GC11020M.86A.1058.2006.0330.1109 - Computers & Internet
2 Suggested Answers
SOURCE: Please give me information to
http://www.intel.com/p/en_US/support/highlights/dsktpboards/d102ggc2
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Third-Party+Chipset+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+D102GGC2
http://driverscollection.com/?H=D102GGC2&By=INTEL
Posted on Jul 01, 2011
Testimonial: "Thanks.Your solution is very helpfull.I have fixed my problem."
Actualizacion de BIOS SA86510A.86A.1024.2006.0504
The BIOS number corresponds to Intel Desktop Board D865GSA. You can find the BIOS at following link
https://downloadcenter.intel.com/download/10671/BIOS-Update-SA86510A-86A-
It was released in 2006. The latest BIOS is at following link and it was released in 2010.
https://downloadcenter.intel.com/download/12687/BIOS-Update-SA86510A-86A-
Aug 10, 2015 | Computers & Internet
How to get video and other drivers for gc11020m.86a.1065.2006 ?
Hi! Try this web site, it will help you a lot...
http://drp.su/download.htm
its free!, try to use USB to copy or any peripherals you can use to copy the software, it will help to install the needed driver of the Motherboard.
May 27, 2014 | Intel D102GGC2 Motherboard
Please give me information to get audio and video drivers for my PC.....The details are Board: Intel Corporation D102GGC2 AAD42789-204 Serial Number: BTGC6360083X Bus Clock: 133 megahertz BIOS: Intel...
Jul 01, 2011 | Intel D102GGC2 Motherboard
I bought new 2gb ddr2 with 800 mhz and its not working on my motherboard d102ggc2 can u plz help me with the solution
i guess you did not check the compatibility of the RAMs to your MB limitations....
the only solution is to return the RAMs and get the RAMs that is supported by your MB.....
the MB (D102GGC2) can hold only a max of 533 mhz and max of 1GB each in each slot of RAM....
so if you are trying to install one 2GB card of 800 mhz IT WIILL NOT WORK....
get TWO RAM cards of 1GB each (total 2GB) of RAM.... each of 400 mhz....
hope this helps...
Reg
Suresh
to check what your MB supports, look for the details below...
http://www.intel.com/support/motherboards/desktop/d102ggc2/sb/CS-029352.htm
Intel® Desktop Board D102GGC2 Technical product specification circuit388.gif Product Specification
This product specification applies only to standard D102GGC2 boards with BIOS identifier GC11020M.86A. Changes to this specification will be published in the D102GGC2 Desktop Board Specification Update before being incorporated into a revision of this document.
pdf.gif D102GGC2 Technical Product Specification [PDF]
File Name: D102GGC2_TechProdSpec.pdf
Date: April 2006
This document is an update to the specifications contained in the D102GGC2 Technical Product Specification. It is intended for hardware system manufacturers and software developers of applications, operating systems, or tools. It contains specification changes, errata, specification clarifications, and documentation changes.
pdf.gif D102GGC2 Desktop Board Specification Update [PDF]
File Name: D102GGC2_SpecUpdate03.pdf
Date: November 2006
Apr 27, 2011 | Intel D102GGC2 Motherboard
I have intel Desktop board with the following configuration BIOS : GC11020M.86A.1065.2006.0502.1638 Desktop : D102GGC2 Process : Intel (R) Pentium (R) 4 CPU 3.06GHz Intel (R) EM 64T capable Hyper...
Verify four things:
1. You are not plugged into the onboard video VGA port
2. Onboard video is disabled in BIOS.
3. Power is actually being applied to the card(make sure the fan spins up)
4. Reseat the card and make sure it is seated properly.
Mar 09, 2011 | Intel D102GGC2 Motherboard
Need an instruction manual for Toyostove RCA 86A
http://www.toyotomiusa.com/ownersManuals_portableHeaters.php
Go to this link and look for your heater model. I didn't see one for a RCA 86A though. I did see one for a RCA 36. I also saw a DR 86.
Jan 24, 2011 | Heating & Cooling
Raid 0 help
right click on 'my computer' and choose the 'manage'-option. in the following window, choose 'disk management' from the left. what appears in the lower right window, is a list of installed hard disks and partitions on those disks. the two disks need to be grouped together in a RAID and activated, which can be done by right-clicking the disks you want to configure.
Oct 18, 2009 | Computers & Internet
My computer will not detect both ram ports at the same time.
this your MB grant county intel MB manual.pdf
also check your bios version
CAUTION: if your not confidant to upgrade your bios
leave it to the pro's for 1 mistake renders MB DOA
current bios is 1087 i see dimm2 had issues
BIOS Version 1087
About This BIOS:
 January 30, 2007
 GC11020M.86A.1087.2007.0130.1451
 OPROM Revision:
VBIOS :008.050i.057.000
RAID :4.2.79
PXE :2.16
New Fixes/Features:
 Fixed slow performance issue with 256MB memory in DIMM2.
 Fixed multilanguage display of CPU temperature in setup.
 Fixed issue where certain DVD drive was not detected.
 Add SLP 2.0 support
 Fixed parallel port option missing in ITK.
 Restored IGD register after S3 resume.
 Restored Verb Table after S3 resume.
 Disabled USB OHCI/EHCI MSI capability.
Apr 01, 2009 | E-Machines T5082 PC Desktop
Update my Intel D845GVSR Bios Version to VA84510A.86A.0056.P20, then my USB driver is not working at all.
I followed the suggestion of changing the BIOS configuration to the recovery mode, however one thing was missing - it required a startup disk and I didn't have one. I then changed the BIOS configuration to the config (pins 2 & 3) mode, booted up and went to the BIOS/CMOS setup and a new menu tab appeared called "maintenance". I went to the advance tab and selected USB configuration and, instead of a blank screen, there appeared a selection for USB support and it showed disabled. I changed the setting to enabled and three more lines of information regarding USB came up, but required not further changes. I went to F10 and saved and exited and I now have me USB capability back.
Mar 10, 2008 | Intel D845GVSR Motherboard
Computers & Internet Logo
104 people viewed this question
David Payne
David Payne
