reconfigure the BIOS. To do that you need to press a key while the computer is booting. Usually F2 but can be other keys. It should tell you on the bottom of the first screen which key to press to enter BIOS setup.
If you don't know the settings the should be one for optimal defaults - use that one. You will also need to reset the time and date.
Save, Exit and re-boot and everything should then work.
During the boot process you will see on the screen to press delete to enter setup
Jul 23, 2011 | Gigabyte GA-G31M-ES2L Motherboard
When i turn it on it makes a beeping noice then says at the bottom F2 for setup and F4 for recovery when y press F4 it says operating system not found. what do i do?
Dec 26, 2010 | Samsung NC10-14GW Notebook
Samsung Series 5 I5/1.7 13.3 4gb 500gb W7hp 64 NP530U3CA01US Logo
477 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
