Question about Destroyit 2604 Cross Cut Level 3 Paper Shredder - 2604CC
Oil light for destroyit 2604 on and oil line is not completely filled
Oil will not pump and red oil light is on
You have to reset the oil indicator. Turn the machine on and then hold down the 'R' button for a few seconds. The oil lights will flash and then turn off and the machine will start drawing in the new oil.
Dec 10, 2013 | Destroyit 4005CC Shredder
Destroyit 5009 Shredder No power to the oil pump.
Investigate the operation purpose of the Oil Pump. Did you measure the voltage across the terminal or observe that the pump was not operational. It must have an auxiliary function that is not related to main operations. Investigate the purpose of the Oil Pump and deduce what would make it operate then check that switch if their is no voltage measured across the pumps terminal when it should be operating. This deductions may help lead to the problem and a solution.
Aug 27, 2013 | Destroyit 5009 Shredder
Destroyit keeps clogging
Oil the shredder, and make sure it's plugged into the wall and not a power bar.
Aug 24, 2012 | Office Equipment & Supplies
Destroyit 4107 keeps clogging
There could be several issues that can lead to this.
1.) check voltage, has anything been added to the circuit that could be reducing the voltage/amperage to this shredder
2.)excessive debris stuck around the cutter shafts
3.) is oil getting to the cutter shafts
4.) remove side panels and check the make sure the drive chain is lubricated.
Might not solve it but it's a good place to start.
Aug 24, 2012 | Destroyit 4107 Shredder
Heater won't stay on, I heard there was a recall on this item.
Hi and welcome to FixYa, I am Kelly.
I am only answering part of your question (Recall) so do not rate the post so other experts can help you with your heater won't stay on problem.
Your heater model is not one of the 4 models that were recalled.
The recall involves Holmes® models HFH6498-U, HFH6500-U and HFH6500TG-U and Bionaire® model BFH3530-U. The recalled heaters also have date codes beginning with 2604 through 3804 for all units, except for Holmes® model 6500TG-U, which has date codes ranging from 2604 through 4704. The model and date code can be found on the silver label on the back of the unit. The heater fans are 26 inches tall; come in all gray, two-tone gray, or black and gray; and have either the word Holmes® or Bionaire® printed on the front of the base.
See this link for more details:
http://www.holmesheaterrecall.com/
Thanks for choosing FixYa,
Kelly
May 22, 2011 | Bionaire BH3930 Oil Filled Radiator Heater
Use of Mineral oil or Vegetable oil for shredder?
Hi I am a shredder technician. Though it is not recommended you can use either as long as they dont gum up the machine over time. As this will cause you major problems. please leave feedback . Have a nice day. And good luck
May 30, 2010 | Destroyit 4004 Shredder
Destroyit 3102 drive gear part number
The part number you need is 2601 062 as long as your looking for the gear that meshes with the motor shaft. The price is around 25.00 dollars and phone number for destroyit or as known MBM corp. 800-223-2508
Hope this helps leave feedback if so. If you have trouble getting part contact me i'm a dealer and can get you the part.
May 14, 2010 | Destroyit 3102 Shredder
How much oil at the oil change and what weight?
Buy a 4 litre can of 10/40w, of good quality and fill inbetween the dip stick marks roughly about 3.5 liters,if you have a sight glass stand bike fully upright,get a mate to help then fill to inbetween the sight mark lines. If replacing the oil filter fill it up and lightly oil the o ring ,and do up tight by hand.Filling the oil filter will stop the enging running dry untill full,and give accurate fill reading.
Mar 02, 2010 | 1988 Honda VT 1100 C Shadow
Replacing fluids 0n 1996 300zx
radiator antifreeze: open drain **** on radiator and drain refill with water re plug and leave radiator cap off. start vehicle. watch when coolant drops or rises drastically as that is the thermostat opening. at that time re open drain **** and fill radiator with hose water at the same time. when water coming out is completely clear again turn vehicle off and drain radiator again. fill with antifreeze and water mix. 50/50
oil: jack up car, find oil plug, directly behind steering rack on oil pan. undo plug and drain oil into container. while oil is draining remove oil filter. wait for oil to drain completely then re-install drain plug and new oil filter(filled with oil) undo oil cap and pour in oil 4.5 quarts on n/a and 5 for turbo. tighten cap and your done.
brake system: dont attempt, use an experienced mechanic as the lines need to be bled in numerous places including inside the car from the abs module mounted behind the passenger seat.
easy brake system: individually bleed brakes while adding fluid until clear fluid comes out. (not efficient)
a/c: do not attempt unless you have an evac pump for ac systems.
clutch: same as easy brake except using the bleed valves at the slave cylinder and on passenger side fender well.
washer fluid: add fluid and squirt a little to make sure there is no air in the line
Jul 18, 2009 | 1996 Nissan 300ZX
Destroyit 2604 Cross Cut Level 3 Paper Shredder - 2604CC Logo
27 people viewed this question
Top Destroyit Office Equipment & Supplies Experts
k24674
Are you a Destroyit Office Equipment and Supply Expert? Answer questions, earn points and help others
