Question about Craftsman PYT 9000 26 HP 48" Yard Tractor
Pto button pulled blades wont turn
Model number 917 289720 new battery mower works in every way but pto will not engage
  • 33 Answers
SOURCE: motor stops when the pto or cutting blades are turned on or engaged.
you most likely have a bad safety switch. there is one under your seat,one on engagement lever for blades,and probably one or two more in other places.start with the one under your seat by unplugging it and then going ahead with normale start up and implement engagement. you will have found the bad switch when everything works as it should.replace switch if you feel its necessary or just leave unplugged. it will not affect performance or longevity of the tractor
Posted on May 02, 2009
wadembly
  • 462 Answers
SOURCE: Craftsman riding mower blades will not engage
maybe the safty switch under seat might be starting to go out if that switch doesn't work the blades wont come on at all for safety
Posted on Jun 28, 2009
  • 95 Answers
SOURCE: prob with PTO on craftsman mower 917.273372
There is a idler pivot plate on the mower that must be cleaned and lubricated regularly, from the left side of the mower deck if you look in the middle of the mower deck while someone engages the mower(with the engine off) you will see the pulley try and move,there is a 3/8 bolt that comes up through a bushing that this pivots on, soak that area with wd-40 and see if that improves the movement. Be sure not to get any wd-40 on the belt or pulleys. Always try and keep that area clean and lubed.
Posted on Jul 30, 2009
braintrust
  • 62 Answers
SOURCE: after replacing the belt, new pulleys, and bolts,
sounds like the linkage to your blades, check your lever, to make sure its working right may need some grease, it may be sticking and not fully engaging, or doing its job when its supposed to
Posted on Oct 27, 2009
  • 9 Answers
SOURCE: i have a bolens 38 inch riding mower. it cranked
did you try depressing the clutch to disengage everything regardless of being in neutral? and it sounds like a pulley bearing went bad.try to spin the pulley with your hand and see if it moves.take the belt off to the mower deck and that should keep them from turning when you go to start it.
Posted on Feb 21, 2010
Testimonial: "thanks. at least i can crank it and get it to a trailer instead of pushing it. i really appreciate it.......cb"
Mowers shuts off when I engage the pto switch, I jumped all of the safety switches,put new pto switch on, belt and pulleys are fine! Please help
Craftsman Garden Tractor 917.28746 Engine shuts off when ...
www.shopyourway.com > Manage My Life > Questions
Craftsman Garden Tractor 917.28746 Engine shuts off when engaging mower deck. 917.28746 ... Then start the tractor and pull the pto button out. If the engine ...
Why does my engine die when the blade is engaged ... - iFixit
https://www.ifixit.com/.../Why+does+my+engine+die+when+the+bl...
iFixitI have an older Murray riding lawn mower, whenever I engage the mower the engine dies, otherwise it runs .... My dr feild brush mower ... cuts off when I engage theblades. ... My Huskee only shut off once I put it in drive with the blade engage.
Riding Lawn Mower Problem - Dies when PTO engaged - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
Apr 28, 2008 - When I pull the switch to engage the PTO, the engine bogs down real ...off I can keep the engine running with the mower engaged then it is fine ... Riding mower cuts out
May 18, 2010
mower dies when I let off the clutch
Sep 19, 2008
pto on Cub Cadet will not stay engaged...
Apr 6, 2008
Craftsman Mower deck (clutch) Won't engage
Jul 1, 2006
More results from forums2.gardenweb.com
Dec 29, 2015 | Garden
Troy Bilt 33" walk behind mower blades won't turn on.
Troy-Bilt Lawn Mower Blades Won't Engage - Model ...
www.repairclinic.com/...Mower/...-/Troy-Bilt-Lawn-mower-blades-won-t...
Most Frequent Causes for Lawn mower blades won't engage. See All Lawn Mower Parts for model 13AP60TP766. Cause 1 PTO Clutch. If the blades don't rotate the electric PTO clutch might not be engaging. ... Lawn mower wheels don't turn ...
Nov 08, 2015 | Troy Garden
X520 jd mower trouble
Sounds like a problem with the governor. Start it up. Don't engage the blades. Drive to a hill. Idle all the way down. Try driving up the hill. The motor should pick up when it slows while pulling up the hill. If it doesn't, the governor isn't working right.
Jul 16, 2013 | Garden
I have a Craftsman FS5500 48" lawn mower. The PTO makes a noise (squeak) for a second when I pull up on the red blade engage knob. The blades do not engage. PTO does not turn. When I push the red...
The problem is probably in the button that you pull and push to engaged and disengage the PTO... If you wiggle the button or try to pull it slowly, you may find a spot where it will work. But the button has gone bad and will need to be replaced.
If you are comfortable with wiring, you could jumper the wires and getting it working, but it would be a very temporary and possibly dangerous fix...
Jul 30, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
I had just started cutting grass with my John Deere L120 riding mower when the blades stopped turning. I thought the belt had broke or come off so I pulled into my garage to investigate. I turned the mower...
You have several safety switches on your unit. The engine should not start if the PTO safety interlock is engaged. Be sure PTO switch is off.
If the sarter Does Not Work Or Will Not Turn Engine Brake pedal is not depressed.
or the PTO is engaged.
Battery terminals are corroded. or Fusible Link in starting circuit is blown - (Not likely unless bad wires) Here is a link to your wiring diagram (maybe your model)
http://www.postimage.org/image.php?v=Pq1tOfiS
Notice how the starting circuit goes through the brake pedal (must be depressed) and the PTO switch (must be disengaged) and that the PTO only works with operator present. Print that page while link still works.
Aug 11, 2010 | Garden
CubCadet 1554 - won't start!
If you hear the PTO click when you turn the ignition on, sounds like the PTO button is pulled out like you were engaging the blades. The engine will not start if the PTO button is pulled out....
May 07, 2010 | Oregon Scientific Electric PTO Clutch for...
Husqvarna Mdl YTH2448 Riding Mower - Electric PTO Not Working
It sounds like your charge system is not working. If you jump the battery the engine will run with a weak battery but the pto clutch needs a strong battery to stay engaged.Try this to test it,after you jump it leav the jumper cables hooked up and try to engage the blade clutch,if it runs it is either a battery that wont take a charge or a charge system not working. If you put a volt meter on the battery while the engine is running and the voltage is 13 volts the charge system is working and the battery is bad.
Jul 31, 2009 | Husqvarna Garden
Husqvarna yth2448 pto switch kills motor/battery will not charge
you may hav a bad alt. problem with the mower dying when you engage the pto is most likley a bad sensor or wire unplugged on the seat sensor.the way it works is if the blades are turning and it dosent sense you being on the seat the mower shuts down.this has been standard on mowers for quite a few years now. it keeps the blades from cutting you up if you fall off the seat while mowing. as for charging i would try cleaning the battery connections and get the battery checked first.
Jul 16, 2009 | Husqvarna Garden
Cub cadet Z Force 48 inch zero turn blades won't engage
I hope this will help you...under the side panels on each side of the mower, there are "reverse lockout safety switches", they are supposed to stop the blades when both handles are pulled back. If one or both of the switches are out, the deck will not engage. Also, under the right side panel (when sitting on seat) there should be 3 relay switches, the one closest to the motor controls the PTO., if this is out, the PTO will not engage.
Jun 25, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Craftsman PYT 9000 26 HP 48" Yard Tractor Logo
49 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
