Question about Invacare Supply Group Invacare Pronto M51 Power Wheelchair - Blue - Power wheelchair
Yellow wrench is flashing 6 times on
My Pronto M51 electric wheel chair has stopped. On the joystick the yellow wrench if flashing 6 times. The company I bought it from put a diagnostics machine on it and it has given the fault code 0603. Can you tell me what that fault code means and what is the problem when the yellow wrench is flashing 6 times. Thank you so much, Amy
SOURCE: How do I charge My Pronto M51 motorized wheelchair?
I also have a Pronto M51 and use it daily. I have found though by leaving the charger plugged in over a weekend, it reduces the battery range and does not come back to normal until I use it for a week and charge it nightly. You can overcharge the batteries because the charger does not shut off entirely. I have monitored this with my meter.
Posted on May 13, 2009
SOURCE: pronto M51 ...the yellow light is blinks and dosen't stop
Take your drive units both out of gear and put them back in that will reset the computer and it started mine working again.
Posted on May 26, 2009
SOURCE: tool; light blinks 9 times battery is charged
the batteries were dead
Posted on Sep 07, 2009
  • 692 Answers
SOURCE: I bought a used pronto m51. What is up with the
Jhester Well You just need new batteries. Does the chair come on when you diconnect the charger and does it move? If you don't have all the battery level lights lit up when you turn it on then the batteries are too low for the charger to pick up. No lights no power New Batteries Hope this helps
Posted on Sep 17, 2010
  • 692 Answers
SOURCE: Battery indicator seems fine. Wrench symbol is
The wrench symbol being lit indicates a problem. Does the wrench symbol blink? when you try to engage the joystick the brakes should try to engage and you would hear them click and the symbol will flash. The number of flashes telling you what is wrong. If the symbol is not flashing and staying on then that also a probem but you can't tell what it is. Either way the chair will have to be checked by a tech that has a programmer to plug into the chair and read the error codes to determine the problem. Check with your provider that sold you the chair to see if they can troubleshoot the chair for you or contact Invacare Tech Support @ 1-800-333-6900 and explain your problem. Sorry I can't give you a definite answer Hope this helps
Posted on Mar 07, 2011
Pronto power chair m51 will not engage
Sorry to read about your problem, 1st make sure the charger is unplugged, then restart, next make sure your free wheel levers located in the back left and right side are pushed into the drive position, if the joystick is scanning back and forth, turn off then on and push the horn button twice. The Joystick maybe flashing at you a code.Count the lights and how many are flashing, this is a flash code that can be looked up your manual that came with every Pronto. Strege Mobility
Sep 07, 2017 | Health & Beauty
Light come on controller no flashing code lights joy stick does not work
The M51 could have the motor clutch levers in the free wheel/push mode and the joystick will not blink if this is the case. Make sure that the chair cannot be pushed. If it can be pushed it means it is in free wheel and you need to lock the motors in gear.
If it is in gear and the joysticks green light does not change color or blink it could be that the joystick is bad. When nothing happens and the lights don't blink when you push the joystick knob the chairs controller basically isn't recognizing the joystick movement.
Time to have the joystick repaired or more. Have a technician look at it.
Jun 16, 2015 | Invacare Pronto M51 Power Wheelchair
I get error code 9, what do I do to fix this
Error Code 9 is a "Communications Error". The controller, or "Little black box" down inside the chair is not talking to the joystick, etc. First, check all the connections. Unplug, examine and clean all of the connections going into the controller, and the joystick connection too. Inspect all of the cables for damage to the wiring. If all looks good, then you likely have a bad controller....ouch. These are very expensive to replace new. You might be able to find a used one on Ebay, etc., or you could be better off looking on sites like Craigslist for a complete powerchair replacement. I have found near-new chairs for under a thousand dollars. Search for Pride Jazzy chairs too...a lot more of those for sale than Invacare chairs. Good luck.
Jun 13, 2014 | Invacare Pronto M51 Power Wheelchair
How do u fix a pronto m51 wheel chair joystick after it got wet and it flashes 7 times
I would dry it completely and try it again. it may need to be opened and dried on the inside, or replace the joystick.
Strege Mobility
May 06, 2014 | Jet 3 Ultra Power Chair
I have a Invacare Pronto M51, the chair won't move. When I turn on the joystick, the wrench light flashes 9 times, stops, then flashes 9 times again. Can you tell me what that indicates?
A flash code of 9 indicates a communication fault. What this means is that there is a lack of communication between the joystick and the other electronic component, the controller module. In my experience, the usual culprit is that the charger plug makes bad contact inside the joystick housing causing it to heat up and burn. This can cause components inside the joystick to burn out. The other more common problem is that there is a break in the 4 wire harness going from the joystick down to the controller in the base. Sometimes it is just a matter of unplugging the connector, cleaning it, and pushing it back in. In other cases, the wire has been cut or broken along its length. Look for cuts along the black covering of the 4 wire harness (connecting cable)and twist and tape or splice and solder to repair the wires. These connecting harnesses are so inexpensive it is usually easier to replace, however a quick splice can get you going temporarily. If you smelled burning that would be an indication that the joystick assembly has burned out and I would replace that along with a new harness (connecting cable with a plug on each end) to the base electronic module.
The connecting cables have always been a weak link in this design and have had a history of failures over the years. For this reason I replace both the joystick assembly and connecting cable when servicing. Hope this helps.
Mar 21, 2014 | Invacare Pronto M51 Power Wheelchair
Yellow light blinks 9 times and chair won't move. how do i fix it?
The problem is bad communication between the joystick and the conroller or power module. By replacing the jostick cables you will see if that fixes the problem. Check with your provider (where you got your chair) to see if they have an extra joystick cable or can loan you one from a chair that they might have. Now there are 2 cables one from the joystick to the base of the chair and one from the base to the controller either could be bad but try the one to the joystick first Hope this helps
May 03, 2011 | Invacare Pronto M51 Power Wheelchair
My pronto m51 sure step service light is flashing seven time and it will only turn to the right
sarah check the joystick cable try unplugging it from the rear of the joystick and plugging it back in then unplug it at the back of the chair and plug it back then turn the chair on to see if you are still getting 7 flashes. If you are then you have one of 2 problems the joystick cable somehow is bad or the joystick itself has got a problem try the cables first to see if it fixes the problem If Medicare paid for the chair then they will pay for most of the repair Contact Roadrunner Mobility @ 1-800-467-2668 Hope this helps you
Apr 02, 2011 | Invacare Health & Beauty
The charge indicator lights flash left to right..when moving joystick the chair does not move.
chair is locked out. turn on then push joystick forward till it beeps then pull backward till it beeps then it is unlocked
Jun 15, 2010 | Invacare Pronto M51 Power Wheelchair
The electric wheelchair is flashing the locked symbol but we don't know how to unlock it so that it will work
Turn on chair, move joystick forward till it beeps, then all the way back till it beeps, and then let go of joystick, it should fire up.
May 20, 2010 | Invacare Pronto M51 Power Wheelchair
Hi, I have a pronto m51. The yellow led in the
If it's the yellow battery light it will blink when the battery voltage is very low, too low to drive and lower than the red blink.
May 10, 2010 | Invacare Supply Group Invacare Pronto M51...
Invacare Supply Group Invacare Pronto M51 Power Wheelchair - Blue - Power wheelchair Logo
247 people viewed this question
Top Invacare Supply Group Health & Beauty Experts
wcdoc1953
wcdoc1953
Robin Hill
Robin Hill
Are you an Invacare Supply Group Health and Beauty Expert? Answer questions, earn points and help others
