A3xo5f2g Freezing up
The unit freezes up regularly.
Defrost drain is freezing
it is a normal problem with all refr. there is a drain tube at the rear of the unit the has a "drain loop" it gets plugged after a few years. try and remove the tube from the clamp, and run water thru it to clear the blockage. you will also need to remove the ice from under the freezer coil after you clear the tube. after that the regular defrost cycle will take over and work properly.
Dec 31, 2013 | GE GDS18LBR Bottom Freezer Refrigerator
Water Dispenser Temperature Control/switch-off
Not on regular models. Most models have a water tank in the fridge compartment which makes the water temperature to stay just above freezing temperature.
Wanna a play with your unit. Then remove the tank and just add two pipe ends together. Eliminating the tank. Then you should get room temperature water after about 5 seconds of cold water. Be careful just connecting the two ends of pipe after removing tank might lead to freezing pipes if your fridge temperature is close to freezing temp.
Nov 26, 2013 | Samsung RF4287HA
I have noticed my heat pump is freezing up on the outside unit, we have had freezing rain and snow the last 2 days but I have never noticed ice accumulation on the outside of the unit, it also seems like...
In freezing weather the heat pump efficiency drops. The freezing is normal. The equipment has a board and sensor to defrost your heat pump. Now this system can fail but freezing rain and snow get pulled into the unit get pulled into the unit coil and freeze blocking airflow. You can defrost the unit by turning it to cooling. This is what the defrost board does automatically.
Dec 27, 2012 | Goodman Heating & Cooling
Everything is freezing in the refridgerator. The water dispenser will not put out water. We have taken the temperture to 0 then back to 5 and it still will freeze in the regular compartment.
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Mar 13, 2011 | GE Refrigerators
Unit freezing up
It will not hurt the unit if you let it thaw out and then run it again. However, if you keep doing this on a regular basis, you can burn out your compressor. What are the conditions that the unit is being run under that is causing it to freeze up? Make sure that you run the unit on high cool on warm days so that it will not freeze.
Hope this helps,
Jeff
Jul 03, 2009 | Heating & Cooling
Freezing up, home ac unit no air flow after running a while
A low freon level in the unit can cause them to freeze up. Are the fins behind the filter clean?
Jun 19, 2009 | Whirlwind FH-778 Air Conditioner
Freezing problem with d1 machine embroidery and regular sewing.
there was a recall for the designer 1 machines. visit husqvarna's website.
Nov 10, 2008 | Husqvarna Designer I
Items in fridge freezing..........
set too cold - set temp knob to a lower number
Sep 06, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Food freezing in refrigerator section of frig.
look under your refridgerator and see if there is alot of dust on the coils. Whenever food starts freezing in my fridge I vacuum the coils and the problem goes away.
Sep 01, 2008 | Refrigerators
Heating & Cooling Logo
18 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
