Question about RCA P52926 52" Rear Projection Television
Rca 60'' p60928
Hi , i have a rca 60'' projector tv.i need a blue lamp. model of the tv is a: rca P60928 can you tell me where i can have one a best price. p.s. i whant to know how i can adjust the black color because i can not see all the detail on black thing. thanks
  • 398 Answers
The set does not have a blue lamp. The set has a blue picture tube. I have found that the best RCA parts distributor is Union Electronics at 1-800-648-6657. The picture tubes in projection sets are very fragile and dangerous to handle. The new picture tube will come dry, so the lens assembly and seal will have to be assembled onto the new tube and then filled with fresh coolant. The set will then need a complete realignment, everything from screen and focus voltages, bias and drive, yoke and ring position to convergence circuits. If you have no experience in any of the above, do not attempt to replace a picture tube. Allow a qualified tech to handle it for you.
Posted on Aug 28, 2007
How do I change my projector lamp?
  1. Front Projector
    • 1 Disconnect the power cable from your projector. Allow it to cool for 30 to 60 minutes. Lay the projector upside down on a table.
    • 2 Remove the lamp cover, typically located on one of the rear corners of the projector's underside. Depending on your projector, you will either have to loosen a few Phillips screws or press on one or two plastic release tabs to remove the lamp cover.
    • 3 Loosen the screws holding the lamp assembly in place. Grab the assembly by the handle and slide it out of the projector.
    • 4 Slide a new lamp assembly into the projector. Don't touch the glass on the bulb because it will damage the bulb. Tighten the retaining screws on the lamp assembly and replace the lamp cover.
    • 5 Turn the projector right side up and reconnect the power cable. Power on your projector.
    Rear Projector
    • 6 Unplug the TV from the outlet. Let it cool for 30 to 60 minutes.
    • 7 Remove the lamp cover. On most rear projection TVs, the lamp cover is located on the right or left side of the TV's rear panel. Remove the cover by loosening the screws and pulling the cover away from the TV. Certain manufacturers, like Mitsubishi, have the lamp cover in the front of the TV, near the left speaker. To get to the cover, you must first use your fingers to pry off the front panel below the screen, revealing the speakers and lamp cover. Loosen the screws on the cover and pull it away from the TV.
    • 8 Remove the lamp assembly. Loosen its screws, grab the handle and slide it out of the TV. If you have a newer Sony model, there are no screws. Instead, press the release tab to unlock the lamp assembly and slide it out of the TV.
    • 9 Slide a new lamp assembly into the TV. Don't touch the glass on the assembly, as the oils in your fingers will damage the bulb. Tighten the screws or pop the retaining tab into place.
    • 10
      Replace the lamp cover and front panel, if necessary. Plug your TV back into the electrical outlet and power it on.
Tips & Warnings
  • Touching the lamp assembly before it has cooled can cause a nasty burn.
Read more: How to Change a Projector Lamp '
Apr 11, 2012 | Office Equipment & Supplies
How do you tell the bulb is bad
Testing suspect/broken lamps
1. As before, with lamp replacement, allow approximately 45-60 minutes cooling time before accessing the projector.
2. If there is no output from the lamp, ensure that all internal, external and trip fuses are intact and filter covers are correctly fitted.
3. If another projector of the same make and model is available, change over the lamp assembly to confirm that the lamp is at fault.
4. If the projector is now working, a replacement lamp should be ordered from a recommended supplier.
5. If the projector still fails to work, check that the manufacturer's warranty has expired and, if so, contact TRS and report the fault as normal.
6. When replacing a lamp and it is found that the glass lamp housing has shattered, be aware that lamps can contain a small amount of mercury vapour. The room should be evacuated for a minimum of 30 minutes prior to any further remedial work being carried out.
7. On returning to the room, do not attempt to clean out the shards of broken glass. The projector should be carefully placed in a robust plastic bag and sealed.
Feb 26, 2011 | NEC LT 240 Multimedia Projector
Hi i have a hitachi tv, serial no:v71100318. the tv hasnt worked properly for the last few weeks, i switch it on the standby light is green blue screen comes on then the screen goes off and standby light...
sorry but the serial number doesn't tell anything about a set, the model is what you need first, it could be lamp but don't know the model
Feb 13, 2011 | Hitachi TVs
My RCA p60920bl suddenly won't power on.
You probably need a new projector bulb. Google up your model and buy the best warranteed one you can find. Buy a "caged assembly" and not just a bare bulb.
Then unplug your tv and get a screwdriver. Follow your model's instructions and just snug down the electrical screws. Do not overtighten them.
Then consult your manual on how to reset the lamp timer so it knows you put a new bulb in and fires up from the first try.
Treat yourself because you've just saved yourself a trip from a repairman!!
Aug 12, 2010 | RCA P60920BL 60" Rear Projection...
look for the model number on back of your tv then go on google and type brand and model and part you are looking for e.x Lamp
Feb 08, 2010 | RCA R52WM24 52" HDTV Projection Television
Want play no sound or picture
If you do not get snow for a picture then it is more than likely a power transformer and you might have to look around to find one.
Aug 06, 2009 | RCA P60928 TV
Hitachi replacement bul
Let me know exact model of your Hitachi TV to check bulb availability in parts stores.
Bulb replacement is easy process and mostly it is written on owner's manual of TV.
Please use "add a comment" button to intimate model number of TV.
Thank you.
Apr 06, 2009 | Hitachi REPLACEMENT LAMP, Projector Lamp...
Kf-42610 blue hue and blue dots on screen
Hi Guys
The Blue dots or discolouration you are seeing is due too the Blue LCD screen having cracked from excessive heat. This normally happens when you have a power failure while the Television was on. This obviously because the Blue LCD sits next to the lamp - the main cause of heat. The correct part number on the 60" is A-1086-952-A. It is very, very ,expensive.
Sorry to have been the bearer of bad news. Good luck : )
Aug 29, 2007 | Sony XL-2100U Projector Lamp for...
RCA P52926 52" Rear Projection Television Logo
89 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
