Question about Dishwashers
Electra elecst2147 Flashing lights and F5 in window
Hi I have a ELECST2147 and f5 is showing and we don't have a manual can anyone help ??? Thanks
F5 means incorrect temperature maybe caused by the temperature sensor or relay switch. Either way the manufacturer recomends a service call from a qualified repair agent.
Dec 02, 2013 | Computers & Internet
Why is my washing machine flashing f5
http://www.hotpointservice.co.uk/hs/pages/content.do?keys=FAQ:ERROR_CODES
F05 - Pressure switch jammed on full
All error codes at above link...
May 12, 2011 | Hotpoint Aquarius WD640 Front Load...
Often Flashes F5 shortly after power up and then cannot print or copy
It is copy lamp lighting abnormality. It could be a mulfunction with copy lamp, ccd or the wire harness.
May 11, 2009 | Sharp AL-1217 Copier
F5 Error flashing
Hello sir; The F-5 means the exposure lamp bad, replace it, will take care your problem.
Apr 24, 2009 | Sharp AL-1642CS Copier
Feature light flashing and canceling DND doesn't clear it
Turns out, that particular extension had a voicemail. Not sure how that happened, because it's a shared phone and nobody is assigned that extension.
Jul 28, 2008 | NEC Electra Elite DTU 16D-2 Corded Phone
Flashing light
It sounds as if that particular extension is in Do Not Disturb.
From that phone, try Feature - 69 - Feature.
Feb 25, 2008 | NEC Electra Elite 32D-1 Corded Phone
Nec phone DTU-32D
do you have VM on this system?
Nov 30, 2007 | NEC Electra Elite 32D-1 Corded Phone
Error flashing F5
We had a similar problem where F5 was flashing but the burners actually continued to work. It turns out that this was related to moisture (the problem typically happened when boiling water). Adding a strip of aluminum tape inside the back panel seems to have solved the problem (fingers crossed).
Oct 11, 2007 | Frigidaire PLEF398AC Electric Kitchen...
Dishwashers Logo
110 people viewed this question
Top Dishwashers Experts
