Question about Casio Watches
HOW TO REMOVE ETA G10.211 QUARTZ MOVEMENT CROWN AND STEM FROM WATCH CASE
s4u311
  • 813 Answers
SOURCE: how do i remove crown?
hummmmmmm
u need to go experts of watch reper i think its its problem in watch curcuit thats y this happen
& thnx useing fixya
Posted on Mar 28, 2008
VOTIT
  • 2071 Answers
SOURCE: Removing the crown
The video i want to see you,is using older kind of watch,screwing before he can pull the crown ,the new model watches now like your Tag Heuer is pushing, use a needle to push, while pushing the stem lock you pull the crown .That's why ill tell you in advance so you aware.I know because i'm a watch technician working in rolex before...
remove the crown
if i helped,please,click FOR RATING .It is the only way i get paid for my works also,please consider leaving feedback..
Regards,
VOTIT
Posted on Sep 08, 2008
  • 5 Answers
Hi, on the back of the movement there should either be a screw or a dimple in line or next to the line of the stem. If a dimple, press in with a pin or similar sturdy tool and gently withdraw the stem. If a screw, only one turn should be enough to release the stem
Posted on Nov 18, 2008
  • 108 Answers
SOURCE: How do I remove the crown/stem.
To remove the stem you must first loosen the set lever screw, then you can pull the stem out.
You only need to turn the set lever screw a couple turns to release the stem. Some movements use a button instead and in that case you would simply push the button down lightly with a pointed tool and while holding the button down pull the stem out.
For watches with one-piece cases where the movement comes out the dial side and the case has no removable back, you will not be able to get at the set lever screw. For this type of watch you must grasp the crown firmly and pull it out, or use plastic or soft brass tweezers to get behind the crown and pop it off. These watches have two-piece stems that have male and female ends that snap together. Then remove the bezel and let the movement come out into your hands. Then remove the hands and the dial and put the movement face down into a movement holder.
Posted on Apr 04, 2010
Testimonial: "thanks"
  • 101 Answers
SOURCE: I want to remove my
you will need to open the watch back and look at the movement near the where the stem enters the movement (you need to be very cautious doing this ) near the the stem you should see an arrow pointing to small hole you will need to use a pin or a need to place inside and push down. In the meantime you will have to pull out the watch crown and stem slowly . Sometimes the holes are not marked but are placed very close to where the the stem enters the movement.
When you are done press the same release tab ( the hole) and slide the crown all the way.
Posted on Oct 20, 2010
Should i pull the crown to save battery if i store my quartz watch for a few months
I don't think storing a watch with the crown out accomplishes much. That I am aware of, pulling the crown out does not break the electrical connection between the battery and the watch. At least in looking at quartz movements, I don't see any electrical apparatus that insulates the crown in any way so that it could act as a switch. I think that in quartz watches that hack, pulling the crown out mechanically disengages or interferes with the drive train, but it doesn't stop the oscillator or stepper motor from running.
With quartz movements, at least those I have seen the internals of, (most ETA and ISA designs, some Rondas, a few Seikos), pulling the crown to the setting position does one of two things:
1) On better, jeweled movements - it breaks contact between the coil and battery, thus stopping the motor. The oscilator continues to be powered, but most of the current consumption is from the motor. These pulling the crown out does save battery life. Or,
2) On cheaper non-jeweled movements - it blocks the rotation of the second hand gear, and stalls the motor. These are observable by a "twitchy" second hand when the stem is out. This method actually kills the battery faster, as a stalled electric motor draws more current.
May 08, 2011 | Watches
How do i remove crown?
hummmmmmm
& thnx useing fixya
Mar 28, 2008 | Tag Heuer Formula 1 CAC1111.BA0850 Wrist...
How do you remove the crown to take the movement out of the case
Except you are watch repairman, otherwise you can't do it by yourself at home. If you use force to pull the stem/crown out of the case, you will damage your watch. After that, putting the stem/crown back in, the watch doesn't work anymore.
Feb 19, 2011 | Watches
I want to remove my quartz movement to dry moisture from inside my watch. How can I remove crown, so that I can remove movement? Watch is old Gruen. Not worth shop repair.
Thanks for contacting FixYa.
It is WAY too risky to remove crown/fixture. Try this instead;
  • Step 2 Lay the watch in a dry place in sunlight and see if the water evaporates on its own. Put a piece of soft, absorbent cloth such as a towel under the watch. If the water inside the watch face is only a fine film of condensation that clears on its own after a short time, you probably do not need to do anything else.
  • Step 3 Seal the watch in a plastic bag filled with unopened packets of silica gel desiccant. These are the packets that come in shoe boxes and other packaged items. You can also use dry rice instead of the silica gel packets. Leave the bag somewhere warm and dry for a few days. The silica gel packets or rice can help draw out the water from inside the watch.
  • Step 4 Direct a fan at the watch or use a hair dryer on the lowest heat setting to blow air on the watch. Alternatively, if you can safely leave the watch on top of a low heat source such as a floor vent or radiator, this can help evaporate the water from inside the watch.
  • Step 5 Obtain the appropriate watch repair supplies. If you need to purchase tools, look for these at a watch repair shop or at a jewelry store. You can also find watch repair tools online. You may need small, fine-tipped screwdrivers and watch openers and closers.
  • Step 6 Take off the back of the watch, as if you were changing the battery. Use care not to scratch or damage any of the mechanisms such as the coil or stem. Let the watch dry thoroughly in the open air until there is no trace of moisture. Reassemble the watch once it is dry and press the seal firmly back into place. If the seal does not fit tightly, you may need to replace it
  • jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
    Best regards. Jewel
    Sep 21, 2010 | Watches
    I have a diesel watch model dz-2136 I need to know how to remove stem
    Thank you for contacting FixYa.
    I dont know why you want to remove the stem but here you go.
    For watches with one-piece cases where the movement comes out the dial side and the case has no removable back, you will not be able to get at the set lever screw. For this type of watch you must grasp the crown firmly and pull it out, or use plastic or soft brass tweezers to get behind the crown and pop it off. These watches have two-piece stems that have male and female ends that snap together. Then remove the bezel and let the movement come out into your hands. Then remove the hands and the dial and put the movement face down into a movement holder. Now you can remove the stem as described above
    Aug 26, 2010 | Diesel Audio Diesel Watch
    Watch is new out of the box. Movement will not start. ???
    mcdevito75 here, If your Wittnauer is a Quartz movement, look for a small piece of plastic, just under the crown (winder) remove this piece of plastic carefully and push the crown back down to start your watch, if it's an automatic movement, try to wind with the stem if you feel a resistance then winding will initially start yor watch by winding with 20--30 winds, if you feel no resistance when winding the simply rock your watch back and forth in your hand, you will detect something moveing inside the watch, this is the counter balance winding the watch, rock the watch back and forth for approx. 30 seconds to start an initial wind.
    Jul 10, 2010 | Wittnauer Belasco 36 Diamond 27 Mm Watch...
    How do I remove the crown/stem to take the watch movement out of the case? thanks Marc
    Apr 04, 2010 | Watches
    Removing the crown/stem of CASIO EF-321
    Other case for a simple Casio quartz watch :
    Jan 15, 2009 | Casio Edifice EF106D2AV Wrist Watch
    Need a new stem. Can I purchase on and get it put on myself
    You have to open your watch and find movement number. Use an eyeglass as the numbers are very tiny. Number is pressed onto one of movement plates and shoud be letters ETA+number.
    When this is done, visit your nearest watchmaker shop and ask for stem for movement ETA+number. Do not tell this is for Ebel or you will be charged accordingly to brand name.
    There should be no problems for supplying ETA stem.
    Dec 04, 2008 | Ebel Classic Wave 9090F249725 Wrist Watch
    Nov 13, 2007 | Tag Heuer Formula 1 CAC1111.BA0850 Wrist...
    Watches Logo
    554 people viewed this question
    Top Casio Watches Experts
    Kazim ERGUNEY
    Kazim ERGUNEY
    Ansel Alberto
    Ansel Alberto
    Are you a Casio Watch Expert? Answer questions, earn points and help others
