Question about Home Security
Glidermatic gts problems:My glidermatic gts door doesn't open with the remotes, after a power failure period. 2 beeps occur when remote is pressed and the sensor lights on the door unit comes on, but there is no movement at all from the system.
  • 7 Answers
SOURCE: sears garage door opener problems
check the motor reset or power connected to the motor and check the chain or screw to see if it is in a bind.
Posted on Sep 25, 2008
  • 6 Answers
SOURCE: Simon 3: A remote window sensor downstairs creates a constant Low Battery beep/message.
you have to run a sensor test so the system will recoginize the new battery, open keypad cover type in your code press test till it says "sensor test" once it runs through all points press done, now reset your panel disarm code disarm
Posted on Oct 17, 2008
SOURCE: flashing green light on Sears garage door wall opener HBW0777 1/2
Same problem - The flashing wall button indicates the remotes are locked out. I fixed mine by pushing the green button on the back of the opener. I did nothing else , just left the LED time out.
Posted on Dec 13, 2008
SOURCE: Liftmaster 1/3 HP - humming, but does not open.
It's the gear drive. There are kits online for about $40, if you're semi-handy you can replace it yourself. Search for liftmaster replacement parts.
Posted on Dec 16, 2008
  • 899 Answers
SOURCE: Garage door only opens with wall unit
a component in the wall unit is failing , that makes the conection happen when the remote signal is recieved , ( it is recieving the remote signal but not sending it out to the control circuit for the motor )
Posted on Dec 29, 2008
Factory remote start wont work. hit button horn bbeps all lights and radio come on. when horn beeps second time car wont crank as it always has in the past
Ford Keyless Remote Car Starter fix - YouTube
? 5:14
https://www.youtube.com/watch?v=fQHb0mU0rvI
Jun 24, 2012 - Uploaded by mitch cox
I bought a 2010 Ford Raptor my remote starter won't work? when I press the .... 2013 lincoln navigator, 2-Way Remote StartSystem and i press button ... a Ford OEM 1-Way 100 Series Keyless Remote Start (CM5Z-19G364-A).
1998 to 2008 Lincoln Navigator Factory Transmitter Remote ...
? 3:00
https://www.youtube.com/watch?v=sLMN34KN3nY
Nov 2, 2012 - Uploaded by Lessco Electronics
1. Close all doors and then open drivers door and press the UNLOCK button on drivers door panel while door ...
2008 Lincoln Navigator Remote Start Accessories ' Th
Dec 12, 2015 | 2008 Lincoln Navigator
Viper 479V Viper Responder Remote how to program
open the door, turn the key on, press valet switch one time and press it again and hold it until alarm beeps if it dosent beep it means that alarm hasn't read the door open if it beeps press lock on the remote and it should beep again and its will be set. (if the alarm dosent beep you have to put the door trigger wire (green) to ground and repeat steps from beggining
Apr 02, 2014 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Keyless remote
hi Alan
what procedure you are doing for remote matching?
try this one and let me know.
1 Unlock the car, get in and close the door
2 Switch ignition on
3 Press the door lock button on the dash to lock the car
4 Press and hold the door lock button on the dash, the alarm will beep
5 Keep holding the door lock button on the dash, press and hold the lock on the remote,
the alarm will beep
Repeat (5) for the other remotes,
6 leave the door lock button on the dash, the alarm will beep, switch ignition off
Feb 13, 2014 | Suzuki Cars & Trucks
How to program 473v remote
Open the door, turn the key on, press valet switch one time and press it again and hold it until alarm beeps if it dosent beep it means that alarm hasn't read the door open if it beeps press lock on the remote and it should beep again and its will be set. (if the alarm dosent beep you have to put the door trigger wire (green) to ground and repeat steps from beggining
Sep 16, 2013 | 5101 LE 1 Way Car Remote Starter System
Replaced batery in key fob and now there is no connection between fob and security system...I can lock and unlock doors with the key and I can start car ...fob doesn't work; does not lock or unlock...
reprogram the remote transmitter. first leave driver door open all other doors closed,key removed from the ignition switch. insert key into the ignition switch,then remove it.press lock and unlock on the vechicle door lock control switch at 1 second intervals 5 times. close and repoen drivers door.press lock and unlock on the vechicle lock control switch at 1 second intervals 5 times. insert key into ignition switch. switch ignition on and off twice to program a remote transmitter code whilst erasing the original codes or three timre to check how many remote transmitters are currently registered.remove key from the ignition switch.system should now lock and unlock.twice to indicate programming mode or one to four times,slowly to indicate number of remote transmitters registered.for the solara press and hold lock and unlock remote buttons together, press lock remote button for a second period of 1 second. system should now lock and unlock vechicle.once to confirm, twice to indicate registration has failed.if required repeat button procedure to program remaining remote transmitters.note to exit programming mode close drivers door or insert ignition key.maximum of 4 remote transmitters can be programmed.if akk failed let dealership reprogram remote transmitters.
May 18, 2011 | 1999 Toyota Camry Solara
Hi, My glidermatic gts keeps going open once it reaches the bottom, everything works; it?s just it keeps going open. I have to close open, close open until it stops in the close...
The Glidermatic GTS 2000 has limits that are stored electronically.
The problem you have is the closing limit is set too low and needs to be adjusted so the door is just resting on the concrete - currently it is trying to drive through the concrete, the motor detects and obstruction and reverses.
If your Glidermatic GTS 2000 was supplied & fitted prior to April 2010 you can download the 'Limit Setting' procedure on the Gliderol website. If the unit was installed after April 2010 it MAY have a revised PCB known as the NGTSv2 PCB. Contact your local branch for limit setting procedures as they are not yet available to download online.
The combination of a mechanical door and electric motor means periodical adjustment is required to esnsure the travel limits and - most importantly - the sensitivity is set correctly. A service to your DOOR is strongly recommended every 12 months.
I hope this helps
Jan 03, 2011 | Garden
I changed battery and now it dosnt work
You lost your program of the key module follow these instructions.
To Program a Remote for a VW
Put your good key in the ignition and turn to "ON", do not start the engine. Make sure all the remotes you want to use are present because they have to be programmed at the same time.
- Close the door and insert key #2 into the driver's side lock. Lock the door.
-Within 5 seconds of locking the door, press unlock 2 times on the new remote, key #2.
-(if this is remote #3, press unlock 3 times. if this is remote #4, press unlock 4 times).
-If there's a chirp or beep do not press it again. This means that the car has recognized the new keyless entry remote.
- Repeat with other remote or unlock the car and turn off - done.
Mar 23, 2010 | 1996 Jaguar Vanden Plas
Doors only with ignition key
Step 1 Close all of the doors on your car, including the trunk and the hood. Remove your key from the ignition.
  • Step 2 Open the trunk and then get in the car. Close the driver's door and put the key in the ignition.
  • Step 3 Turn the key one click to the right, then back to the off position. Repeat this process quickly five times, ending in the off position. This process must be completed in 10 seconds. If successful, you will hear a beep.
  • Step 4 Open and close your driver's door and press any button on your remote to begin the programming process. The red light on your remote will flash on and off.
  • Step 5 Open your driver's door and get out of the car to close the trunk. Close the driver's door and wait for the keyless remote to emit another short beep. The programming is now complete.
  • make sure you write a review for me ant voet if I was of any help. Thanks Ivan
    Feb 03, 2010 | Vehicle Parts & Accessories
    Home Security Logo
    1,618 people viewed this question
    Top Home Security Experts
    Lawrence Oravetz
    Are you a Home Security Expert? Answer questions, earn points and help others
