Question about Troy Garden
Troybilt tb4SC I'm working on one of these for a friend and his blower is blowing oil out the breather tube. What needs to be done to correct this problem? Do you have to tear the engine down and replace the breather tube? When I look on parts lists for this blower, I don't see a "breather tube"
trippssmengi
  • 76 Answers
SOURCE: Blowing oil on an 8HP craftsman snowblower
That is a breather tube, I can't picture the motor off the top of my head but that tube is either connected to the valve cover or if the tube seems to go up over the motor then that tube goes down into the motor. If it's the one thats connected to the valve cover then it's possible there is to much oil in the valve box. If it's the one that seems to go up over the top and in then if your just alittle to much over full you'll get oil out of that tube cause that tube sits alittle above the oil level.If your oil level is right on the line then I would run it for a bit then check the oil level. If the level is still good then you should be ok but keep an eye on it if it continues to blow oil out I would take it in to get looked at futher.
Posted on Jan 04, 2009
goldenglove1
  • 144 Answers
SOURCE: What type and grade of oil is required. I have
Any 2 cycle oil will work. Then mix 1 gallon of gas to 1 container of 2 cycle engine, shake well and pour into your blower.
Posted on Aug 10, 2010
  • 27 Answers
SOURCE: HOW MUCH COMPRESSION SHOULD A
Typically you should be looking for around 100 psi minimum.
Posted on Oct 05, 2010
rycgl
  • 1545 Answers
SOURCE: What type oil do I
Your user manual would tell you exactly what to use, if you have it. If you need a manual you can download a free one here, but you will need the serial number of the machine in addition to the model number.
http://manuals.mtdproducts.com/mtd/Public.do?BrandCode=10001&langId=-1
Posted on Dec 07, 2010
  • 2239 Answers
SOURCE: valve breather shots out oil when engine is running
I do not think this is a gasket issue, if the machine has beed tipped up oil will travel up the breather tube and enter the air filter case, over filling will also cause this, if its been tipped it will clear if you run it for a time with the filter off.
Posted on Jul 03, 2012
What size fuel tubing is used on a troy bilt model tb4sc blower?
yes it has and size is like 3/16 outside 1/8 inside
roughly lol
Aug 16, 2014 | Garden
2003 Honda XR 650 R is blowing oil out the crankcase breather hose
Hi, Anonymous and the usual suspects are:
1. Oil tank/system overfilled.
2. Faulty breather valve.
3. Engine breather hose bent, pinched, kinked etc.
4. Air filter has too much "pre-oil".
5. Crankshaft seal failure allowing transmission fluid to migrate.
6. Blow by drain tube cracked/split or filled to capacity.
For more information about your question and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Xr650r Blowing Oil Out The Crankcase Vent
XR650R Blowing Oil The Crank Case Vent
2000 XR650R Service Repair Manual Instant Download Download Manuals... $15
https://www.partsfish.com/page/oem-parts-for-honda
http://mybikemanuals.com/honda/honda-xr-owners-manuals
Nov 21, 2012 | 2003 Honda XR 650 R
2008 Honda CRF 250 R blows oil out of the breather hose
Hi, Devenbandazi and the usual suspects are:
Losing oil from crankcase breather hose 06 crf 250r
HELP NEEDED CRF250 Putting Lots of Oil Out Valve Cover Breather
Honda 2004 CRF250R Service Manual
http://www.partsfish.com/page/oem-parts-for-honda
HONDA CRF250R 2006 Owner Manual
Jul 18, 2011 | 2008 Honda CRF 250 R
What type oil do I need for a TB4SC Troy-Bilt leaf blower? Thanks.
Dec 07, 2010 | Mtd #TB4SC 25CC 4-Cycle Gas Blower
HOW MUCH COMPRESSION SHOULD A TB4SC TROYBILT BLOWER HAVE
Oct 04, 2010 | Mtd #TB4SC 25CC 4-Cycle Gas Blower
My troy-bilt blower/vac is blowing oil out of the carb. what are some things that may cause this? Oil level? How do I know I have proper amount of oil? If I leave the foam filter and the carb cover on, the...
Your oil breather (on the side of the engine opposite the carb) may be malfunctioning/defective allowing the carb to **** oil from it. There is a breather tube that crosses over the top of the cylinder connecting the crankcase( oil) breather to the air filter housing. Check the oil level and the condition of the air filter and esp. the oil breather. It serves the same function as a PCV on a car engine.
Aug 09, 2010 | Troy Garden
Oil blows out of tube
You either have a head gasket going bad or your piston rings are shot which causes air to go down into the crankcase building up pressure which exits through the breather tube.
Jan 31, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Jan 04, 2009 | Craftsman 4 Cycle Blower/Vac
Garden Logo
47 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
