Question about Health & Beauty
Sharper image luggage scale
Model TS1191 digital luggage scale. will not convert from kg to lbs. I have and am following directions. SI live chat says from old company prior to 2009. could a new battery possibly solve this problem?
SOURCE: Scales show weight in kg. How to get them to show lbs.
Body Fat Monitor/Scales: TBF-611, TBF-612, TBF-621, TBF-622, BF-541, TBF-560, TBF-572. UltimateScales: 2000, 2001, 2001T. BF-662, BF-555, BF-556, BF-558, BF-559, BF-625, BF-626.
Press the Set and Up Arrow buttons at the same time. Release the buttons, the display will flash. Press the Arrow button to cycle through each weight mode until just the mode that you require is displayed. Then press Set. The display screen will flash to confirm your selection and store in memory.
Note: If weight mode is set to pounds or stone-pounds, the height programming mode will be automatically set to feet and inches. Similarly, if kilograms is selected, height will be automatically set to centimeters.
Posted on Mar 14, 2009
SOURCE: need to reset
just keep pressing the cancel button for 10 seconds,,, it will start blinking,, then reset it to your desired point
Posted on May 15, 2010
joeguest2
  • 2080 Answers
SOURCE: I lost my instruction manual
Look on the bottom of the scale for a sliding switch to alternate between Kg and lbs.
If you do not see one then remove the little cover and check inside the battery compartment for it.
Good luck.
Comment back here and rate with 4 Thumbs up if this was at all helpful.
Thank you.
Posted on Feb 23, 2011
krb55
  • 604 Answers
SOURCE: when I check my scale with 100lb weight it reads
you need to turn the calibration setting to 100 lbs, then it will be calibrated
Posted on Mar 17, 2011
jas247
  • 844 Answers
SOURCE: I have a healthometer scale,
Welcome to FixYa!
1. The Platform on which you stand may be hitting the base of the scale. The corner that your heels are on is adjustable from the bottom of the base. Turn the scale over on its side and remove the round plastic foot. Insert an Allen wrench into the now exposed hole and turn the screw to raise that corner of the platform.
Note: If you adjust one corner, be sure to adjust the opposite corner to keep the platform levelor.
2. Look under the base of the scale and make sure no foreign item is lodged into the base and that no parts have come out of the base.
Thank you for using FixYa!
Jas247
Posted on Apr 19, 2011
Tn425 sharper image bathroom scale how to change from kg to pounds?
There is a small finger slider switch underneath the scale, setting the scale to either pounds or kilograms.
May 07, 2014 | Terraillon TFX70 Sharper Image Body...
What is the air pressure for shocks on a 97 flhtc
I do not know but you could call a Harley Service department or better go there in person and ask.
Recommended Suspension Air Pressure: FLHX, FLTRX, FLHR/C
Solo rider up to 150 LB up to 68KG10-20 0 psi0kPa
Solo rider up to 150-200 LBup to 68-91 KG0-10 psi0-69kPa
Solo rider up to 200-250LBup to 91-113KG10-20 psi69-138kPa
Solo rider up to 250-300LBup to 113-136 KG20-30 psi138-206kPa
Solo rider up to over 300LBup toover 136KG30-50 psi206-345kPa
Solo rider with capacity luggage of 40 lbs (18 kg) up to 150LB up to 68KG 10-20 psi 69-138kPa
Solo rider with capacity luggage of 40 lbs (18 kg) up to 150-200 LB up to 68-91 KG 20-30 psi 138-206kPa
Solo rider with capacity luggage of 40 lbs (18 kg) up to 200-250 LB up to 91-113KG 30-40 psi 206-276kPa
Solo rider with capacity luggage of 40 lbs (18 kg) up to 250-300LB up to 113-136 40-50 psi 276-345 kPa
Solo rider with capacity luggage of 40 lbs (18 kg) up to over 300LB up to over 136KG 50 psi 345 kPa
Rider plus passenger ALLWeights 40-50psi 276-345 kPa
Maximum GVWR ALL Weights 50psi 345 kPa
If Tour-Pak is installed, add 5-10 psi (34-69 kPa) to shock pressure.
Do not exceed 50 psi (345 kPa) suspension pressure.
Apr 17, 2014 | 2001 Harley Davidson FLHT Electra Glide...
How do you change from kg to pounds?
To change to lbs. Press button to turn on, while it is flashing, you press button again, that will change it to lbs. You must do it while it is flashing.
Mar 30, 2014 | Rapala 50lb Digital Scale
On my "Ideaworks" wireless electronic display
After playing with the remote on this scale for about 30 minutes, I finally found out how to change this display from kg to pounds or stones. Since this scale doesn't come with an instruction manual, I know a lot of people are totally lost. OK, first click the user button once, so that the weight and goal weight show. Then hold down the clock/set button. After a few seconds the kg on the screen will start blinking. Then use your arrow buttons to switch to stones, then to pounds. The lb will show at the top of the display above where the kg was. You can also set your goal weight by pressing the set button and scanning through after setting the lbs setting. Hope this helps!
Aug 22, 2011 | Jobar International Ideaworks Remote Read...
When I check my scale with 100lb weight it reads 100 kg or 220 lbs??
Mar 17, 2011 | Detecto Model 6855 Bariatric Scale
How do i chang kg to lbs
Please log on to .Eng Net tools. You an download a free software that can find great use to convert all your requirements.
 the link is as ;  http://www.engnetglobal.com/
also 1 KG= 2.20- lbs ( 2.65lbs in another system)
Please vote if helpful
Sep 02, 2010 | Conair WW73 Electronic Body Fat/Hydration...
Tanita, the Ultimate Scale
The scale may have instructions on the bottom of the scale. (Example for the Tanita: The Ultimate Scale w/ the body fat analysis). The instructions on the back state the following steps: Step 1: press both the "Set" and the triangle buttons. Step 2: press the "triangle" button until you select the appropriate weight measurement (a) kilogram, (b) stone lbs or (c) lbs. Step 3: press the set button.
Oct 31, 2008 | Omron HBF-400 Fat Loss Monitor with Scale
Weight watcher scale not calibrating weight correctly
Press the scale once with your foot. All screen options should display to initialize and then go to 0.0. Now step on the scale. It should read out your correct weight. If not, first remove and replace the battery for reset. If still not, replace the battery. If still not it's ready for return or replacement. Hope it works! Dave - CA
Aug 12, 2008 | Irons
Health & Beauty Logo
228 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
