Question about Samsung SV5000W VHS VCR
Power light is on, but nothing happens.
I am having a bit of problem with my VCR, the power light is on, but nothing more happens. Any ideas, what could be the problem? Thanks
Could be faulty power supply - I have a similar issue. The only difference with mine is at that moment if I wait long enough (3 minutes from initial plugging in) the unit comes on.
I removed the lid, there is a damaged capacitor in the power supply area and scorch/burn marks on the lid.
I plan to replace the obviously faulty/damaged capacitors.
Posted on Feb 09, 2008
    Genius:
  • 1,139 Answers
Two questions, Are you able to load a cassette?, and are you able to watch TV through your VCR? These two questions are vital to further analysis. if the answer to both is no then you will have to take the VCR to a TV repair shop because it will require internal repairs that you may not have the equipment to perform. Please get back to me with the answers to these two questions Thank you,
Posted on Sep 05, 2007
Have 2 units both just flash "loading" and will
This happened last night on my new-to-me JVC SR-MV55. Even powering it off for five minutes didn't help. It apparently crashed during dubbing (couldn't create more than 9 chapter codes?). Manual suggested holding down Stop and Power after powering it down. But no matter how long I held Power it wouldn't stop flashing. But I tried Stop/Powwer for a bit, nothing seemed to happen, then maybe 15 seconds later it restarted "WAKE UP'".
Mar 25, 2011 | JVC SR-MV55 DVD Recorder / VCR Combo
Sylvania DV220SL8 won't play DVDs, DVD tray won't open
One simple solution is to unplug the unit for 30 seconds then plug it back in. Worked like a charm for me.
Jan 09, 2010 | Sylvania DV220SL8 DVD Player/VCR
VCR does not record when programmed to do so
is there a option to turn timer rec on/off?
Oct 20, 2008 | Televison & Video
DVD/VCR Combo is Locked. The read out on the box says LOCKED
You might press the "Childlock" (or something lock) button on the remote control to unlock it. Hope it help!
Oct 19, 2008 | GoVideo Go Video DVD/VCR Combo
Vcr won't play
having the same problem I would love to know myself!!!! PLEASE HELP
Mar 20, 2008 | RCA VR349 VHS VCR
VCR
you have probably bent the tab that holds the tape end sensor or its light. The tapes have a clear section at the end of the tape and the light shines through to the sensor to tell the unit that the tape is finished. The light should not pass through the recordable part of the tapes. If anything is bent the light may shine on the sensor and tell the unit you're at the end of the tape and to shut off. Some units have a tape tension sensor also that tells the unit that the tape is broken and to shut off. Only way to know is to remove power and take it apart and look for anything that may be bent. Stay away from the rotating head assembly and the posts that the tap travels on. Do not apply power with the unit open. Do not load a tape and remove power as some units freeze in the loaded position and will not load new tapes unless manually placed back in the unloaded position.
Oct 17, 2007 | Emerson EWR20V4 DVD Recorder/VCR
Canon CCD GL1
Hey hill,
This happened to me one time. Judging from the date of this, you probably have found a solution. The bottom line is that the camera has accidentally been placed in "Standby" mode. It is the lever surrounding the back of camera record button. When this is moved to standby, the VCR mode works, but nothing for the Camera mode. Hope this helps.
Oct 10, 2006 | Canon GL1 Mini DV Digital Camcorder
Samsung SV5000W VHS VCR Logo
202 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
