Sharp mx c311 copier
Message says rendering. Cannot clear, delete or anything
SOURCE: Help
Sorry bubbabear 64, you are wrong you need to reset the copier with sim 14, once you have cleared the jam, there is no sensor in the fuser so often if the paper gets crumpled in there is doesnt trigger and sensors so the customer trys to copy again and again, seen it many times.
John Sharp Tech
Posted on Jul 22, 2008
  • 117 Answers
SOURCE: add user codes to a sharp mx-4501n mpf
Try exploring the device's web management interface.
Use your wenb browser to connect to the device's IP address.
the default credentials for the unit are user: admin pasword: admin
if that does not work, try password: Sharp (note that the S is capital and the rest are lower case)
Posted on May 07, 2009
  • 120 Answers
SOURCE: hello i have copier machine sharp mx-450u,with
As a general rule, U machines are not designed to be turned into network printers, that's what the MX-M450N is for. You can put an MX-NBX3 on it, it might work properly and it might not.
The NBX3 can only function properly with a hard drive in the copier, otherwise you're outta luck!!
Your driver type may be wrong. If you are currently using PCL6, try PCL5e.
Other than that, try getting a new driver from the Business Copiers section of sharpusa.com. You may have to see which model will work for you. Look for the PCL driver for MX-NBX3, then look for MX-M450U, then MX-M450N.
Posted on Jul 09, 2009
  • 118 Answers
SOURCE: Changing toner cartridge on copier
Open up the large front door, it will swing downwards. At the top section you'll see four boxes with front handles. Each of the boxes is a slide-out container of toner.
Follow the instructions on the new toner box to prepare it for the copier.
You'll note each toner box has a color designation (on a plastic label just above where you grab). Simply grab the handle on the one you need to replace, pull it out and then slide in a new one.
Also note there are four colors: Yellow, Magenta, Cyan and Black. The LCD screen should indicate which toner bottle(s) to replace.
Posted on Aug 31, 2009
  • 32 Answers
SOURCE: Getting H3 error message Sharp AL 1631 copier
H3 is a heater/fuser problem. Try to reset it by SIM 14. Press Clear , auto exposure, Clear and auto exposure and press copy key. check if H3 has been reset and LED is back to "00".
Posted on Nov 05, 2009
It says Rendering in the spool section of Job Status
I know this is from months ago but I'll post this reply so people in the future can see it:
You probably need to do an image memory clear on the machine to clear out the corrupted print job, delete it from the queue on your computer, then reboot the machine.
To do an image memory clear on a Sharp MX-4111N:
1. double tap the home button
2. touch the firmware version in the bottom right corner(it doesn't look like a button but it is)
3. a number pad will pop up, hit P * C *
4. you should now be in the simulation menu, hit 66, Mono, 10, mono, execute, yes.
Give the machine a minute to process, then it should reboot automatically. If at this point you cannot print, you need to clear the print queue on each computer and do another image memory clear.
Copier Collin Houston TX Copier and Imaging Expert
Sep 30, 2014 | Sharp Mx-4111n Multifunction Copier
How to fix mx-c311 error code e7-06?
The Causes
Compressed image data abnormality. HDD connection trouble when HDD is installed.try to check and see wether connectors are connected properly
. Remedy
If the job at an occurrence of an error is a FAX job, check the FAX PWB. Check connection of the MFPC PWB and the HDD. Replace the MFPC PWB.
Jul 16, 2014 | Sharp MX-C311 Primary Transfer Belt Unit
Why is the DATA light blinking on Sharp model MX-2300N
If something is stuck in the rendering process this will happen. To fix it, first make sure the machine is in copy mode then press:
Pound, Star, C, Star
66, start
10, start
execute, yes...wait for a minute while it processes, then it will reboot.
this will clear out anything stuck in queue
Skelton Business Equipment Houston Copiers
Jun 02, 2014 | Sharp MX-2300N Color Copier
Sharp MX c310 error L4-16
if you are agree to pay my papal than i solve your problem
Paypal account xptareq2000@yahoo.com
Jun 11, 2012 | Sharp MX-C311 Primary Transfer Belt Unit
My printer (Sharp MX-C311) shows an error code: L4-16. Please advise on troubleshooting procedures.
Make sure the to pressure release levers on each side of the fuser are down. Turn the machine off for a minute then back on and should be fine.
Sep 14, 2011 | Sharp MX-M350 All-In-One Printer
Our Sharp MX C311 gives me the error : Network Interface is out of service. What is wrong with it?
sounds like your NIC card is bad, no network cable plugged in or the network port in the wall is not an active network port.
Aug 25, 2011 | Sharp MX-2300N Color Copier
MX-C311 Sharp...constantly sayd add drum. Drum has been put back into machine
When you installed the drum, was it a new drum you put in? And if so, was there a message being displayed to replace the drum? Because if so, you have to manually go into service mode and reset the drum counter.
-David.
Oct 30, 2010 | Sharp MX-M350 All-In-One Printer
48 people viewed this question
jasbo
jasbo
